716 Posts 111 Posters 703.1k Views 93 Watching
    you are also missing the capacitor on the booster output for better stability
      Mr_sensor
      @gohan said in 💬 Easy/Newbie PCB for MySensors:
      Ok, I assumed it was not needed when using a battery. Which one to use there?
        It is needed if you use a booster. Look at project page for details.
        • M Mr_sensor
          sundberg84S
          sundberg84S
          @mr_sensor a advice is to measure the resistance again over the resistors.
          • sundberg84S sundberg84
            Mr_sensor
            @sundberg84 Well I tried that but did not get the measurement straight from the pcb si I decided t solder a new board using the right capacitor this time (0,1uf instead of 1uf) made sure using the right resistors as well and adding a capacitor after the booster. Than with the same mini pro from the other board tested again and wow it is working as intended.
            Child ID 2Battery Voltage: 3.44 V
            Battery Percent: 102 %
            2930 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:102
            2938 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            2945 TSF:TDI:TSL
            2947 MCO:SLP:WUP=-1
            2949 TSF:TRI:TSB
            3065 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            3178 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            957
            Child ID 2Battery Voltage: 3.22 V
            Battery Percent: 95 %
            3690 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
            3698 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            3704 TSF:TDI:TSL
            3706 MCO:SLP:WUP=-1
            3708 TSF:TRI:TSB
            3815 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            3932 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            955
            Child ID 2Battery Voltage: 3.21 V
            4442 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            4452 TSF:TDI:TSL
            4454 MCO:SLP:WUP=-1
            4456 TSF:TRI:TSB
            4560 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            4673 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            953
            5185 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            5193 TSF:TDI:TSL
            5195 MCO:SLP:WUP=-1
            5197 TSF:TRI:TSB
            5304 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            5416 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            952
            Child ID 2Battery Voltage: 3.20 V
            5926 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            5935 TSF:TDI:TSL
            5939 MCO:SLP:WUP=-1
            5941 TSF:TRI:TSB
            6045 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            6158 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            952
            6670 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            6678 TSF:TDI:TSL
            6680 MCO:SLP:WUP=-1
            6682 TSF:TRI:TSB
            6789 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            6901 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            952
            7411 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            7419 TSF:TDI:TSL
            7424 MCO:SLP:WUP=-1
            7426 TSF:TRI:TSB
            7530 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            7643 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            952
            8155 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            8163 TSF:TDI:TSL
            8165 MCO:SLP:WUP=-1
            8167 TSF:TRI:TSB
            8273 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            8388 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            955
            8898 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            8908 TSF:TDI:TSL
            8910 MCO:SLP:WUP=-1
            8912 TSF:TRI:TSB
            9021 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            9132 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            948
            Child ID 2Battery Voltage: 3.19 V
            Battery Percent: 94 %
            9646 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:94
            9654 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            9660 TSF:TDI:TSL
            9662 MCO:SLP:WUP=-1
            9664 TSF:TRI:TSB
            9771 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            9881 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            952
            10395 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=OK:95
            10403 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            10409 TSF:TDI:TSL
            10412 MCO:SLP:WUP=-1
            10414 TSF:TRI:TSB
            10520 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            T: 998.00
            10635 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:998.0
            H: 998.00
            953
            11147 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
            11155 TSF:TDI:TSL
            Now in mqtt I can see the percentage as:
            95
            qos : 0, retain : false, cmd : publish, dup : false, topic : **mygateway1-out/2/255/3/0/0**, messageId : , length : 30, Raw payload : 5753```
            But not the voltage?
            • M Mr_sensor
              2945 TSF:TDI:TSL
              2947 MCO:SLP:WUP=-1
              2949 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              957
              3704 TSF:TDI:TSL
              3706 MCO:SLP:WUP=-1
              3708 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              955
              4452 TSF:TDI:TSL
              4454 MCO:SLP:WUP=-1
              4456 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              953
              5193 TSF:TDI:TSL
              5195 MCO:SLP:WUP=-1
              5197 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              952
              5935 TSF:TDI:TSL
              5939 MCO:SLP:WUP=-1
              5941 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              952
              6678 TSF:TDI:TSL
              6680 MCO:SLP:WUP=-1
              6682 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              952
              7419 TSF:TDI:TSL
              7424 MCO:SLP:WUP=-1
              7426 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              952
              8163 TSF:TDI:TSL
              8165 MCO:SLP:WUP=-1
              8167 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              955
              8908 TSF:TDI:TSL
              8910 MCO:SLP:WUP=-1
              8912 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              948
              9660 TSF:TDI:TSL
              9662 MCO:SLP:WUP=-1
              9664 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              952
              10409 TSF:TDI:TSL
              10414 TSF:TRI:TSB
              T: 998.00
              H: 998.00
              953
              11155 TSF:TDI:TSL
              95
              sundberg84S
              sundberg84S
              @mr_sensor good to hear its working.
              It looks like you are only sending the % and not the voltage?
              • D
                dakipro
                @Mr_sensor It happened to me once that capacitor was just shortening the circuit, it was a smd, but when I removed it and tested it it was constantly making shortage, thus the circuit was never working and luckily my power supply had a low enough protection.
                I examined cap very closely, all looked fine, but internally it was not working fine.
