  3. nRF5 action!
nRF5 action!
  • alowhumA
    alowhumA
    alowhum
    I received two new eByte modules. I can't even connect to either one, both with BMP or ST-Link V2. Very strange. I'm going to try not powering them from the USB stick but from a second 3.3v source.
    • alowhumA alowhum
      Toyman
      @alowhum did you manage to flash them?
      • alowhumA
        alowhumA
        alowhum
        #1579
        @toyman No. I don't understand what's going on, as I was able to flash one succesfully before. I did find [this a bit unnerving].(https://devzone.nordicsemi.com/f/nordic-q-a/19943/nrf52832-unable-to-connect-to-the-target).
        Could it be that the EByte chips need the DCDC stuff before they can be connected to? Or that the exact moment on power-on (reset) matters?
        One thing I have found is that I had installed OpenOCD on my laptop to turn a ST-Link V2 into a Black Magic Probe. That version of OpenOCD was overruling the hacked version that Sandeep Mistry had created for the NRF5.
        But even with that removed, the problem remains this:
        "TARGET: nrf52.cpu - Not halted".
        Apparently this is a sign that the chips are protected. I was able to remove that protection before (by selecting "Burn Bootloader"), but it doesn't work now.
        Nca78N 1 Reply Last reply
        • T Toyman
          #1580
          @alowhum said in nRF5 Bluetooth action!:
          No.
          • alowhumA alowhum
            @alowhum have you tried the menu item to write softdevice ? If I remember well it will unlock the chip and after that you will be allowed to write code to it.
            • O
              O
              Omemanti
              wrote on last edited by Omemanti
              #1582
              Hey,
              somehow I cant change the pins on my Ebyte module. Im trying to test with MockMysensors.
              I want te TX set to pin nr. P0.06
              I changed: MyBoardNRF.h and included nrf.h
              #define PIN_SERIAL_RX (8)
              #define PIN_SERIAL_TX (6)
              but somehow the TX pin stays P0.25.
              Can someone point me in the right direction?
              The node connects to the gateway, so thats also working.
              Seems like that if you put the MyBoardNRF5 files into the example map and you change some things in that file using the Arduino IDE, it doenst get uploaded. When I changed the MyBoardNRF5 file using Brackets it working as intended.
              • alowhumA
                alowhumA
                alowhum
                @Nca78 Thanks, but it didn't work either :-(
                Some notes from my adventures with the eByte module:
                I've been playing with OpenOCD and the ST-Link v2. The ST-Link V2 that I turned into a Black Magic Probe doesn't see the modules.
                I went into the Arduino's folder that has OpenOCD, created .cfg file, and then:
                ./openocd -d2 -f nrf52832.cfg
                This started the OpenOCD server. Then I opened another terminal window and did
                telnet localhost 4444
                Now I could manually issue some OpenOCD commands. The goal was to do a manual mass erase.
                Some OpenOCD commands and their output:
                flash probe 0        c Unknown device (HWID 0x00000000)
                > flash banks
                #0 : nrf52.flash (nrf51) at 0x00000000, size 0x00000000, buswidth 1, chipwidth 1
                #1 : nrf52.uicr (nrf51) at 0x10001000, size 0x00000000, buswidth 1, chipwidth 1
                > flash probe 1
                flash 'nrf51' found at 0x10001000
                > nrf51 mass_erase 0
                Target not halted
                This command actually resulted in OpenOCD ballooning to 8Gb in ram. Then after 5 minutes of seemingly being busy, I got the 'target not halted' command.
                > flash info 1
                #1 : nrf51 at 0x10001000, size 0x00000100, buswidth 1, chipwidth 1
                	#  0: 0x00000000 (0x100 0kB) not protected
                Target not halted
                error retrieving flash info
                Here is says "target not protected".
                > nrf52.cpu curstate
                reset
                Weird: the processor says it is in reset state? Could it be that it is not so much protected, but that it is constantly being reset? But then why is this with all the chips?
