  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • Nca78N Nca78
    @alowhum said in nRF5 Bluetooth action!:
    @nca78 said in nRF5 Bluetooth action!:
    https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
    Cool!
    If you buy one, buy the "black" version, it's a bit bigger but it's because it has a PCB antenna, range will be better.
    Toyman
    @nca78 I don't recognize any LDO on the PCB while it has USB power supply. How is 5V converted to 3.3v?
    alowhumA 1 Reply Last reply
    • T Toyman
      alowhumA
      alowhumA
      alowhum
      @toyman said in nRF5 Bluetooth action!:
      I was wondering the exact same thing!
      Nca78N 1 Reply Last reply
        small internal dcdc converter
        • alowhumA alowhum
          Look at bottom of page 6 and top left of "schematic" on page 9 of the CP2104 datasheet. It can supply up to 100mA.
          https://www.silabs.com/documents/public/data-sheets/cp2104.pdf
            Can someone please provide a link to the module being discussed? I tried looking on Aliexpress, and I don't see anything which matches.
              wrote on last edited by Nca78
              #1621
              @neverdie it's this link, in the description on aliexpress you can see the internal PCB "module"
              T NeverDieN 2 Replies Last reply
              • Nca78N Nca78
                Toyman
                @nca78 Got it. So it's kinda Arduino Nano, but nrf52-based.
                • Nca78N Nca78
                  https://www.digikey.com/product-detail/en/tag-connect-llc/TC2030-CLIP/TC2030-CLIP-ND/2605371
                  ? Plug of nails?
                    ? Plug of nails?
                    Toyman
                    @neverdie https://www.aliexpress.com/store/product/Nordic-nRF52832-BLE-4-0-4-2-5-0-USB-UART-BLE-dongle-for-computer/420533_32862480389.html
                      I dropped "Bluetooth" from the title of this thread because the thread instead evolved into the MySensors alternative to Bluetooth.
                      • alowhumA
                        alowhumA
                        alowhum
                        How hard, or how much work, would it be to create a version of the MySensors gateway that works on one of those dongles?
                        • alowhumA alowhum
                          Toyman
                          @alowhum my understaning, it should work out of the box
                          • alowhumA
                            alowhumA
                            alowhum
                            Really? So something like:
                            • Upload gateway sketch to it (how?)
                            • Select "serial connection" in Domoticz?
                            • alowhumA alowhum
                              @alowhum You'd still need a programmer
                                Toyman
                                @neverdie ...and some nifty soldering skills in order to connect to SWDIO/SWDCLK pads
                                  i don't think you need extraordinary soldering skills, pads on bottom looks easy ;) (pretty sure these are the programming pads)
                                  The right question, imho, would be: can you expect from this dongle the range you would expect from a gateway ?? regarding chip antenna performance and maybe its gnd counterpoise..
                                  T JokgiJ 2 Replies Last reply
                                  • scalzS scalz
                                    Toyman
                                    @scalz said in nRF5 action!:
                                    they are even "labeled" on the x-ray picture below
                                      #1633
                                      @Toyman yep, this confirms what i said, not difficult to access.
                                      I didn't read the description..just looking at the pcb layout was enough to tell me poor rf range + no basic usb spec design rules (latter point is maybe not the most critical for most of people, but it just shows 1) designer wasn't aware ?? 2) this is what you get for cheap money, whereas missing parts would have cost few cents..).
                                      Just saying, because maybe this dongle can work well enough for some people.
                                      • scalzS scalz
                                        Toyman
                                        @scalz actually, it might be ideal as a REPEATER given the form-factor. You just insertt it into any cheap USB charger and voila.
                                          @Toyman that's a valid point, sure. Here, I prefer to not have repeater as much as i can, else i switch to subghz ;)
