  2. Announcements
    Well, if I have communication working it means the node should be encrypting data. I'll have to try with clear eeprom and try flashing sketch again
    AnticimexA
    AnticimexA
    Anticimex
    @gohan not if there is no encryption at all. You could try to use simple password option on a node with various passwords and see if it is detected by your gw at all.
    • AnticimexA Anticimex
      @gohan have you verified your communications are actually encrypted?
      @anticimex I guess you were right... the gw and node aren't using the AES key. So where am I supposed to add it in the gateway?
      AnticimexA 1 Reply Last reply
        AnticimexA
        AnticimexA
        Anticimex
        @gohan you set that with the configure arguments I suspect, but I can't see it in the documentation. @marceloaqno perhaps knows how the rPi port handles this. I'm on a phone so I can't check the code easily. But you should be able to find it in the transport driver for rPi. On the rPi it can probably be defined in the code as it does not have a personalizer.
        gohanG 1 Reply Last reply
          @anticimex It doesn't read it from the mysonfig.h for sure as it is where I always put it
            AnticimexA
            AnticimexA
            Anticimex
            @gohan MyConfig.h does to my knowledge not have a define value for that. You cannot add new definitions to it and expect them to have an effect. If there is one already defined in there, as a comment or not, and it does not have an effect, please report a bug on it.
            • M macvictor
              @marceloaqno Thank's for you help. I have other question.. general I try configure my gateway to work with security & signing, but they doesn't work. Where is problem? On the bottom i send point what it do it:
              Gateway:
              2. make
              3. sudo make install
              10. sudo mysgw --gen-aes-key
              Node:
              #define USE_SOFT_SIGNING
              #define STORE_SOFT_KEY
              #define USER_SOFT_KEY
              #define STORE_SOFT_SERIAL
              #define STORE_AES_KEY
              #define USER_AES_KEY
              EEPROM configuration:
              // Enable NRF24L01 radio type
              // Select soft signing
              #define MY_SIGNING_SOFT
              // Enable node whitelisting
              #define MY_REPEATER_FEATURE
              #define BUTTON_PIN  3   // Arduino Digital I/O pin number for button
              #define CHILD_ID 1      // Id of the sensor child
              #define RELAY_ON 1
              #define RELAY_OFF 0
              Bounce debouncer = Bounce();
              int oldValue = 0;
              bool state;
                // Setup the button
                pinMode(BUTTON_PIN, INPUT);
                // Activate internal pull-up
                debouncer.attach(BUTTON_PIN);
                debouncer.interval(5);
                pinMode(RELAY_PIN, OUTPUT);
                state = loadState(CHILD_ID);
                digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);
              void presentation()  {
                debouncer.update();
                // Get the update value
                int value = debouncer.read();
              //  oldValue = value;
                delay(5000);
                if (message.isAck()) {
                  // Change relay state
                  state = message.getBool();
                  // Store state in eeprom
              4 TSM:INIT
              5 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSF:SID:OK,ID=105
              15 TSM:FPAR
              2065 !TSM:FPAR:NO REPLY
              2067 TSM:FPAR
              4117 !TSM:FPAR:NO REPLY
              4119 TSM:FPAR
              6169 !TSM:FPAR:NO REPLY
              6171 TSM:FPAR
              8221 !TSM:FPAR:FAIL
              8222 TSM:FAIL:CNT=1
              8224 TSM:FAIL:PDT
              and in gateway i see:
              sudo mysgw -d
              mysgw: Starting gateway...
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              mysgw: connected to 127.0.0.1
              mysgw: MQTT connected
              mysgw: !TSF:MSG:PVER,3=2
              mysgw: !TSF:MSG:PVER,1=2
              mysgw: TSF:MSG:REL MSG
              mysgw: !TSF:RTE:240 UNKNOWN
              mysgw: !TSF:MSG:PVER,0=2
              mysgw: !TSF:RTE:233 UNKNOWN
              mysgw: !TSF:RTE:51 UNKNOWN
              Where is problem?
              rajeev2301R
              rajeev2301R
              rajeev2301
              @macvictor
              I followed all the step that you mentioned in your post to establish the serial gateway. However I am still not able to receive the message from arduino. Could you please what to do?