                Once the OpenOCD server is running I also tried getting into the chip with
                telnet localhost 3333
                But then I get "Error: attempted 'gdb' connection rejected"
                The OpenOCD documentation mentions the chip protection:
                Flash Driver: nrf5
                All members of the nRF51 microcontroller families from Nordic Semiconductor include internal flash and use ARM Cortex-M0 core. Also, the nRF52832 microcontroller from Nordic Semiconductor, which include internal flash and use an ARM Cortex-M4F core.
                flash bank $_FLASHNAME nrf5 0 0x00000000 0 0 $_TARGETNAME
                Some nrf5-specific commands are defined:
                Command: nrf5 mass_erase
                Erases the contents of the code memory and user information configuration registers as well. It must be noted that this command works only for chips that do not have factory pre-programmed region 0 code.
                http://www.openocd.org/doc/html/Flash-Commands.html
                I also got out my voltmeter. Pin 21 and pin 25 have 3v on them, the rest don't.
                YveauxY T M 3 Replies Last reply
                  maciekczwa
                  I have the same problem with brand news ebyte modeules.
                  Here are my openocd logs:
                  Open On-Chip Debugger 0.10.0-dev-gdc53227 (2016-04-09-13:45)
                  Licensed under GNU GPL v2
                  For bug reports, read
                  debug_level: 2
                  0x4000
                  adapter speed: 10000 kHz
                  Info : clock speed 4000 kHz
                  Info : using stlink api v2
                  in procedure 'program'
                  in procedure 'reset' called at file "embedded:startup.tcl", line 478
                  in procedure 'ocd_bouncer'
                  embedded:startup.tcl:454: Error: ** Unable to reset target **
                  in procedure 'program_error' called at file "embedded:startup.tcl", line 479
                  wybrany port szeregowy at file "embedded:startup.tcl", line 454
                  nie istnieje albo Twoja płytka nie jest podłączona
                  O 1 Reply Last reply
                  • alowhumA alowhum
                    > flash banks
                    > flash probe 1
                    > nrf51 mass_erase 0
                    Target not halted
                    > flash info 1
                    Target not halted
                    > nrf52.cpu curstate
                    reset
                    Flash Driver: nrf5
                    @alowhum I'm not in sync with the whole thread , but I had similar issues when I had an FTDI adapter connected with @NeverDie 's breakout.
                    As soon as I disconnected the DTR (reset) line the thing started to work!
                    Not sure if this is related to your issue, but it's worth a try.
                    • alowhumA alowhum
                      > flash banks
                      > flash probe 1
                      > nrf51 mass_erase 0
                      Target not halted
                      > flash info 1
                      Target not halted
                      > nrf52.cpu curstate
                      reset
                      Flash Driver: nrf5
                      Toyman
                      wrote on last edited by Toyman
                      #1586
                      @alowhum I intentionally asked you because I know the problem exists.
                      You need to erase the chip via Jlink Commander. Neither nrfjprog nor anything alse will work (AFAIK)
                      Actually, it was @NeverDie who found it in the beginning of his quest with nrf52. "The thing that started it all" (c)
                      Mars WarriorM 1 Reply Last reply
                      • T
                        Toyman
                        #1587
                        another method (although I haven't tried it with Ebyte) is to use BMP with GDB and issue a "erase mass" command
                        • O
                          O
                          Omemanti
                          Is there a way to enhance the sending performance of the Ebyte units?
                          I got a gateway that's sitting upstairs when I connect an Ebyte module I must be right underneath the gateway to let it receive packages.
                          When I do exactly the same same thing with an NRF52832-DK It doesn't matter where I'm standing, every message is received by the gateway.
                          • O Omemanti
                            #1589
                            @omemanti said in nRF5 Bluetooth action!:
                            @omemanti Maybe by using a properly tuned external antenna? At least for the built-in antenna's, the Fanstel modules seem to have more effective Tx reach than the Ebyte modules do. That's a major reason for my switch from the Ebyte's to the Fanstel's.
