  3. 💬 MyMultisensors
💬 MyMultisensors
328pmotionatsha204amulti sensorhumiditytemperaturepirambiant lightlow powercoincell
176 Posts 33 Posters 95.0k Views 35 Watching
  • alexsh1A alexsh1
    @scalz said in 💬 MyMultisensors:
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    You are a star - I must admit that setting it up is a bit more fiddly. This is the first time I come across pinchange interrupts and excellent link you provided. Thank you
    alexsh1A
    alexsh1A
    alexsh1
    @scalz I did just notice that I have about 30-32uA sleep consumption, which is too high. This is very consistent through 3 sensors. Any ideas why I have such high consumption? Obviously, there is a chance my multimeter is not giving me correct reading, but so far my Brymen BM869S has been very much spot on!
      #154
      @alexsh1 looks weird, because there is nothing special on the board which could consumes like that, all parts are ultra low power..I tested mine with uCurrent gold device.
      so I would say if it's consistent on 3sensors boards, it could be:
      • software
      • bad caps, out of specs parts..(I usually order my parts at Mouser, arrow etc..)
      what do you get when using sketch J from gammon for example + shutdown sensors in case, no serial connected.
      alexsh1A 2 Replies Last reply
      • scalzS scalz
        • software
        alexsh1A
        alexsh1A
        alexsh1
        @scalz Sketch J is giving 1.5mA consumption.
          #156
          @alexsh1
          so you get 1.5mA with sketch J but 35uA with your code ?? something is wrong..you may have forgotten to shutdown some peripherals.
          with sketch J, you need to shutdown everything on your board in case peripherals are not well initialized. So that implies you include libs for radio etc in sketch J. Then disconnect your ftdi for power consumption tests. the PIR sensor itself won't consume more than 2-3uA, I tested it too.
          On other side, sketch J is just a basic test, because almost same code is used in MySensors lib for sleep()
          Sometimes I read people saying they have x uA power consumption for 328p standalone in deep sleep mode, but this is strange because here, on different 328p design, I have always been able to confirm the current consumption from the datasheet which is nA range. But I always used uCurrent..and reliable capa (X7R etc), hopefully I never got one capa extra leaking so far.
          There is no magics, especially for this board, you should get what datasheets say..
          When I made this board, I started by soldering only 328p circuit and checked power consumption, then tested step by step additional peripheral.
          alexsh1A 1 Reply Last reply
          • scalzS scalz
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @scalz No, I copied and pasted sketch J so no radio peripherals included.
            Strange that I have the same consumption on both boards - I think caps may be the reason! I'll try to desolder a few and test it again.
              #158
              @alexsh1
              where did you source your passive parts like capa, especially the bigger like 100uF ? (for curiosity)
              I guess you sourced others ic like opamp and comparator from a known source.
              • scalzS scalz
                @alexsh1
                alexsh1A
                alexsh1A
                alexsh1
                @scalz different sources - arrow.com for opamp.
                For caps and resistors it is Aliexpress :))
                  #160
                  oki maybe try removing some of the big capa to see if it improves, use a simpler sketch where you just powerdown everything. there is no reason you don't get the low power consumption.
                  regarding sketch J, yes, for sure you got 1.5ma because others peripherals were not initialized/shutdown
                  • scalzS scalz
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @scalz I have desoldered all caps down to 1uF. Tried a different bootloader. However, I cannot get consumption down. I have opt3001 + atsha204a + AT25DF512C (all obtained from a good source). All resistor values are correct (resistor tolerance is 1%). Not sure what else I can do...
                    • scalzS scalz
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #162
                      @scalz I managed to narrow down the problem. Consumption (no radio attached) with Si7021 and opt3001 is 4.8uA, but with flash it goes up to 29uA while sleeping. This is a batch of AT25DF512C-MAHN-T I received from the US so quality is not an issue here. Seems to me that flash is not sleeping?
                      My tests are showing that CJ2305 MOSFET consumption is negligible
                      • scalzS scalz
                        • software
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #163
                        • software
                        @scalz
                        Here we go - you said "software" and I tested SPIFlash lib modified by lowpowerlab and consumption has gone down to 15uA with flash onboard vs 30uA with Mysensors SPIFlash. For whatever season, the default MySensors SPIFlash (drivers\SPIFlash) is giving a higher consumption with flash.initialize() and flash.sleep(). @tbowmo Thomas, any ideas please?
