  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.4k Views 25 Watching
  • MiKaM MiKa
    Please link for enclosure
    KoreshK
    KoreshK
    Koresh
    @mika Can't find white enclosure now. You can find black here https://ru.aliexpress.com/item/50-28-15mm-black-small-case-junction-box-DIY-electronic-box-instrument-shell-enclosures/32816171702.html?spm=a2g0v.search0104.3.7.695b35fcke4Os7&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10151_10065_10344_10068_5722815_10342_10343_10340_5722915_10341_5711416_5722615_10696_10084_10083_10618_10307_5722715_5711215_10059_308_100031_10103_5711515_10624_10623_10622_5711315_5722515_10621_10620_10125,searchweb201603_25,ppcSwitch_5&algo_expid=82d68252-5f35-47c6-a438-13925ec12b35-1&algo_pvid=82d68252-5f35-47c6-a438-13925ec12b35&transAbTest=ae803_1&priceBeautifyAB=0
    • KoreshK
      KoreshK
      Koresh
      wrote on last edited by Koresh
      #150
      First batch of the latest version is ready :wink:
      • pepsonP
        pepsonP
        pepson
        Can you share elemnts for version RFM69HW ? I see only PCB files but i dont know whatr i must have elements...
        • pepsonP
          pepsonP
          pepson
          And what is size gold pins ? 2.54 ?
          KoreshK 1 Reply Last reply
          • pepsonP
            pepsonP
            pepson
            And anybody what pin should be wire to activate programming... ? In arduino pro mini is dedicated micro switch. In this dont have microswitch and i want add microswitch. It should be RST connected to GND ? please help...
            • pepsonP pepson
              KoreshK
              KoreshK
              Koresh
              #154
              @pepson said in 💬 Button size radionode with sensors swarm extension:
              Yes, 2.54
              Programming is activated via DTR pin automatically.
              Schematic of the first version is available. Will share schematic version of ButtonSizeNode_V2 (with dc-dc) later.
              • pepsonP
                pepsonP
                pepson
                wrote on last edited by pepson
                #155
                But please share a list element what capacity and resistor and other and with what body. Ex 0805 etc.
                But for programming i dont need push/wire RST with GND ?
                Explaine me how works Programming is activated via DTR pin automatically ??
                And what is ButtonSizeNode_V2 (with dc-dc) ?? What is diffrent to v1 ?
                alexsh1A 1 Reply Last reply
                • pepsonP pepson
                  alexsh1A
                  alexsh1A
                  alexsh1
                  No, no need to connect RST with GND.
                  DTR works automatically - as soon as you press upload in your Arduino IDE, it starts uploading the sketch to the atmega328p. Simple
                  • KoreshK
                    KoreshK
                    Koresh
                    https://github.com/EasySensors/ButtonSizeNode
                    https://github.com/EasySensors/ButtonSizeNode2
                    Will try to share soon. Almost all elements are 0402.
                    • KoreshK Koresh
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @koresh said in [💬 Button size radionode with sensors swarm extension]>
                      Wow! I have been struggling with 0603 size. You must have eagle's eyes :eyes:
                      • pepsonP
                        pepsonP
                        pepson
                        But v2 is also for radio RFM69HW ?
                        • pepsonP pepson
                          KoreshK
                          KoreshK
                          Koresh
                          @pepson Yes. radio footprints are the same. You can use HW or CW via adapter.
                          pepsonP 1 Reply Last reply
                          • KoreshK Koresh
                            pepsonP
                            pepsonP
                            pepson
                            #161
                            @koresh
                            Ok please share list components... i wait for it.
                            And diffrent with v1 and v2 is only that v2 have two batteries ?
                            • pepsonP pepson
                              @koresh
                              KoreshK
                              KoreshK
                              Koresh
                              @pepson Yes. So it have longer lifetime, radio range and working temperature range.
                              • KoreshK Koresh
                                pepsonP
                                pepsonP
                                pepson
                                @koresh
                                Ok thanks. only wait for list component
                                • pepsonP
                                  pepsonP
                                  pepson
                                  Hi
                                  Can you share your project file and file gerber with this specification
                                  https://support.jlcpcb.com/article/44-how-to-export-kicad-pcb-to-gerber-files
                                  Or can you put description to also file gerber ?
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    Description to model elemnts. Ex. U4
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      #166
                                      Please share also layer describe...
                                      Failed load project to production.
                                      • pepsonP pepson
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        #167
                                        You mixed gerbers of the main board and adapter board.
                                        It is standard. If you really need it you can find layers description here
                                        https://goo.gl/Jv33Lb (Generated Gerber Files)
                                        No I can't. Have no time today, sorry.
                                        • KoreshK Koresh
                                          pepsonP
                                          pepsonP
                                          pepson
                                          @koresh said in 💬 Button size radionode with sensors swarm extension:
                                          Can you explaine me more ? What can i do ?