                              O
                              O
                              Omemanti
                              #1590
                              @neverdie, I did some digging and cut a part of my PCB that was grounded. range drastically increased, guess I need to order a new prototype :)
                              • O Omemanti
                                @omemanti Ah, that makes sense. That's why on my PCB's I have the antenna portion of the module hanging over the edge of the PCB into empty space.
                                  O
                                  O
                                  Omemanti
                                  @neverdie said in nRF5 Bluetooth action!:
                                  yeah, next one will be a big hole in the middle, lets see how that will work out..
                                  • O Omemanti
                                    Interesting board !
                                    But module in the middle is a bad idea, even with a big hole below the antenna it will affect performance to still have some PCB around
                                    For example here is an extract of the Fanstel BT832 module datasheet. It's not the same antenna design but it show having the antenna sticking out is the best solution, else you should but as close as possible to the edge and of course keep ground plane and traces as far as possible.
                                    • Nca78N Nca78
                                      Interesting board !
                                      O
                                      O
                                      Omemanti
                                      #1594
                                      @nca78 I'm trying to create a node that fits inside a standard wallsocket. (I'll post it when it's done) it got a motion and moisture sensor.
                                      For the next version I'm moving the module more to the outside but I need to take the screwholes into account.
                                      The groundplane I used filled the entire PCB, next one will have less ground around the antenna or even holes.
                                      It's designed to hold 3 AA batteries to have a couple years of service.
                                      But cutting away that spot around the antenna gave me reception throughout the entire house
                                      • alowhumA alowhum
                                        > flash banks
                                        > flash probe 1
                                        > nrf51 mass_erase 0
                                        Target not halted
                                        > flash info 1
                                        Target not halted
                                        > nrf52.cpu curstate
                                        reset
                                        Flash Driver: nrf5
                                        maciekczwa
                                        wrote on last edited by maciekczwa
                                        #1595
                                        @alowhum
                                        Hi I managed to clear the access protection.
                                        I connected ebyte module directly to raspberry pi.
                                        I used this guide http://hivetool.org/w/index.php?title=BMD301 with little modifications
                                        Compiled openocd - current version - 7b94ae9e520877e7f2341b48b3bd0c0d1ca8a14b
                                        Added chip definition - I don't know if it is needed, I can check that - I have more modules to unlock
                                        diff --git a/src/flash/nor/nrf5.c b/src/flash/nor/nrf5.c
                                        index 31dd5aae..e01d7ddf 100644
                                        --- a/src/flash/nor/nrf5.c
                                        +++ b/src/flash/nor/nrf5.c
                                        @@ -204,6 +204,7 @@ static const struct nrf5_device_spec nrf5_known_devices_table[] = {
                                         	/* nRF52832 Devices */
                                         	NRF5_DEVICE_DEF(0x00C7, "52832", "QFAA", "B0",    512),
                                        +	NRF5_DEVICE_DEF(0x00C7, "52832", "QFN48", "B00",    512),
                                         static int nrf5_bank_is_probed(struct flash_bank *bank)
                                        Started openocd:
                                        openocd -f interface/raspberrypi-native.cfg -c "transport select swd; set WORKAREASIZE 0" -f target/nrf52.cfg
                                        Connected with telnet to port 4444
                                        Commands:
                                        nrf52.dap apreg 1 0x0c
                                        nrf52.dap apreg 1 0x04 0x01
                                        reset
                                        I tried also with st-link but I think it doesn't support dap commands? Can anyone confirm that?
                                        After clearing access protection I am able to successfully flash chip with st-link.
                                        Now it shows in logs:
                                        Info : nrf52.cpu: hardware has 6 breakpoints, 4 watchpoints
                                        Before it was:
                                        Good luck with unlocking your modules:)
                                        • alowhumA
                                          alowhumA
                                          alowhum
                                          @maciekczwa said in nRF5 Bluetooth action!:
                                          Thanks for the tip! Unfortunately ST-Link V2 gives:
                                          invalid command name "nrf52.dap"
                                          (same with just "dap", which I had tried earlier).
