  3. Vera
  4. No Inclusion
No Inclusion
20 Posts 3 Posters 5.8k Views 3 Watching
  • mntlvrM
    mntlvrM
    mntlvr
    wrote on last edited by mntlvr
    korttomaK 1 Reply Last reply
    • mntlvrM mntlvr
      [[topic:post-is-deleted]]
      korttomaK
      korttomaK
      korttoma
      @mntlvr sorry I do not have much experience with MySensors Library version 2.2. My 2 Gateways I run at home use 2.0.0 and 2.1.1. And my test GW (SensebenderGW) is running 2.2.1-alpha since there were some issue using RFM69 on the 2.2 version. Maybe you should try the development version also (2.2.1-alpha)? Unfortunately I ho not have any ESP8266 Gateways at the moment but I can see if I have one laying around so that I can test.
      • Tomas
      • mntlvrM
        mntlvrM
        mntlvr
        • mntlvrM mntlvr
          korttomaK
          korttomaK
          korttoma
          @mntlvr I got it from GitHub but it seems like the development version is now 2.3.0-alpha, not sure what has changed since I downloaded it.
          https://github.com/mysensors/MySensors/tree/development
          • Tomas
          • mntlvrM
            mntlvrM
            mntlvr
            • korttomaK
              korttomaK
              korttoma
              I found an ESP-07 so I uploaded the ESP8266 WiFi Gateway sketch to it an tested inclusion mode in Vera (MySensors plugin version 1.5) and it seems to work just fine for me. I used esp8266 Community version 2.4.1 in Arduino IDE 1.8.5 and MySensors version 2.2.1 -alpha. I'm really out of ideas why this is not working for you.
              • Tomas
              • mntlvrM
                mntlvrM
                mntlvr
                I am begining to believe it is my version of the ESP 8266 like I said mine is a ESP8266-12E devkit version 1 by nodemcu not just a plain jane version of ESP-8266-12 or 12E but I am have many other problems with mysensors right now , have installed IDE v1.84 and mysensor library 1.4.2 on another computer that has never has Arduino or mysensors on it.
                I constructed a 5100 gateway using that version of library and IDE and it works just fine. But I have also built a mysensors realy driver sensor with same equipment and am having nothing but nRF24l01 problems and Pro-Mini problems , it works for awhile like maybe an hour then I get check wires or continue to press reset on pro-mini many times in a row and all of the sudden the sensors comes back to life and then all of the sudden I get a version mismatch and then check wires again. I tried 15 different nRF modules and no difference. Now how can you get a version mismatch when GW and sensors are using same library and all programmed with same computer. I am about to give up on mysensors unless someone out here can help with this,because it makes no sense.
                P.S.
                I can take the very same ESP8266 dev-kit and make a server or client app out of it with no problem so there has to be a very large difference between a 12-E and a dev-kit but I do not see the difference other in the dev-kit already has buttons connected and resistors and built-in serial chip.
                Any more ideasThomas?
                • sglueS
                  sglueS
                  sglue
                  I too have "No Inclusions" on my Vera UI5.
                  I have updated my serial getway to the lastest and re-install the old one back again.
                  Deleted "Mysensors Plugin - version 1.5" on Vera dashboard and re-install back up.
                  Replace Arduino boards Pro Mini/Nano and radios with existing working ones.
                  Update Arduino IDE to the latest 1.8.5
                  And have been reading this numerous times:
                  https://www.mysensors.org/controller/vera
                  "Restart the Vera LUUP Engine (Settings->Z-Wave Settings->Advanced->Reload Engine)"
                  I don't have "Re-load Engine" on my Dashboard.
                  The only thing is I have not upgrade Vera to UI7.
                  Is UI7 stable now?
                  Any help would be much appreciated.
                  • sglueS
                    sglueS
                    sglue
                    Read somewhere to install "Mysensors Plugin" over existing one.
                    How does one do it?
                    I tried and it created new one and it says "not implemented" or something liked that.
                    • sglueS
                      sglueS
                      sglue
                      wrote on last edited by sglue
                      After spending days trying to sort the problem, finally bit the bullet and upgraded MySensors Library, Arduino ide and Vera 3 UI5 to UI7.
                      Thank God I finally did it.
                      Had to set Serial Port Configuration baud to 115200 and redo MySensors inclusions.
                      My Serial Gateway and MySensors Plugin are working fine now.
                      Touch wood. :smiley:
