  3. 💬 MyMultisensors
💬 MyMultisensors
328pmotionatsha204amulti sensorhumiditytemperaturepirambiant lightlow powercoincell
176 Posts 33 Posters 95.0k Views 35 Watching
  • alexsh1A alexsh1
    @scalz Can you please enlighten me re PIR? There are two inputs D6 and D7. I cannot understand why and how to manage them in a sketch? Previously, I only used one digital input.
    #148
    @alexsh1
    You need to use pinchange interrupts. I won't reinvent a howto, there are multiple on google, like the one from Gammon here
    https://gammon.com.au/forum/?id=11488&reply=6#reply6
    pinchange can only detect toggle. it's up to you to detect the pin state in the interrupt routine.
    Mysensors sleep() doesn't handle pinchange. so in this case, just use sleep(ms). and test for the irq flag when it wakes up
    In a previous post, I extracted and showed you the few functions needed for this. I thought it was enough documented!
    ISR (PCINT1_vect)
      if (digitalRead(AMBIANT_LIGHT_PIN))
        irqLight = false;
        irqLight = true;
    ISR (PCINT2_vect)
      if((PIND & (1 << PIND6)) == 0x40 ) {
    	  myPirSensor.pirhCount++;
    		myPirSensor.irqPir = true;
      if((PIND & (1 << PIND7)) == 0x80 ) {
    	  myPirSensor.pirlCount++;
    Function: pirIntEnable
    Purpose : Enable pin change for PIR interrupt
    Input   : -
    Output  : -
    Comments:
    void pirIntEnable()
      // Enable pin change for D6, D7
      PCMSK2 |= bit (PCINT22);
      PCMSK2 |= bit (PCINT23);
      PCIFR  |= bit (PCIF2);   // clear any outstanding interrupts
      PCICR  |= bit (PCIE2);   // enable pin change interrupts for D0 to D7
    Function: pirIntDisable
    Purpose : Disable pin change for PIR interrupt
    Input   : -
    Output  : -
    Comments:
    void pirIntDisable()
      // Disable pin change for D6, D7
      PCICR  ^= bit (PCIE2);   // disable pin change interrupts for D0 to D7
    Function: lightIntEnable
    Purpose : Enable pin change for OPT3001 interrupt
    Input   : -
    Output  : -
    Comments:
    void lightIntDisable()
      PCMSK1 |= bit (PCINT9);
      PCIFR  |= bit (PCIF1);   // clear any outstanding interrupts
      PCICR  |= bit (PCIE1);   // enable pin change interrupts for A0 to A5
    Function: Light_IntDisable
    Purpose : Disable pin change for OPT3001 interrupt
    Input   : -
    Output  : -
    Comments:
      PCICR  ^= bit (PCIE1);   // disable pin change interrupts
    So if we add this, in the MySensors Motion example, as a very basic example, this should look like this:
    (untested, no time, but it should be close or maybe working)
    // Enable debug prints
    // #define MY_DEBUG
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    #define PIR_SETTLE_TIME 300000
    #define PIR_INT_PINH 6   // The digital input you attached your motion sensor.
    #define PIR_INT_PINL 7   // The digital input you attached your motion sensor.
    // Initialize motion message
    volatile bool irqPirHigh = false;
    Pin change Interrupt Service Routine for D0 to D7
    ISR (PCINT2_vect)
      // Pin change interrupt!
      // if one of the PIR pins is HIGH, we have a pulse
      if((PIND & (1 << PIND6)) == 0x40 || (PIND & (1 << PIND7)) == 0x80 ) {
         irqPirHigh = true;
    Comments:
    void pirIntEnable()
    Comments:
      Function: before
      Purpose : set pin states
      Comments: before setup Mysensors init
    void before()
      hwDigitalWrite(PIR_INT_PINH, LOW);
      hwPinMode(PIR_INT_PINH, INPUT);      // sets the motion sensor digital pinH as input
      hwPinMode(PIR_INT_PINL, INPUT);      // sets the motion sensor digital pinL as input
      // do setup stuff like waiting for pir to settle, send states at init etc.
      sleep(PIR_SETTLE_TIME);
      // enable pin change interrupt to enable PIR/motion detection
      pirIntEnable();
    	present(CHILD_ID, S_MOTION);
      // irq ?
      if (irqPirHigh) {
        // We got a HIGH pulse on PIR pins!!
        // increment a pulse counter, etc.
        // test pulse counter then send or not
        send(msg.set("1"));
        irqPirHigh = false;
      else {
        // increment timer counters, to reset motion state etc
        // do stuff
      // Sleep until timer or a pin change interrupt
      sleep(SLEEP_TIME);
      Serial.println("Wake up!");
    Remember it detect pin change, so it will wake up at each pin change state.
    I can't make this example more noob and simple. then add all your variables for states, timers, improve power consumption etc, as you wish.
    Or, it's perhaps easier to use the example from carywinn above. he posted his sketch which use a lib to handle pinchange. (on my side I don't need a lib for this, and it also saves memory).
    I hope it's clear about pinchange, so I'm done at explaining it ;)
    alexsh1A 1 Reply Last reply
    • scalzS scalz
      @alexsh1
      ISR (PCINT1_vect)
          irqLight = false;
          irqLight = true;
      ISR (PCINT2_vect)
      Input   : -
      Output  : -
      Comments:
      void pirIntEnable()
      Input   : -
      Output  : -
      Comments:
      Input   : -
      Output  : -
      Comments:
      Input   : -
      Output  : -
      Comments:
      // #define MY_DEBUG
      ISR (PCINT2_vect)
           irqPirHigh = true;
      Comments:
      void pirIntEnable()
      Comments:
        Function: before
      void before()
        pirIntEnable();
        // irq ?
        if (irqPirHigh) {
          send(msg.set("1"));
          irqPirHigh = false;
        else {
          // do stuff
        sleep(SLEEP_TIME);
      alexsh1A
      alexsh1A
      alexsh1
      @scalz said in 💬 MyMultisensors:
      You are a star - I must admit that setting it up is a bit more fiddly. This is the first time I come across pinchange interrupts and excellent link you provided. Thank you
      • alexsh1A
        alexsh1A
        alexsh1
        Did anyone manage to find a good case for this sensor? Maybe 3D printed one?
        • dbemowskD
          dbemowskD
          I will gladly design a nice 3D printable case if someone can donate a board. I see that there are multiple battery options, so I would design a case that would fit all battery options.
          • dbemowskD dbemowsk
            alexsh1A
            alexsh1A
            alexsh1
            #152
            @dbemowsk Thanks for volunteering!
            I can probably order new boards (they come in batches of 3) from oshpark and send you one or two. They are 1.93 x 1.00 inch (49.0 x 25.4 mm).
            Unfortunately, the boards I have with CR2450 battery holders and these are extremely fragile to be posted (they are soldered to little pads may come off easily).
            • alexsh1A alexsh1
              alexsh1A
              alexsh1A
              alexsh1
              @scalz I did just notice that I have about 30-32uA sleep consumption, which is too high. This is very consistent through 3 sensors. Any ideas why I have such high consumption? Obviously, there is a chance my multimeter is not giving me correct reading, but so far my Brymen BM869S has been very much spot on!
                #154
                @alexsh1 looks weird, because there is nothing special on the board which could consumes like that, all parts are ultra low power..I tested mine with uCurrent gold device.
                so I would say if it's consistent on 3sensors boards, it could be:
                • software
                • bad caps, out of specs parts..(I usually order my parts at Mouser, arrow etc..)
                what do you get when using sketch J from gammon for example + shutdown sensors in case, no serial connected.
                alexsh1A 2 Replies Last reply
                • scalzS scalz
                  • software
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @scalz Sketch J is giving 1.5mA consumption.
                    #156
                    @alexsh1
                    so you get 1.5mA with sketch J but 35uA with your code ?? something is wrong..you may have forgotten to shutdown some peripherals.
                    with sketch J, you need to shutdown everything on your board in case peripherals are not well initialized. So that implies you include libs for radio etc in sketch J. Then disconnect your ftdi for power consumption tests. the PIR sensor itself won't consume more than 2-3uA, I tested it too.
                    On other side, sketch J is just a basic test, because almost same code is used in MySensors lib for sleep()
                    Sometimes I read people saying they have x uA power consumption for 328p standalone in deep sleep mode, but this is strange because here, on different 328p design, I have always been able to confirm the current consumption from the datasheet which is nA range. But I always used uCurrent..and reliable capa (X7R etc), hopefully I never got one capa extra leaking so far.
                    There is no magics, especially for this board, you should get what datasheets say..
                    When I made this board, I started by soldering only 328p circuit and checked power consumption, then tested step by step additional peripheral.
                    • scalzS scalz
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @scalz No, I copied and pasted sketch J so no radio peripherals included.
                      Strange that I have the same consumption on both boards - I think caps may be the reason! I'll try to desolder a few and test it again.
                        #158
                        @alexsh1
                        where did you source your passive parts like capa, especially the bigger like 100uF ? (for curiosity)
                        I guess you sourced others ic like opamp and comparator from a known source.
                        • scalzS scalz
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @scalz different sources - arrow.com for opamp.
                          For caps and resistors it is Aliexpress :))
                            #160
                            oki maybe try removing some of the big capa to see if it improves, use a simpler sketch where you just powerdown everything. there is no reason you don't get the low power consumption.
                            regarding sketch J, yes, for sure you got 1.5ma because others peripherals were not initialized/shutdown
                            • scalzS scalz
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @scalz I have desoldered all caps down to 1uF. Tried a different bootloader. However, I cannot get consumption down. I have opt3001 + atsha204a + AT25DF512C (all obtained from a good source). All resistor values are correct (resistor tolerance is 1%). Not sure what else I can do...
                              • scalzS scalz
                                alexsh1A
                                alexsh1A
                                alexsh1
                                #162
                                @scalz I managed to narrow down the problem. Consumption (no radio attached) with Si7021 and opt3001 is 4.8uA, but with flash it goes up to 29uA while sleeping. This is a batch of AT25DF512C-MAHN-T I received from the US so quality is not an issue here. Seems to me that flash is not sleeping?
                                My tests are showing that CJ2305 MOSFET consumption is negligible
                                • scalzS scalz
                                  • software
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #163
                                  • software
                                  @scalz
                                  Here we go - you said "software" and I tested SPIFlash lib modified by lowpowerlab and consumption has gone down to 15uA with flash onboard vs 30uA with Mysensors SPIFlash. For whatever season, the default MySensors SPIFlash (drivers\SPIFlash) is giving a higher consumption with flash.initialize() and flash.sleep(). @tbowmo Thomas, any ideas please?
                                  @scalz What lib are you using for flash to get such a low uA?
                                  tbowmoT 1 Reply Last reply
                                  • alexsh1A alexsh1
                                    • software
                                    @scalz
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @alexsh1
                                    It's been a while (a couple of years now) since I looked at the first sensebender micro.. (other than the data that they submit to my gateway :) )
                                    So I'm not entirely sure what is going on..
                                      #165
                                      @alexsh1
                                      yes the mosfet power consumption is negligeable (nA), else there would be a problem ;)
                                      I had to make some changes to get such low power, I agree (including spiflash lib you're right). actually i have too much work, rather 'lazy' and no time to sort my libs.sorry.
                                      Note: Spiflash lib from lowpowerlab (mysensors too i guess..) doesn't use the lowest power mode in sleep function.
                                      Does the sensebender micro have a spiflash too?? then that would explain some posts I read..
                                      As usual datasheets to the rescue, did you take a look? would have saved you time.
                                      Easy one, in datasheet you can read:
                                      • 200nA Ultra Deep Power Down current (Typical)
                                      • 5μA Deep Power-Down Current (Typical)
                                      • 25uA Standby current (Typical)
                                      • 4.5mA Active Read Current (Typical
                                      why don't you get this super low <uA ??
                                      section 12-5 of the datasheet is what you need, use the right opcode (command) which is 0x79 for ultra deep powerdown. create your own or tweak sleep function in lib
                                      So now you can save at least 5uA + (other sensors not optimized maybe) + multimeter imprecision
                                      I hope this helps!
                                      • scalzS scalz
                                        @alexsh1
                                        I hope this helps!
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #166
                                        @scalz Yes, sensebender micro does have flash and using spiflash from mysensors. I never managed to get it below 20uA in the deep sleep, but then I never looked into the libs. My sensebender micro is running from two AA batteries and 20uA is just fine. It does make difference though if running on a coin cell.
                                        When you say ultra deep power down, which mode are you referencing?
                                        There are six sleep modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby, and Extended Standby.
                                        The datasheet - yes, I am referencing to it from time to time. I guess I'll have to dive in if I want to get it sorted. I would need to get Ucurrent Gold or get one built to measure such a low current.
                                        EDIT: For CR2032 3uA would be a self-discharge current (1% a month)
                                        • tbowmoT tbowmo
                                          @alexsh1
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @tbowmo I meant SPIFlash lib
                                          scalzS 1 Reply Last reply
