716 Posts 111 Posters 703.1k Views 93 Watching
    @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
    Also a bit worried the 4,7uF cap os to far away from radio.
    Putting it underneath the nrf24 module? I know it is not a "clean solution" but there would be still be unused space under the radio module
    sundberg84S
    sundberg84S
    @gohan - thanks, not what I want to do - I have descided to have optional/more advanced on bottom side. This is the core idea of the PCB. I might revert back to Rev 9 footprint and squeeze it in like prev. revision.
      maybe a smaller footprint for ceramic instead of electrolitic?
      • sundberg84S sundberg84
        A short sneak-peak on the upcoming revision...
        Still a long way to go...
        Rev 10 - Nrf24l01+ ed.
        • Completley redesigned in KiCad.
        • MysX location changed to accept more MysX boards and align like RFM version.
        • Optional signing added
        • Optional SPI flash added.
        • Extra pins aligned to 2.45 vertical & horisontal
        • Relocated Extra + Bat Measurer some to allow more space to booster
        • Changed pull-up resistor from D3 to D5 to have one more pin for Interrupt
        • Relocated D5 pullup, MysX and IRQ jumper some.
        • Changed footprint (silk-screen) on capacitor to easier show Gnd/Pos side.
        Need to change footprint on voltage regulator on both nrf and rfm edition back to a square and not a liniar one. (rev 9 change). Not intended to revert back.
        Please don't do like that and follow the guideline for the MYSX connector (location was already wrong in previous versions and it's a bit annoying to make MYSX boards for Easy PCB):
        *"The MYSX connector should be placed close to the board edge with a 100 mil spacing from all edges. The footprint has a courtyard outline to emphasize this"
        I agree especially with other traces to cross before reaching the radio.
        • Nca78N Nca78
          sundberg84S
          sundberg84S
          #521
          @nca78 said in 💬 Easy/Newbie PCB for MySensors:
          I actually had a long discussion with @Anticimex which is the designer of MysX and he said it is not wrong. Can you please explain why it's wrong ?
          I was thinking pin 1 should go towards both vertical and horizontal edge of the pcb (that's why I asked him because I though It should go where the radio is) but he said the only rule is pin 1 should go towards the edge. I looked at the rules and that is what it said so I don't think I'm breaking any rules.
          The footprint has a courtyard outline to emphasize this.
          It should be oriented so that pin1 is always closest to the board edge parallel to the connector.
          This allows a daughter board designed using the same constraints to be facing back "inwards" over the motherboard
          Either way it has changed like less than 1mm
          If we can somehow get Anticimex to recommend and we can agree on a better placement I'm happy to re-think my design.
          If you thinks it's hard to create MysX boards for EasyPcb I have created a finished Kicad project with board outlines, connector and drill holes you can use as a template. Check it out on the project page.
          AnticimexA 1 Reply Last reply
            AnticimexA
            AnticimexA
            Anticimex
            #522
            @sundberg84 I cannot see anything wrong with the MYSX placement on that board.
            If one could pick freely, ideal placement of the connector would be in the middle of the board side to allow daughter boards to extend both "upward" and "downward".
            But the important rule is the one already cited, that pin1 is oriented to ensure daughterboard orientation relative to the motherboard and that there is spacing around the connector so that the daughterboard female connector does not come in contact with main board cirquitry.
            Also that the daughterboard does not protrude outside of the mainboard at least along the edge the connector is aligned to.
            Daughterboards in general should not be designed to be wider than the MYSX connector used for this reason (avoiding daughterboard protruding outside mainboard area) to allow a mainboard specific case to be reused with daughterboards mounted.
            Edit: if possible, try to move the components right next to the connector. (remember the 100mil spacing). The resistor below can probably be mounted on the reverse side.
            • AnticimexA Anticimex
              @sundberg84 I will just go ahead and update the spec. Yes, it may cause some existing designs to violate the spec, but that will always be the case. We look forwards, not backwards :)
              Spec is here.
              sundberg84S
              sundberg84S
              #523
              Back to the drawing desk! :)
              Edit: MysX alignment changed so PCB needs to be redesigned.
