  3. nRF5 action!
nRF5 action!
    I dropped "Bluetooth" from the title of this thread because the thread instead evolved into the MySensors alternative to Bluetooth.
    • alowhumA
      alowhumA
      alowhum
      How hard, or how much work, would it be to create a version of the MySensors gateway that works on one of those dongles?
      • alowhumA alowhum
        Toyman
        @alowhum my understaning, it should work out of the box
        • alowhumA
          alowhumA
          alowhum
          Really? So something like:
          • Upload gateway sketch to it (how?)
          • Select "serial connection" in Domoticz?
          • alowhumA alowhum
            @alowhum You'd still need a programmer
              Toyman
              @neverdie ...and some nifty soldering skills in order to connect to SWDIO/SWDCLK pads
                i don't think you need extraordinary soldering skills, pads on bottom looks easy ;) (pretty sure these are the programming pads)
                The right question, imho, would be: can you expect from this dongle the range you would expect from a gateway ?? regarding chip antenna performance and maybe its gnd counterpoise..
                T JokgiJ 2 Replies Last reply
                • scalzS scalz
                  Toyman
                  @scalz said in nRF5 action!:
                  they are even "labeled" on the x-ray picture below
                    #1633
                    @Toyman yep, this confirms what i said, not difficult to access.
                    I didn't read the description..just looking at the pcb layout was enough to tell me poor rf range + no basic usb spec design rules (latter point is maybe not the most critical for most of people, but it just shows 1) designer wasn't aware ?? 2) this is what you get for cheap money, whereas missing parts would have cost few cents..).
                    Just saying, because maybe this dongle can work well enough for some people.
                    • scalzS scalz
                      Toyman
                      @scalz actually, it might be ideal as a REPEATER given the form-factor. You just insertt it into any cheap USB charger and voila.
                        @Toyman that's a valid point, sure. Here, I prefer to not have repeater as much as i can, else i switch to subghz ;)
                          Looks as though there is also a new DK for the nRF52840 as well:
                          https://www.digikey.com/product-detail/en/nordic-semiconductor-asa/NRF52840-DK/1490-1072-ND/8593726
                          just not in stock.
                          Looks like HolyIOT is ahead of the curve on this chip.
                          JokgiJ
                          JokgiJ
                          Jokgi
                          • JokgiJ Jokgi
                            [[topic:post-is-deleted]]
                            @jokgi said in nRF5 action!:
                            @neverdie I would suggest holding off on purchasing a new nRF52840-PDK until the final silicon is released.
                            Oh! It's still not?
                            • scalzS scalz
                              JokgiJ
                              JokgiJ
                              Jokgi
                              wrote on last edited by Jokgi
                              #1638
                              I would be interested in any range testing in regard to this dongle. For ground it has whatever it is that it is plugged into. (PC, SBC, USB extention cable, etc) There will be a nRF52840 based dongle out soon. See picture above. This dongle will need to be programed over the SWD lines. No Segger on board this one..!
                              U 1 Reply Last reply
                                #1639
                                @Jokgi i'm not using usb dongle but it looks nice. (too bad 52840 is AQFN..)
                                • O
                                  O
                                  Omemanti
                                  Getting rid of the ground plains around the entire module hugely improved the range. Had to stap back to AAA batteries to fit on the board. But I'm happy with the way it's going (AA is still possible but not soldered on it just doesn't fit enough in the wall socket)
                                    Very nice. Looks professional!
                                    • T
                                      Toyman
                                      Very nice indeed. I thought ground plains improve the range
                                      Nca78N gohanG 2 Replies Last reply
                                      • T Toyman
                                        @toyman said in nRF5 action!:
                                        He's talking about the ground plane around the nrf5 module, not on the full board ;)
                                        • T Toyman
                                          @toyman they do, but not too close to the antenna 😀
