  3. Delay after TSF:TRI:TSB
19 Posts 5 Posters 4.6k Views 4 Watching
    @fausti the line after indicated NACK. This means that the node did not get acknowledgement from the next node (usually the gateway). The node can't print the nack message until after it has tried and gotten timeout several times. That's why it takes some time. The first send attempt starts much earlier.
    faustiF
    faustiF
    fausti
    wrote on last edited by fausti
    @mfalkvidd many thanks for the quick answer! :-)
    Weirdly this behaviour only shows when I'm using the sleep mode. Also first time NACK appears is after the first Sleep - DEBUG after reset below, NACK at 8437. Any idea what i'm doing wrong or where i could fix it? :grimacing: :grimacing: many thanks in advance 🙂
    ⸮:⸮5 V=6
    0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
    53 MCO:BGN:BFR
    NodeManager v1.7
    LIB V=2.3.0 R=N E=- T=N A=A S=- B=-
    MOTION I=1 P=1 T=16
    LDR I=2 P=16 T=23
    RADIO...108 TSM:INIT
    190 TSF:WUR:MS=0
    215 TSM:INIT:TSP OK
    235 TSF:SID:OK,ID=9
    256 TSM:FPAR
    305 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2377 !TSM:FPAR:NO REPLY
    2402 TSM:FPAR
    2451 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    3278 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    3334 TSF:MSG:FPAR OK,ID=0,D=1
    4526 TSM:FPAR:OK
    4542 TSM:ID
    4556 TSM:ID:OK
    4571 TSM:UPL
    4589 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4661 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4718 TSF:MSG:PONG RECV,HP=1
    4747 TSM:UPL:OK
    4765 TSM:READY:ID=9,PAR=0,DIS=1
    4802 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4876 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4941 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
    5021 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    5091 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    OK
    5152 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
    5232 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
    PRES I=1 T=1 D=MOTION
    5310 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
    PRES I=2 T=16 D=LDR
    5406 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
    READY
    5494 MCO:REG:REQ
    5525 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    5597 TSF:MSG:READ,0-0-9,s=1,c=0,t=1,pt=0,l=6,sg=0:MOTION
    5656 TSF:MSG:ACK
    5675 TSF:MSG:READ,0-0-9,s=2,c=0,t=16,pt=0,l=3,sg=0:LDR
    5732 TSF:MSG:ACK
    5750 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    5808 MCO:PIM:NODE REG=1
    5832 MCO:BGN:STP
    MY I=9 M=1
    INT P=3 M=1
    INT P=2 M=255
    5853 MCO:BGN:INIT OK,TSP=1
    LDR I=2 V=60 %=5
    SEND D=0 I=2 C=0 T=23 S= I=0 F=0.00
    5928 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
    SLEEP 20864s
    6047 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
    6125 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    6199 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
    6254 TSF:MSG:ACK
    6699 TSF:TDI:TSL
    6717 MCO:SLP:WUP=1
    6735 TSF:TRI:TSB
    8437 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
    INT P=3, V=1
    AWAKE
    MOTION I=1 P=3 V=1
    SEND D=0 I=1 C=0 T=16 S= I=0 F=0.00
    8536 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=1,st=OK:1
    LDR I=2 V=59 %=5
    8675 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
    SLEEP 20864s
    8796 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
    8869 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    8943 TSF:MSG:READ,0-0-9,s=1,c=1,t=16,pt=5,l=4,sg=0:1
    8998 TSF:MSG:ACK
    9017 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
    9072 TSF:MSG:ACK
    9443 TSF:TDI:TSL
    9459 MCO:SLP:WUP=1
    9480 TSF:TRI:TSB
    11180 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
    INT P=3, V=0
    AWAKE
    MOTION I=1 P=3 V=0
    11280 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=1,st=OK:0
    LDR I=2 V=60 %=5
    11421 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
    SLEEP 20864s
    11542 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
    11620 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    11696 TSF:MSG:READ,0-0-9,s=1,c=1,t=16,pt=5,l=4,sg=0:0
    11751 TSF:MSG:ACK
    11771 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
    11827 TSF:MSG:ACK
    12197 TSF:TDI:TSL
    Here the DEBUG if I exclude sleep (to --> //node.setSleepDays(1);) - then the sensor sends it's msg. fast and happily..
