  3. nRF5 action!
nRF5 action!
    140$ it is quite expensive compared with a simple small oven
    https://www.youtube.com/watch?v=mjfnpjvw9jY
    Toyman
    @gohan I am not telling you to buy this. Just a direction.
    I've created a PID sous vide machine. It's relatively easy project. SMD oven is absolutely the same. All you need is Arduino, thermoprobe and a relay.
    • alowhumA
      alowhumA
      alowhum
      Quick question: when programming the eByte module (or any module really):
      Should I select "reset enable or not? What does that do exactly?
      Should I select clock: "Crystal oscillator" for the eByte module?
      • alowhumA alowhum
        @alowhum "Reset enable" determines whether pin21 acts as a reset pin or not.
        • alowhumA alowhum
          #1576
          @alowhum IIRC, the crystal oscillator is only required by Bluetooth. For everything else, the internal resonator is sufficient.
          S 1 Reply Last reply
          • alowhumA
            alowhumA
            alowhum
            I received two new eByte modules. I can't even connect to either one, both with BMP or ST-Link V2. Very strange. I'm going to try not powering them from the USB stick but from a second 3.3v source.
            • alowhumA alowhum
              Toyman
              @alowhum did you manage to flash them?
              • alowhumA
                alowhumA
                alowhum
                #1579
                @toyman No. I don't understand what's going on, as I was able to flash one succesfully before. I did find [this a bit unnerving].(https://devzone.nordicsemi.com/f/nordic-q-a/19943/nrf52832-unable-to-connect-to-the-target).
                Could it be that the EByte chips need the DCDC stuff before they can be connected to? Or that the exact moment on power-on (reset) matters?
                One thing I have found is that I had installed OpenOCD on my laptop to turn a ST-Link V2 into a Black Magic Probe. That version of OpenOCD was overruling the hacked version that Sandeep Mistry had created for the NRF5.
                But even with that removed, the problem remains this:
                "TARGET: nrf52.cpu - Not halted".
                Apparently this is a sign that the chips are protected. I was able to remove that protection before (by selecting "Burn Bootloader"), but it doesn't work now.
                Nca78N 1 Reply Last reply
                • T Toyman
                  #1580
                  @alowhum said in nRF5 Bluetooth action!:
                  No.
                  • alowhumA alowhum
                    @alowhum have you tried the menu item to write softdevice ? If I remember well it will unlock the chip and after that you will be allowed to write code to it.
                    • O
                      O
                      Omemanti
                      wrote on last edited by Omemanti
                      #1582
                      Hey,
                      somehow I cant change the pins on my Ebyte module. Im trying to test with MockMysensors.
                      I want te TX set to pin nr. P0.06
                      I changed: MyBoardNRF.h and included nrf.h
                      #define PIN_SERIAL_RX (8)
                      #define PIN_SERIAL_TX (6)
                      but somehow the TX pin stays P0.25.
                      Can someone point me in the right direction?
                      The node connects to the gateway, so thats also working.
                      Seems like that if you put the MyBoardNRF5 files into the example map and you change some things in that file using the Arduino IDE, it doenst get uploaded. When I changed the MyBoardNRF5 file using Brackets it working as intended.
                      • alowhumA
                        alowhumA
                        alowhum
                        @Nca78 Thanks, but it didn't work either :-(
                        Some notes from my adventures with the eByte module:
                        I've been playing with OpenOCD and the ST-Link v2. The ST-Link V2 that I turned into a Black Magic Probe doesn't see the modules.
                        I went into the Arduino's folder that has OpenOCD, created .cfg file, and then:
                        ./openocd -d2 -f nrf52832.cfg
                        This started the OpenOCD server. Then I opened another terminal window and did
                        telnet localhost 4444
                        Now I could manually issue some OpenOCD commands. The goal was to do a manual mass erase.
                        Some OpenOCD commands and their output:
                        flash probe 0        c Unknown device (HWID 0x00000000)
                        > flash banks
                        #0 : nrf52.flash (nrf51) at 0x00000000, size 0x00000000, buswidth 1, chipwidth 1
                        #1 : nrf52.uicr (nrf51) at 0x10001000, size 0x00000000, buswidth 1, chipwidth 1
                        > flash probe 1
                        flash 'nrf51' found at 0x10001000
                        > nrf51 mass_erase 0
                        Target not halted
                        This command actually resulted in OpenOCD ballooning to 8Gb in ram. Then after 5 minutes of seemingly being busy, I got the 'target not halted' command.
                        > flash info 1
                        #1 : nrf51 at 0x10001000, size 0x00000100, buswidth 1, chipwidth 1
                        	#  0: 0x00000000 (0x100 0kB) not protected
                        Target not halted
                        error retrieving flash info
                        Here is says "target not protected".
