  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.4k Views 25 Watching
  • pepsonP
    pepsonP
    pepson
    But v2 is also for radio RFM69HW ?
    KoreshK 1 Reply Last reply
    • pepsonP pepson
      KoreshK
      KoreshK
      Koresh
      @pepson Yes. radio footprints are the same. You can use HW or CW via adapter.
      pepsonP 1 Reply Last reply
      • KoreshK Koresh
        pepsonP
        pepsonP
        pepson
        wrote on last edited by pepson
        #161
        @koresh
        Ok please share list components... i wait for it.
        And diffrent with v1 and v2 is only that v2 have two batteries ?
        • pepsonP pepson
          @koresh
          KoreshK
          KoreshK
          Koresh
          @pepson Yes. So it have longer lifetime, radio range and working temperature range.
          • KoreshK Koresh
            pepsonP
            pepsonP
            pepson
            @koresh
            Ok thanks. only wait for list component
            • pepsonP
              pepsonP
              pepson
              Hi
              Can you share your project file and file gerber with this specification
              https://support.jlcpcb.com/article/44-how-to-export-kicad-pcb-to-gerber-files
              Or can you put description to also file gerber ?
              • pepsonP
                pepsonP
                pepson
                Description to model elemnts. Ex. U4
                • pepsonP
                  pepsonP
                  pepson
                  #166
                  Please share also layer describe...
                  Failed load project to production.
                  • pepsonP pepson
                    KoreshK
                    KoreshK
                    Koresh
                    wrote on last edited by Koresh
                    #167
                    @pepson said in 💬 Button size radionode with sensors swarm extension:
                    You mixed gerbers of the main board and adapter board.
                    It is standard. If you really need it you can find layers description here
                    https://goo.gl/Jv33Lb (Generated Gerber Files)
                    No I can't. Have no time today, sorry.
                    • KoreshK Koresh
                      pepsonP
                      pepsonP
                      pepson
                      @koresh said in 💬 Button size radionode with sensors swarm extension:
                      Can you explaine me more ? What can i do ?
                      • pepsonP pepson
                        KoreshK
                        KoreshK
                        Koresh
                        @pepson
                        pcb2.* - main boards gerbers
                        rfm69c_to_rfm69hc.* - adapter gerbers
                        You need only main board gerbers
                        • G
                          G
                          Gerator
                          Hi @koresh I'm having problems with battery monitor. Trying to find out what's wrong, I have realiced that A6 analog reads from regulator output. So It allways reports 3,3V, isn't it?
                          Also, I read that unregulated could go up to 6,5V. Wouldn't this destroy radio module? I think I'm missing something.
                          • D
                            diogoc
                            Hi. Do you have unassembled pcbs to sell?
                            • G Gerator
                              KoreshK
                              KoreshK
                              Koresh
                              @gerator Oh.. so sorry. It is new forum reporting system. Didn't saw your message.
                              A6 reads unregulated voltage (3.5-6.5V) through divider (1/3). So it can't destroyed nothing.
                              • D diogoc
                                KoreshK
                                KoreshK
                                Koresh
                                @diogoc I will try to find them. But all of components are 0402... :eyes:
                                • bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  @Koresh I still have a bunch of v1 boards that I never got to work because of power consumption (I presume). I thought I'd make one more attempt.
                                  I tried bridging the jumper and I'm using a 2032 battery. Consumption varies between 2 and 4mA on different boards. On some boards it fluctuates a lot. The instructions above are not immediately clear. Do I have to remove the LDO AND capacitors as well?
                                  • Y
                                    Y
                                    yury
                                    @bjornhallberg
                                    while measuring current draw , was there FDTI adapter connected also?
                                    • Y yury
                                      @bjornhallberg
                                      bjornhallbergB
                                      bjornhallbergB
                                      bjornhallberg
                                      wrote on last edited by bjornhallberg
                                      #176
                                      @yury No I ran them on just a 2032 battery at the time, just had it in an external battery holder. I also removed the LDO on one of the boards and bridged the two top pads, with no apparent effect.
                                      Unless there is something wrong with my DMM.
                                      alexsh1A 1 Reply Last reply
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @bjornhallberg I have the same v1 board you have with a sleeping power consumption being 5uA. I also have Si1132 sensor soldered and had some issues with power consumption initially as the standard Si1132 lib did not implement sleep function for this sensor.
                                        1. what sensors do you have? Do they properly put to sleep? BH1760?
                                        2. can you share the sketch?
                                        3. removing the LDO will not help you to bring down consumption from 3mA. 3mA most likely mean your radio is not sleeping. Such consumption will kill CR2032 very quickly - no chance running the board on such consumption
                                        4. did you try a different multimeter?
                                        5. there could be a problem with one of the tantalum capacitor. @yury could you remind which one has to be removed please?
                                        I suggest you start with 5)
                                        • alexsh1A alexsh1
                                          bjornhallbergB
                                          bjornhallbergB
                                          bjornhallberg
                                          #178
                                          @alexsh1 Thanks for the suggestions! Reassuring to know that you succeeded.
                                          1. I haven't added any sensors so it's just the default ones.
                                          2. https://github.com/EasySensors/ButtonSizeNode ... may need some cleaning up @Koresh or do we use v2 code for v1 sensor as well?
                                          3. I thought as much ... damn. I'm using the CW version radio with the adapter plate. I also thought about the radio but unlike the NRF radio this one should work with no counterfeit units?
                                          4. No my other DMM was out of batteries. Found my old crappy DMM and it says the same, ~2mA.
                                          5. I did remove both caps and it's still at ~2mA.
                                          You're probably right about something not sleeping. Or else I've done a horrible soldering job on the four radios I've attached so far. All four sensors behave pretty much the same.
                                          Also, at least on Domoticz they changed things around now so you have to use V_LEVEL instead of V_LIGHT_LEVEL or what? https://www.domoticz.com/forum/viewtopic.php?t=18577 With V_LIGHT_LEVEL I get some incomprehensible percent value reported.