    ⸮:⸮5 V=6
    53 MCO:BGN:BFR
    NodeManager v1.7
    MOTION I=1 P=1 T=16
    LDR I=2 P=16 T=23
    190 TSF:WUR:MS=0
    215 TSM:INIT:TSP OK
    235 TSF:SID:OK,ID=9
    256 TSM:FPAR
    376 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    432 TSF:MSG:FPAR OK,ID=0,D=1
    2377 TSM:FPAR:OK
    2394 TSM:ID
    2408 TSM:ID:OK
    2422 TSM:UPL
    2441 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2512 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2570 TSF:MSG:PONG RECV,HP=1
    2598 TSM:UPL:OK
    2617 TSM:READY:ID=9,PAR=0,DIS=1
    2654 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    2727 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2793 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
    2873 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2942 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    OK
    3035 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
    3112 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
    3190 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
    PRES I=2 T=16 D=LDR
    3289 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
    READY
    3377 MCO:REG:REQ
    3407 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    3479 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    3536 MCO:PIM:NODE REG=1
    3561 MCO:BGN:STP
    MY I=9 M=1
    INT P=3 M=1
    INT P=2 M=255
    3581 MCO:BGN:INIT OK,TSP=1
    LDR I=2 V=57 %=5
    3657 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:5
    INT P=3, V=1
    MOTION I=1 P=3 V=1
    8374 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
    INT P=3, V=0
    MOTION I=1 P=3 V=0
    12304 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:0
    • faustiF fausti
      ⸮:⸮5 V=6
      53 MCO:BGN:BFR
      NodeManager v1.7
      MOTION I=1 P=1 T=16
      LDR I=2 P=16 T=23
      190 TSF:WUR:MS=0
      215 TSM:INIT:TSP OK
      235 TSF:SID:OK,ID=9
      256 TSM:FPAR
      2402 TSM:FPAR
      4526 TSM:FPAR:OK
      4542 TSM:ID
      4556 TSM:ID:OK
      4571 TSM:UPL
      4747 TSM:UPL:OK
      OK
      PRES I=2 T=16 D=LDR
      READY
      5494 MCO:REG:REQ
      5656 TSF:MSG:ACK
      5732 TSF:MSG:ACK
      5832 MCO:BGN:STP
      MY I=9 M=1
      INT P=3 M=1
      INT P=2 M=255
      LDR I=2 V=60 %=5
      SLEEP 20864s
      6254 TSF:MSG:ACK
      6699 TSF:TDI:TSL
      6717 MCO:SLP:WUP=1
      6735 TSF:TRI:TSB
      INT P=3, V=1
      AWAKE
      MOTION I=1 P=3 V=1
      LDR I=2 V=59 %=5
      SLEEP 20864s
      8998 TSF:MSG:ACK
      9072 TSF:MSG:ACK
      9443 TSF:TDI:TSL
      9459 MCO:SLP:WUP=1
      9480 TSF:TRI:TSB
      INT P=3, V=0
      AWAKE
      MOTION I=1 P=3 V=0
      LDR I=2 V=60 %=5
      SLEEP 20864s
      11751 TSF:MSG:ACK
      11827 TSF:MSG:ACK
      12197 TSF:TDI:TSL
      ⸮:⸮5 V=6
      53 MCO:BGN:BFR
      NodeManager v1.7
      MOTION I=1 P=1 T=16
      LDR I=2 P=16 T=23
      190 TSF:WUR:MS=0
      215 TSM:INIT:TSP OK
      235 TSF:SID:OK,ID=9
      256 TSM:FPAR
      2377 TSM:FPAR:OK
      2394 TSM:ID
      2408 TSM:ID:OK
      2422 TSM:UPL
      2598 TSM:UPL:OK
      OK
      PRES I=2 T=16 D=LDR
      READY
      3377 MCO:REG:REQ
      3561 MCO:BGN:STP
      MY I=9 M=1
      INT P=3 M=1
      INT P=2 M=255
      LDR I=2 V=57 %=5
      INT P=3, V=1
      MOTION I=1 P=3 V=1
      INT P=3, V=0
      MOTION I=1 P=3 V=0
      @fausti sorry, I don't know what nodemanager does behind the scene so there isn't really a way for me to troubleshoot.