                Since most of us (well, me at least) are buying cheap components I made it a habit now to always measure every passive component before installation, partly eliminates one variable
                • sundberg84S
                  sundberg84S
                  #516
                  A short sneak-peak on the upcoming revision...
                  Still a long way to go...
                  Rev 10 - Nrf24l01+ ed.
                  • Completley redesigned in KiCad.
                  • MysX location changed to accept more MysX boards and align like RFM version.
                  • Optional signing added
                  • Optional SPI flash added.
                  • Extra pins aligned to 2.45 vertical & horisontal
                  • Relocated Extra + Bat Measurer some to allow more space to booster
                  • Changed pull-up resistor from D3 to D5 to have one more pin for Interrupt
                  • Relocated D5 pullup, MysX and IRQ jumper some.
                  • Changed footprint (silk-screen) on capacitor to easier show Gnd/Pos side.
                  Need to change footprint on voltage regulator on both nrf and rfm edition back to a square and not a liniar one. (rev 9 change). Not intended to revert back.
                  Also a bit worried the 4,7uF cap os to far away from radio.
                  gohanG Nca78N 2 Replies Last reply
                    @sundberg84 said in 💬 Easy/Newbie PCB for MySensors:
                    Putting it underneath the nrf24 module? I know it is not a "clean solution" but there would be still be unused space under the radio module
                      sundberg84S
                      sundberg84S
                      @gohan - thanks, not what I want to do - I have descided to have optional/more advanced on bottom side. This is the core idea of the PCB. I might revert back to Rev 9 footprint and squeeze it in like prev. revision.
                        maybe a smaller footprint for ceramic instead of electrolitic?
                          Please don't do like that and follow the guideline for the MYSX connector (location was already wrong in previous versions and it's a bit annoying to make MYSX boards for Easy PCB):
                          *"The MYSX connector should be placed close to the board edge with a 100 mil spacing from all edges. The footprint has a courtyard outline to emphasize this"
                          I agree especially with other traces to cross before reaching the radio.
                          • Nca78N Nca78
                            sundberg84S
                            sundberg84S
                            #521
                            @nca78 said in 💬 Easy/Newbie PCB for MySensors:
                            I actually had a long discussion with @Anticimex which is the designer of MysX and he said it is not wrong. Can you please explain why it's wrong ?
                            I was thinking pin 1 should go towards both vertical and horizontal edge of the pcb (that's why I asked him because I though It should go where the radio is) but he said the only rule is pin 1 should go towards the edge. I looked at the rules and that is what it said so I don't think I'm breaking any rules.
                            The footprint has a courtyard outline to emphasize this.
                            It should be oriented so that pin1 is always closest to the board edge parallel to the connector.
                            This allows a daughter board designed using the same constraints to be facing back "inwards" over the motherboard
                            Either way it has changed like less than 1mm
                            If we can somehow get Anticimex to recommend and we can agree on a better placement I'm happy to re-think my design.
                            If you thinks it's hard to create MysX boards for EasyPcb I have created a finished Kicad project with board outlines, connector and drill holes you can use as a template. Check it out on the project page.
                            AnticimexA 1 Reply Last reply
                              AnticimexA
                              AnticimexA
                              Anticimex
                              #522
                              @sundberg84 I cannot see anything wrong with the MYSX placement on that board.
                              If one could pick freely, ideal placement of the connector would be in the middle of the board side to allow daughter boards to extend both "upward" and "downward".
                              But the important rule is the one already cited, that pin1 is oriented to ensure daughterboard orientation relative to the motherboard and that there is spacing around the connector so that the daughterboard female connector does not come in contact with main board cirquitry.
                              Also that the daughterboard does not protrude outside of the mainboard at least along the edge the connector is aligned to.
                              Daughterboards in general should not be designed to be wider than the MYSX connector used for this reason (avoiding daughterboard protruding outside mainboard area) to allow a mainboard specific case to be reused with daughterboards mounted.
                              Edit: if possible, try to move the components right next to the connector. (remember the 100mil spacing). The resistor below can probably be mounted on the reverse side.
                              • AnticimexA Anticimex
                                @sundberg84 I will just go ahead and update the spec. Yes, it may cause some existing designs to violate the spec, but that will always be the case. We look forwards, not backwards :)
                                Spec is here.
                                sundberg84S
                                sundberg84S
                                #523
                                Back to the drawing desk! :)
                                Edit: MysX alignment changed so PCB needs to be redesigned.
                                • Nca78N
                                  wrote on last edited by Nca78
                                  #524
                                  I have moved the discussion about the alignment here :
                                  https://forum.mysensors.org/topic/9060/mysx-connector-alignment
                                  • sundberg84S
                                    sundberg84S
                                    Thoughs? (Noth Nrf + RFM)
                                    @Nca78 - MysX alignment?
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @sundberg84 be careful about daughterboards colliding with the pro mini.
                                        sundberg84S
                                        sundberg84S
                                        @anticimex - thanks for input. Same with radio I guess... ? Don't know how to solve it by fitting all these things into one board.
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @sundberg84 The rfm69 radio can be surface mounted. If one goes for headers, the pitch it uses allow for low profile headers so the radio should go clear under a daughterboard assuming it does not have reverse side mounted components with a high profile.
