nRF5 action!
@jokgi said in nRF5 action!:
@neverdie I would suggest holding off on purchasing a new nRF52840-PDK until the final silicon is released.
Oh! It's still not?
i don't think you need extraordinary soldering skills, pads on bottom looks easy ;) (pretty sure these are the programming pads)
The right question, imho, would be: can you expect from this dongle the range you would expect from a gateway ?? regarding chip antenna performance and maybe its gnd counterpoise..
@scalz
I would be interested in any range testing in regard to this dongle. For ground it has whatever it is that it is plugged into. (PC, SBC, USB extention cable, etc) There will be a nRF52840 based dongle out soon. See picture above. This dongle will need to be programed over the SWD lines. No Segger on board this one..! -
@Nca78
Getting rid of the ground plains around the entire module hugely improved the range. Had to stap back to AAA batteries to fit on the board. But I'm happy with the way it's going (AA is still possible but not soldered on it just doesn't fit enough in the wall socket) -
Very nice. Looks professional!
@toyman said in nRF5 action!:
Very nice indeed. I thought ground plains improve the range
He's talking about the ground plane around the nrf5 module, not on the full board ;)
I didn't have good enough technique dispensing manually directly from a solder paste syringe,
what did you have issues with?
It was very hard to extrude it, so I always seemed to either underextrude or overstrude. I found it very hard to get the right amount exactly where it should go by just manually pressing the plunger on the solder paste syringe that the material came in.
What about moving the PID-related discussion to a dedicated thread as this one is already excessively long and useful information will get lost soon ?
Yes I had the same problem too... added with too old solder paste from my local shop :(
I just ordered a stencil together with my test PCB, I guess it's the way to go given the now very low prices of stencils (mini-stencils at 9.9$ at Seeed and I just paid 7$ + 2$ PCB at JLCPCB, same company than EasyEDA). -
@gohan said in nRF5 action!:
I think we should open a dedicated thread about smd
We had the same idea at the same time.
I moved the related posts here => https://forum.mysensors.org/topic/9412/smd-reflow-oven-pidNot sure the title is the best, feel free to suggest a better one in the other thread :)
Hello guys. Finally I've got some nrf51288 boards, like used here: https://www.openhardware.io/view/510/Button-cell-Temperature-Humidity-sensor I've hooked it up to ST Link, uploaded test sketch and everything worked fine. Then I tried to put it to sleep and measure power consumption. The best number I'm getting is 550uA... And it seems like something is completely wrong with this. Either my readings, or some bug in new version of Mysensors library or nrf5 arduino core.
To be sure it's not particular chip's bug I've checked both I've got, no differences. I've also checked current on stock BLE firmware from manufacturer it was running when they came. It was around 120uA - 200uA while presenting via bluetooth. So I guess it can't be that my readings are completely wrong. But then how can it be that bluetooth presenting consume less current than sleeping?
For now I couldn't find a solution or any hint for this, so I apologize If I am missing something, but I need help.EDIT: I might just delete this post, but maybe someone will search for the same solution. Long story short 600uA extra is due to the lack of low frequency crystal onboard. It makes HFCLK to not shutdown and draws current during a sleep. I knew, that synth RTC will take more current but I didn't expect it to be that much.
Another question is why sleep that depends on pin change and seems doesn't require RTC consumes 1ma? I'm confused... -
To summarize, what I have for now.
Plain mysensors sketch with empty loop consumes - 16.6mA
The same sketch with
sleep(60000);in loop - 95-100uA -
pinMode(10, INPUT_PULLUP);andsleep(10, FALLING, 0);- 1mA -
The sketch based on Nordicsemi example from here https://github.com/NordicPlayground/nrf51-powerdown-examples/blob/master/system_on_wakeup_on_gpio/main.c
void setup() { NRF_GPIO->PIN_CNF[10] = ((uint32_t)GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos) | ((uint32_t)GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) | ((uint32_t)GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Pos) | ((uint32_t)GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) | ((uint32_t)GPIO_PIN_CNF_SENSE_Low << GPIO_PIN_CNF_SENSE_Pos); NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Msk; NVIC_EnableIRQ(GPIOTE_IRQn); delay(2000); NRF_RTC1->TASKS_STOP = 1; } void loop() { NRF_RADIO->TASKS_DISABLE = 1; NRF_CLOCK->TASKS_HFCLKSTOP = 1; __WFE(); __SEV(); __WFE(); } void GPIOTE_IRQHandler(void) { // This handler will be run after wakeup from system ON (GPIO wakeup) if (NRF_GPIOTE->EVENTS_PORT) { NRF_GPIOTE->EVENTS_PORT = 0; } }While
delay(2000);consumes 4mA, after stopping RTC and HFCLK and going to sleep as expected consumes less than 10uA (my meter can't read less than that so it shows just 0).- The same code adapted for use with mysensors library:
#define MY_RADIO_NRF5_ESB #include <MySensors.h> void setup() { NRF_GPIO->PIN_CNF[10] = ((uint32_t)GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos) | ((uint32_t)GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) | ((uint32_t)GPIO_PIN_CNF_PULL_Pullup << GPIO_PIN_CNF_PULL_Pos) | ((uint32_t)GPIO_PIN_CNF_DRIVE_S0S1 << GPIO_PIN_CNF_DRIVE_Pos) | ((uint32_t)GPIO_PIN_CNF_SENSE_Low << GPIO_PIN_CNF_SENSE_Pos); NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_PORT_Msk; NVIC_EnableIRQ(GPIOTE_IRQn); } void loop() { transportDisable(); NRF_POWER->TASKS_LOWPWR = 1; NRF_RTC1->TASKS_STOP = 1; MY_HW_RTC->POWER = 0; MY_HW_RTC->INTENCLR = RTC_INTENSET_COMPARE0_Msk; MY_HW_RTC->EVTENCLR = RTC_EVTENSET_COMPARE0_Msk; NRF_ADC->TASKS_STOP = 1; NRF_ADC->ENABLE = 0; NRF_CLOCK->TASKS_HFCLKSTOP = 1; NRF_UART0->TASKS_STOPRX = 1; NRF_UART0->TASKS_STOPTX = 1; NRF_UART0->TASKS_SUSPEND = 1; __WFE(); __SEV(); __WFE(); } void GPIOTE_IRQHandler(void) { // This handler will be run after wakeup from system ON (GPIO wakeup) if (NRF_GPIOTE->EVENTS_PORT) { NRF_GPIOTE->EVENTS_PORT = 0; } }I know that this code is wrong, as it doesn't enable peripherals after wake up, and it I just took chunks of code from different places trying to disable whatever is running by mysensors and consumes that extra current. So in sleep this code consumes 200-230uA.