      What is powered through pin 6?
      faustiF 1 Reply Last reply
        faustiF
        faustiF
        fausti
        @mfalkvidd thanks again!! :-)
        Yeah.. went through the whole NodeManager Library, tried many things, but couldn’t find the reason for this behaviour. probably I must build my sketch again on foot – without NodeManager, hoped it could save me some time. ^^
        PIN 6 powers an LDR together with PIN 5, read by PIN A0. But when I exclude all corresponding parts and even remove the hardware (10k + LDR) it won’t help.
        Oddly sleeping Time (MCO:SLP:MS=20864000 has the same value as the number after NACK (st=NACK:20864000). If I change the sleep time (e.g. from 1 day to 60 sec) both values are changing equally to the equivalent value in ms.
        @henrik-nielsen had a similar problem (maybe the same) https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
        Later I’ll try the fix described by @berkseo.
        Thanks! :grinning:
        YveauxY mfalkviddM 2 Replies Last reply
        • faustiF fausti
          Thanks! :grinning:
          @fausti are you using an amplified nrf24 pa+lna module by any chance?
          • faustiF fausti
            Thanks! :grinning:
            @fausti interesting that the sleep and the nack has the same value. Maybe something gets overwritten in memory.
            tekkaT 1 Reply Last reply
              tekkaT
              tekkaT
              tekka
              @mfalkvidd @fausti no, this is normal the smartsleep log:
              ==> smart sleep enabled, IRQ on pin 1 set, going to sleep for 20864000 ms
              ==> I_PRE_SLEEP_NOTIFICATION, 500ms to process any incoming message before going to seep
              6254 TSF:MSG:ACK
              6699 TSF:TDI:TSL
              6717 MCO:SLP:WUP=1
              6735 TSF:TRI:TSB
              ==> sleep interrupted by IRQ 1
              ==> I_POST_SLEEP_NOTIFICATION, node was sleeping for 20864000ms (but sleep was interrupted)
              • tekkaT tekka
                6254 TSF:MSG:ACK
                6699 TSF:TDI:TSL
                6717 MCO:SLP:WUP=1
                6735 TSF:TRI:TSB
                tekkaT
                tekkaT
                tekka
                ...but, the delay between TSB and SEND is a bit odd;
                9480 TSF:TRI:TSB
                Enabling MY_DEBUG_VERBOSE_RF24 could eventually give some hints.
                • tekkaT tekka
                  9480 TSF:TRI:TSB
                  tekkaT
                  tekkaT
                  tekka
                  FYI: I tried with both, 2.3.0 and 2.3.1-beta (incl. CE fix), on non-amplified and PA+LNA modules - I do not see any delay between TSB and SEND
                  6973 MCO:SLP:MS=5000,SMS=1,I1=1,M1=1,I2=255,M2=255
                  6979 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                  7486 TSF:TDI:TSL
                  7487 MCO:SLP:WUP=1
                  7489 TSF:TRI:TSB
                  7492 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:5000
                  I assume you have a power issue, a bad module - or an artifact originating from the nodemanager?
                  • faustiF
                    faustiF
                    fausti
                    @Yveaux sensor is using standard NRF24L01+ (only the gw uses pa+lna - but I guess that won't be an issue?)
                    @tekka did you use the same sketch? You mentioned smartsleep, I haven't enabled that.. I'll try MY_DEBUG_VERBOSE_RF24 later, use a fresh NodeManager and will check all my hardware again and I still have to try that fix: https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
                    I've build more than one sensor and all of them are showing that delay - using different power sources and I also tried different capacitor. Maybe after all it's the gw.. but can't think of a reason why sleeping would cause that behavior at gw.
                    I'll report later - Thanks for the quick help!!
                    tekkaT 2 Replies Last reply
                    • faustiF fausti
                      tekkaT
                      tekkaT
                      tekka
                      @fausti the log indicates that smartsleep is enabled - that said, smartsleep may originate from the nodemanager
                      • faustiF fausti
                        tekkaT
                        tekkaT
                        tekka
                        @fausti Can you re-test your setup with this patch (ideally, update GW and nodes): https://github.com/tekka007/MySensors/tree/RF24STDBYTiming - I've added a delay after setting the radio in standby mode.
