  3. 💬 Easy/Newbie PCB (RFM69 HW/W edition) for MySensors
mysensoreasynewbiepcbmysx
106 Posts 20 Posters 57.0k Views 19 Watching
  • ? A Former User
    @sundberg84 - I attached the BME280 to D5 to switch on/off (to achieve less power consumption) but if I upload the program the module powers up, and connecting, send a measurement with temp, hum, bat and goes to sleep than wake up, and does nothing. If I attach the sensor to normally VCC + GND, it works fine. How can it be? What could be the problem?
    sundberg84S
    sundberg84S
    @ZsoltZombori - Did you put the pin HIGH before read? (Comfirm with a multimeter?) If you did, you might want to add a wait(); before the readings so the sensors gets time to stabilise?
    Or the BME module needs some sort of initialization/startup after powered on?
    ? 1 Reply Last reply
      I think you need to reinitialize the sensors before you actually read it after you power it down. I suggest you remove the instructions in setup and put everything in a function that you call every time you read the sensor, where in the beginning you set pin D5 high and at the end you set it low.
      • sundberg84S sundberg84
        A Former User
        wrote on last edited by [[global:former-user]]
        #49
        @sundberg84 - Very good tip, I read the datasheet of bme280 sensor and it need time to initialize. I added 10 ms wait to program,
        @gohan - I made a very beginner mistake as you said. The wire.begin was added to setup, I wrote it to loop, but it is not working..
        • sundberg84S
          sundberg84S
          #50
          Some initial changes for Rev 10.
          • MysX location changed to accept more MysX boards and align like Nrf24 version.
          • Antenna location changed, radio rotated 180 degrees
          • Optional signing added
          • Optional SPI flash added.
          • Extra pins aligned to 2.45 vertical & horizontal
          • Relocated Extra + Bat Measurer some to allow more space to booster
          • Pinholes added for RFM Radio
          • Changed pull-up resistor from D3 to D5 to have one more pin for Interrupt
            Are there any arduino pin left that could be connected to the "extra" area?
              sundberg84S
              sundberg84S
              @gohan - yes, but then you are not free to use the extra area as you like.
                In that case a trace cut would solve the problem :-)
                  sundberg84S
                  sundberg84S
                  #54
                  @gohan isn't a trace cut harder to achieve than solder a wire to the right pin?
                    I don't know, but it has been quite tedious to bridge the pins that were just next to the "extra" area to test the fota. 😅
                      mickecarlsson
                      wrote on last edited by mickecarlsson
                      #56
                      Please make the pad for the antenna on the "bottom" larger, same as "above". Most ready-made antennas are with a 90 degree wire for easier soldering.
                      RFM69 antenna
                        mickecarlsson
                        Proposal.
                        Make two of the pads at the extra area with A4 and A5 (I2C) as more and more sensors are I2C.
                        Preferably the two pads next to VCC and GND.
                        Like the BMP280 and BME280, they are I2C with VCC, GND, SCL and SDA, so first line of pins in the extra area should be:
                        VCC o-o-o-o
                        GND o-o-o-o
                        A5 -o o o o
                        A4 -o o o o
                        The new layout with the SMD on the bottom layer looks good.
                        • M mickecarlsson
                          RFM69 antenna
                          sundberg84S
                          sundberg84S
                          #58
                          @mickecarlsson - im not sure what you mean with:
                          Picture?
                          I was thinking about I2c but the problem is that different sensors use different pin-orders.
                          Also see the discussion with gohan above about extra area.
                            mickecarlsson
                            This area that I have painted red.
                            • M mickecarlsson
                              sundberg84S
                              sundberg84S
                              @mickecarlsson - aha!! Okey, no problems :) I will just double-check this will not cause any issues with a SMA antenna.
                                mickecarlsson
                                I have just finished soldering my last four easypcb with BME280:
                                • M mickecarlsson
                                  sundberg84S
                                  sundberg84S
                                  @mickecarlsson - Woao - looks great!
                                  If you do that many with Ic2 i can understand you want extra area to be extended ;) I will think about it or maybe I can do a MysX daugherboard to you instead.
                                  Can I use your pic as a good example on the openhardware page?
                                  gohanG 1 Reply Last reply
                                    mickecarlsson
                                    Yes, you can use the pictures. If you need better pictues I can provide it to you.
                                      @sundberg84 are you going to test the SPI Flash with FOTA? at least to get an idea of the compatible chips that can be used.
                                        sundberg84S
                                        sundberg84S
                                        #65
                                        @gohan that was my plan. What is your thought s about this ? I have never used fota or spi flash.
                                        I'm not a software guy though... I can test hardware.
                                          The hardest part of fota is to wire the spi flash, the rest it is quite easy once you have the mycontroller installed. I can help you out if you want