All is running on WT15822 board like this:
It doesn't have 32KHz crystal, but I program it using "Crystal Oscillator" from board menu of nrf5 arduino core.
As far as I understand some of the periferals and/or interrupts and/or timers is used by Mysensors stack and doesn't shut down when going to sleep, so it tries to use RTC, which is not available, so it wokes HFCLK, so it consumes extra current. A lot more than it should in sleep mode.I need help with this, as I am planning to build a bucnh of simple window sensors on this board and they doesn't require wake by timer, but will be woken by extrnal pin interrupt. But for now I just can't use Mysensors sleep function to do this, because as I have described it works not as expected. Hope to get some response from you guys.
Great work @monte, thanks for sharing.
Just to set your expectations correctly: Very few MySensors users have tried nrf5 so far, so the combined experience is quite low. Hopefully someone has an idea on how to help you, but it could very well be that you're the community's most experienced user in this area thanks to your work.
Another question is why sleep that depends on pin change and seems doesn't require RTC consumes 1ma? I'm confused...@monte thé HFCLK is on because of a hardware bug in nrf51822 when you want to wake up using pin interrupt. You have to use PORT interrupt to go really low (around 5uA).
I made some (dirty) test code to validate that with MySensors but there was not much interest in that in the forum so I switched to something else. I will not use nrf51822 but nrf52832/40, they became really cheap now and don't have this hardware bug.
@nca78 By the way, were you ever able to get multiple different interrupts working?
Here we are a year later, and I guess there's still no final silicon for the nRF52840?
@neverdie it works with the code I posted.
There are a few modules available with nrf52840 now so I guess final silicon is out. But it's only available in WCSP format I think so you won't see the chip alone.
@nca78 The Rev C (COO) parts are available now and they are the production parts. (Symmetry and Nordic's other distributors have these in stock) There will be a respin of this to a Rev D to fix the REG0 issue. FYI, the current nRF52840 package is not a WCSP. It is a aQFN™ package. The nRF52840-Dongle is also available now. Go forth and design......
@nca78 well, after 2 nights of intense trying and failing I've got code to work as expected. And yes, it works with PORT interrupt, its kinda more code for you to write in compare to simply using attachInterrupt function, but I'm okay with that. For me double the price of 52832 compared to 51822 is significant. And for now, for a simple sensor stuff as we do with mysensors I don't really see any advantages except that interrupt bug fixed.
Also I've found that Mysensors sleep function for nrf5 is missing one very important command, I don't know why, maybe it is nrf51822 specific and thus @d00616 missed it but in current version of Mysensors library it doesn't disable UART before sleep, that's why I was getting 120-200uA current during sleep. I still don't really know how to make pull requests on github, so I guess I will just post it here:
line 290 of MyHwNRF5.cpp should contain:NRF_UART0->ENABLE=0;and line 327:NRF_UART0->ENABLE=1;respectively. That completely disables UART on nrf51822.
I will post my complete sketch later, when I will finish it, maybe someone who strugles as I did will find it useful. Also I think we need to somehow combine all examples that were posted in this thread or at least put a list of them with links, because looking through 1654 posts is not an easy task, especially if you not sure what you are looking for exactly. -
I will post my complete sketch later, when I will finish it, maybe someone who strugles as I did will find it useful. Also I think we need to somehow combine all examples that were posted in this thread or at least put a list of them with links, because looking through 1654 posts is not an easy task, especially if you not sure what you are looking for exactly.@monte But you solve your issue with the WT15822 board? Can you please share your sketch?
Is the range good of the WT15822 board?
I have started sketching to create a couple of new simple temp / hum sensors (WT15822, si7021 and cr2032) and want to know if I can use WT15822 before I order a pcb :)