                        • tekkaT tekka
                          faustiF
                          faustiF
                          fausti
                          @tekka WOW!! Your fix works like a dream - can't thank you enough! :pray: :tada:
                          For now I just used your patch at the sensor - but it allready runs perfectly - no lag/no NACK (see DEBUG below).
                          So the radio needs more time to settle? How long did you set the delay?
                          Many many thanks to @tekka and to you all for helping that fast and professional!!
                          [For so many hours I tried figuring out where the problem lies.. at least I know that library better now ^^ ]
                          0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.1-beta
                          59 MCO:BGN:BFR
                          NodeManager v1.7
                          LIB V=2.3.1-beta R=N E=- T=N A=A S=- B=-
                          MOTION I=1 P=1 T=16
                          LDR I=2 P=16 T=23
                          RADIO...118 TSM:INIT
                          200 TSF:WUR:MS=0
                          223 TSM:INIT:TSP OK
                          245 TSF:SID:OK,ID=9
                          266 TSM:FPAR
                          315 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          1208 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          1265 TSF:MSG:FPAR OK,ID=0,D=1
                          2390 TSM:FPAR:OK
                          2406 TSM:ID
                          2420 TSM:ID:OK
                          2435 TSM:UPL
                          2453 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          2525 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2582 TSF:MSG:PONG RECV,HP=1
                          2611 TSM:UPL:OK
                          2629 TSM:READY:ID=9,PAR=0,DIS=1
                          2666 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          2740 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          2805 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.3.1-beta
                          2891 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          2961 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          OK
                          3022 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
                          3102 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                          3180 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
                          PRES I=2 T=16 D=LDR
                          3276 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
                          READY
                          3364 MCO:REG:REQ
                          3395 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          3467 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          3524 MCO:PIM:NODE REG=1
                          3551 MCO:BGN:STP
                          MY I=9 M=1
                          INT P=3 M=1
                          INT P=2 M=255
                          3569 MCO:BGN:INIT OK,TSP=1
                          LDR I=2 V=302 %=29
                          3645 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:29
                          SLEEP 20864s
                          3768 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                          3846 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                          4419 TSF:TDI:TSL
                          4435 MCO:SLP:WUP=1
                          4456 TSF:TRI:TSB
                          4483 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                          INT P=3, V=1
                          AWAKE
                          MOTION I=1 P=3 V=1
                          4579 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                          LDR I=2 V=284 %=27
                          4718 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:27
                          SLEEP 20864s
                          4841 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                          4919 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                          5494 TSF:TDI:TSL
                          5511 MCO:SLP:WUP=1
                          5531 TSF:TRI:TSB
                          5558 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                          INT P=3, V=0
                          AWAKE
                          MOTION I=1 P=3 V=0
                          5654 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:0
                          LDR I=2 V=295 %=28
                          5793 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:28
                          SLEEP 20864s
                          5916 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                          5994 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                          6569 TSF:TDI:TSL
                          • RayneR
                            RayneR
                            Rayne
                            @tekka This patch is not compiling correctly for ESP8266Gateway when using Wemos D1 Mini in the board manager, nor does it compile when the NodeMCU 1.0 board is selected either.
                            • RayneR Rayne
                              @rayne it compiled fine when the change was merged into MySensors.
                              Could you post the error message you're getting?
                              RayneR 1 Reply Last reply
                                RayneR
                                RayneR
                                Rayne
                                @mfalkvidd Strange, when I compile for a arduino pro mini sensor, it compiles fine. However if I try to compile the esp8266gateway for a Wemos D1 Mini, the compiler complains about a file with no such directory.
                                • RayneR Rayne
                                  @rayne see https://forum.mysensors.org/topic/9563/esp8266-fatal-error-gdb_hooks-h-no-such-file-or-directory-solved
                                    RayneR
                                    RayneR
                                    Rayne
                                    @mfalkvidd Ahhhh, that was it. I was still on 2.3.0 of the esp8266 core. Once I upgraded to 2.4.2 it compiled fine and was able to find gdb_hooks.h. I think I was on the older version due to some compatibility issues I had when I was making a WiFi Jammer for a buddy of mine some time ago. Hey thanks for your help @mfalkvidd . You are the man!