              import RPi.GPIO as GPIO
              from lib_nrf24 import NRF24
              import time
              import spidev
              GPIO.setmode(GPIO.BCM)
              pipes = [[0xE8, 0xE8, 0xF0, 0xF0, 0xE1], [0xF0, 0xF0, 0xF0, 0xF0, 0xE1]]
              radio = NRF24(GPIO, spidev.SpiDev())
              radio.begin(0,8)
              radio.setPayloadSize(32)
              radio.setChannel(0x76)
              radio.setDataRate(NRF24.BR_1MBPS)
              radio.setPALevel (NRF24.PA_MAX)
              radio.setAutoAck(True)
              radio.enableDynamicPayloads()
              radio.enableAckPayload()
              radio.openReadingPipe(1 ,pipes[1])
              radio.printDetails()
              radio.startListening()
              radio.GPIO.cleanup()
              Please find below my raspberry code..can you please suggest , if there is any issue with code or am I missing anything ?
              • rajeev2301R rajeev2301
                @macvictor
                import time
                import spidev
                radio.begin(0,8)
                @rajeev2301 please don't split our effort to help you into multiple threads. It wastes people's time when some information is in one thread and some in another thread.
                • wesW
                  wesW
                  wes
                  To upgrade to the latest release, can I use git pull, or is it better to delete the directory and start again?
                  Blog: https://www.wes.id.au/
                  Nodes: Arduino Pro Mini ATMega328P 3.3V 8MHz, RFM69 433MHz, Canton Power CE024 0.8-3.3V regulator & single AA battery
                  Gateway & Controller: Raspberry Pi 3 + Home Assistant
                  • wesW wes
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @wes you can pull. Just as long as you verify that your working directory is clean or only contains changes you intend to have. And you have the appropriate branch or tag checked out.
                    S 1 Reply Last reply
                    • M macvictor
                      Gateway:
                      2. make
                      Node:
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue = 0;
                      bool state;
                        // Setup the button
                        debouncer.update();
                        delay(5000);
                      4 TSM:INIT
                      5 TSF:WUR:MS=0
                      11 TSM:INIT:TSP OK
                      15 TSM:FPAR
                      2067 TSM:FPAR
                      4119 TSM:FPAR
                      6171 TSM:FPAR
                      8221 !TSM:FPAR:FAIL
                      8222 TSM:FAIL:CNT=1
                      8224 TSM:FAIL:PDT
                      sudo mysgw -d
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: MCO:BGN:STP
                      Where is problem?
                      pepsonP
                      pepsonP
                      pepson
                      @macvictor
                      Hi
                      Is any chance to add security & signing for radio RFM69HW ? Please help me how ?
                      • pepsonP pepson
                        @macvictor
                        Hi
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @pepson signing is radio agnostic. It has nothing to do with the radio.
                          sineverba
                          @anticimex @wes Can I please ask how to update? I mean, the right command to type.
                          I have the folder "MySensors" on documents of my user in Pi:
                          /home/sineverba/MySensors
                          Of course I have all installed and perfectly working now (I'm on the 2.2.0 rc2).
                          I need also to relaunch the ./config command?
                          Thank you to both and all!
                          • S sineverba
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @sineverba https://www.mysensors.org/download
                              Syna
                              Hello, I configure the raspberry gateway to use MQTT. I set mosquitto as the broker. The problem that I encounter is that when I subscribe to test if the gateway publish on the broker, I have empty message. So my first guess is that there is an issue somewhere which cause that only empty message are sent.
                              • Sergio RiusS
                                Sergio RiusS
                                Sergio Rius
                                Regarding the communication issues described in the instructions page with the 2.2 stable version, is that still valid and still recommended to use the development branch?
                                    Sergio RiusS
                                    Sergio RiusS
                                    Sergio Rius
                                    @gohan Thank you verys muchos. :+1:
                                    • S Syna
                                      marceloaqno
                                      Code Contributor
                                      wrote on last edited by marceloaqno
                                      #797
                                      #define MY_NODE_ID X
                                        sineverba
                                        Hi to all,
                                        1 - Disable the daemon with
                                        sudo rm -r MySensors
                                        4 - Git the "new" MySensors folder && configure it as usual. Remember to activate the daemon and see on Domoticz (for example) the gateway with new version :)
                                        • O
                                          O
                                          otto001
                                          # -*- coding: utf-8 -*-
                                          LOOKFOR = u"mysgw"
                                              if proc.name() == "mysgw":
                                                  #print(proc)
                                                  #print(cpu)
                                                  #print(proc.cpu_times())
                                                  if cpu > 50:
                                                  else:
                                          Cheers,
                                          Pula
                                          Nick WillisN 1 Reply Last reply