                        > nrf52.cpu curstate
                        reset
                        Weird: the processor says it is in reset state? Could it be that it is not so much protected, but that it is constantly being reset? But then why is this with all the chips?
                        Once the OpenOCD server is running I also tried getting into the chip with
                        telnet localhost 3333
                        But then I get "Error: attempted 'gdb' connection rejected"
                        The OpenOCD documentation mentions the chip protection:
                        Flash Driver: nrf5
                        All members of the nRF51 microcontroller families from Nordic Semiconductor include internal flash and use ARM Cortex-M0 core. Also, the nRF52832 microcontroller from Nordic Semiconductor, which include internal flash and use an ARM Cortex-M4F core.
                        flash bank $_FLASHNAME nrf5 0 0x00000000 0 0 $_TARGETNAME
                        Some nrf5-specific commands are defined:
                        Command: nrf5 mass_erase
                        Erases the contents of the code memory and user information configuration registers as well. It must be noted that this command works only for chips that do not have factory pre-programmed region 0 code.
                        http://www.openocd.org/doc/html/Flash-Commands.html
                        I also got out my voltmeter. Pin 21 and pin 25 have 3v on them, the rest don't.
                        YveauxY T M 3 Replies Last reply
                          maciekczwa
                          I have the same problem with brand news ebyte modeules.
                          Here are my openocd logs:
                          Open On-Chip Debugger 0.10.0-dev-gdc53227 (2016-04-09-13:45)
                          Licensed under GNU GPL v2
                          For bug reports, read
                          debug_level: 2
                          0x4000
                          adapter speed: 10000 kHz
                          Info : clock speed 4000 kHz
                          Info : using stlink api v2
                          in procedure 'program'
                          in procedure 'reset' called at file "embedded:startup.tcl", line 478
                          in procedure 'ocd_bouncer'
                          embedded:startup.tcl:454: Error: ** Unable to reset target **
                          in procedure 'program_error' called at file "embedded:startup.tcl", line 479
                          wybrany port szeregowy at file "embedded:startup.tcl", line 454
                          nie istnieje albo Twoja płytka nie jest podłączona
                          O 1 Reply Last reply
                          • alowhumA alowhum
                            > flash banks
                            > flash probe 1
                            > nrf51 mass_erase 0
                            Target not halted
                            > flash info 1
                            Target not halted
                            > nrf52.cpu curstate
                            reset
                            Flash Driver: nrf5
                            @alowhum I'm not in sync with the whole thread , but I had similar issues when I had an FTDI adapter connected with @NeverDie 's breakout.
                            As soon as I disconnected the DTR (reset) line the thing started to work!
                            Not sure if this is related to your issue, but it's worth a try.
                            • alowhumA alowhum
                              > flash banks
                              > flash probe 1
                              > nrf51 mass_erase 0
                              Target not halted
                              > flash info 1
                              Target not halted
                              > nrf52.cpu curstate
                              reset
                              Flash Driver: nrf5
                              Toyman
                              wrote on last edited by Toyman
                              #1586
                              @alowhum I intentionally asked you because I know the problem exists.
                              You need to erase the chip via Jlink Commander. Neither nrfjprog nor anything alse will work (AFAIK)
                              Actually, it was @NeverDie who found it in the beginning of his quest with nrf52. "The thing that started it all" (c)
                              Mars WarriorM 1 Reply Last reply
                              • T
                                Toyman
                                #1587
                                another method (although I haven't tried it with Ebyte) is to use BMP with GDB and issue a "erase mass" command
                                • O
                                  O
                                  Omemanti
                                  Is there a way to enhance the sending performance of the Ebyte units?
                                  I got a gateway that's sitting upstairs when I connect an Ebyte module I must be right underneath the gateway to let it receive packages.
                                  When I do exactly the same same thing with an NRF52832-DK It doesn't matter where I'm standing, every message is received by the gateway.
                                  • O Omemanti
                                    #1589
                                    @omemanti said in nRF5 Bluetooth action!:
                                    @omemanti Maybe by using a properly tuned external antenna? At least for the built-in antenna's, the Fanstel modules seem to have more effective Tx reach than the Ebyte modules do. That's a major reason for my switch from the Ebyte's to the Fanstel's.
                                      O
                                      O
                                      Omemanti
                                      #1590
                                      @neverdie, I did some digging and cut a part of my PCB that was grounded. range drastically increased, guess I need to order a new prototype :)
                                      • O Omemanti
                                        @omemanti Ah, that makes sense. That's why on my PCB's I have the antenna portion of the module hanging over the edge of the PCB into empty space.
                                          O
                                          O
                                          Omemanti
                                          @neverdie said in nRF5 Bluetooth action!:
                                          yeah, next one will be a big hole in the middle, lets see how that will work out..