              • Nca78N
                wrote on last edited by Nca78
                #524
                I have moved the discussion about the alignment here :
                https://forum.mysensors.org/topic/9060/mysx-connector-alignment
                • sundberg84S
                  sundberg84S
                  Thoughs? (Noth Nrf + RFM)
                  @Nca78 - MysX alignment?
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @sundberg84 be careful about daughterboards colliding with the pro mini.
                      sundberg84S
                      sundberg84S
                      @anticimex - thanks for input. Same with radio I guess... ? Don't know how to solve it by fitting all these things into one board.
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @sundberg84 The rfm69 radio can be surface mounted. If one goes for headers, the pitch it uses allow for low profile headers so the radio should go clear under a daughterboard assuming it does not have reverse side mounted components with a high profile.
                          sundberg84S
                          sundberg84S
                          #529
                          @anticimex you could use male headers on mother and female headers on daughter...
                          Or just mount the mother on top.
                          here it seems the capacitor is the biggest concern.
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @sundberg84 if I remember correctly, the motherboard has to use male MYSX. So there is no option for that. I thought you planned to use sockets for the arduino. But if it is soldered directly on the pcb, it should go clear I think. But best to use angled ftdi interface then.
                            • Nca78N
                              Yes I guess the only viable solution with MYSX and a pro mini is to solder the promini without headers so it can be under the daughter board and big (electrolytic capacitor) or sensible (radio antenna) stuff can be as far away as possible.
                              @sundberg84, I'm not sure it's great to have antenna in that position for my "vertical" concept but I guess it's not a great idea any more to do that. Now that pin 1 is in a corner I have all the space in the world to put reed/hall switch next to the other side (on top of pro mini) and it will be much more in line with expected use of MYSX connector.
                              Antenna is on the side that's not supposed to be below daughter board so I don't think you can do better for that., I think it's much better than before, I'll be able to make a board that's more versatile than the current one with footprints for most common sensors.
                                #532
                                @sundberg84
                                not sure but on your preview, I see that you don't use any gnd planes?? Imho, just sayin for your users :), it would be better to have it, ideally unbroken+ vias, for impedance, emi, rf counterpoise, impedance matching rf feedline to sma depending on its length and how it's routed etc.., maybe a little google it ;)
                                looks nice :+1:
                                • scalzS scalz
                                  @sundberg84
                                  looks nice :+1:
                                  sundberg84S
                                  sundberg84S
                                  @scalz - yes it is true about ground plane! I did that one rev 4 or something but something broke the thing... so I have been hesitating since but I know all about the benefits - been reading and googling.
                                  I have not made any traces or planes on the images - just component placement. I will give it another shot... maybe I have learned some since rev 4 ;)
                                  Thanks for your feedback.
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @sundberg84 I forgot to mention that your nRF24 module goes very close to the MYSX. There is a risk a female receptacle might collide with the rf module if you are unlucky. And daughterboards will most likely be at least as wide as the courtyard of the MYSX.
                                      #535
                                      @sundberg84
                                      yes not talking about your latest but saw that on your rev9 and 10 pics.
                                      it will make it better, and it's good point for rf quality (range and msg fail) ;)
                                      placing planes is one of the first thing I usually do after component placements.. then it's easier to route as it solves many connection.
                                      keep the good work!
                                        Mr_sensor
                                        @sundberg84 I have a "newby" question about how to use the Extra's part of the board. If I want to connect a DS18B20 sensor per example can I just solder it on the extra area and connect is with some wires to the pinout I need?
                                        Asking this because I did this with the i2c sensor on the board discussed here. having a wire form the extras towards the arduino i2c pins directly. Later I discovered that the i2c pins are also on the board.
                                        So how to deal with this?
                                          you can add a wire to the I2C pins, in your case you just need a short wire to a digital pin that are just next to the Extra area