                        @scalz What lib are you using for flash to get such a low uA?
                        tbowmoT 1 Reply Last reply
                        • alexsh1A alexsh1
                          • software
                          @scalz
                          tbowmoT
                          tbowmoT
                          tbowmo
                          @alexsh1
                          It's been a while (a couple of years now) since I looked at the first sensebender micro.. (other than the data that they submit to my gateway :) )
                          So I'm not entirely sure what is going on..
                            #165
                            @alexsh1
                            yes the mosfet power consumption is negligeable (nA), else there would be a problem ;)
                            I had to make some changes to get such low power, I agree (including spiflash lib you're right). actually i have too much work, rather 'lazy' and no time to sort my libs.sorry.
                            Note: Spiflash lib from lowpowerlab (mysensors too i guess..) doesn't use the lowest power mode in sleep function.
                            Does the sensebender micro have a spiflash too?? then that would explain some posts I read..
                            As usual datasheets to the rescue, did you take a look? would have saved you time.
                            Easy one, in datasheet you can read:
                            • 200nA Ultra Deep Power Down current (Typical)
                            • 5μA Deep Power-Down Current (Typical)
                            • 25uA Standby current (Typical)
                            • 4.5mA Active Read Current (Typical
                            why don't you get this super low <uA ??
                            section 12-5 of the datasheet is what you need, use the right opcode (command) which is 0x79 for ultra deep powerdown. create your own or tweak sleep function in lib
                            So now you can save at least 5uA + (other sensors not optimized maybe) + multimeter imprecision
                            I hope this helps!
                            • scalzS scalz
                              @alexsh1
                              I hope this helps!
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #166
                              @scalz Yes, sensebender micro does have flash and using spiflash from mysensors. I never managed to get it below 20uA in the deep sleep, but then I never looked into the libs. My sensebender micro is running from two AA batteries and 20uA is just fine. It does make difference though if running on a coin cell.
                              When you say ultra deep power down, which mode are you referencing?
                              There are six sleep modes: Idle, ADC Noise Reduction, Power-save, Power-down, Standby, and Extended Standby.
                              The datasheet - yes, I am referencing to it from time to time. I guess I'll have to dive in if I want to get it sorted. I would need to get Ucurrent Gold or get one built to measure such a low current.
                              EDIT: For CR2032 3uA would be a self-discharge current (1% a month)
                              • tbowmoT tbowmo
                                @alexsh1
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @tbowmo I meant SPIFlash lib
                                scalzS 1 Reply Last reply
                                • alexsh1A alexsh1
                                  #168
                                  @alexsh1
                                  I'm not talking about the mcu sleep modes. I mentioned the spiflash sleep modes (or I don't get what you asked previously regarding spiflash..)
                                  datasheet see here, ic can go <uA, if you do what i said above, you'll get the better power consumption you want,
                                  https://www.adestotech.com/wp-content/uploads/DS-AT25DF512C_030.pdf
                                  • scalzS scalz
                                    @alexsh1
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @scalz Sorry, yes, I thought you were talking about mcu.
                                    No, I did not check the datasheet for the chip. Thanks for the link. I'll see what can be done to save some power here :v:
                                      #170
                                      oki, i think you now have the solution to what happened in your other post here ;)
                                      https://forum.mysensors.org/topic/6846/sensebender-micro-rfm69w-consumption/14
                                      • scalzS scalz
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @scalz Yes, I think I mentioned sensebender micro, didn't I?
                                        20+ uA is not too bad and given the power source is 2xAA, I never bothered to spend too much time troubleshooting it, but now things are different as I know what causes such high consumption.
                                        BTW - Sketch J in my case was giving me 1.5mA as radio was not sleeping.
                                        • scalzS scalz
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @scalz Voalá! 5.2uA consumption with flash in Ultra Deep Power-Down!
                                          Will have to test OTA functionality though (waking up from Ultra Deep Power-Down), but in my experience this is going to be very hard on a coin battery.
