  3. Delay after TSF:TRI:TSB
19 Posts 5 Posters 4.6k Views 4 Watching
  • faustiF fausti
    @mfalkvidd thanks again!! :-)
    Yeah.. went through the whole NodeManager Library, tried many things, but couldn’t find the reason for this behaviour. probably I must build my sketch again on foot – without NodeManager, hoped it could save me some time. ^^
    PIN 6 powers an LDR together with PIN 5, read by PIN A0. But when I exclude all corresponding parts and even remove the hardware (10k + LDR) it won’t help.
    Oddly sleeping Time (MCO:SLP:MS=20864000 has the same value as the number after NACK (st=NACK:20864000). If I change the sleep time (e.g. from 1 day to 60 sec) both values are changing equally to the equivalent value in ms.
    @henrik-nielsen had a similar problem (maybe the same) https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
    Later I’ll try the fix described by @berkseo.
    Thanks! :grinning:
    @fausti are you using an amplified nrf24 pa+lna module by any chance?
    • faustiF fausti
      Thanks! :grinning:
      @fausti interesting that the sleep and the nack has the same value. Maybe something gets overwritten in memory.
      tekkaT 1 Reply Last reply
        tekkaT
        tekkaT
        tekka
        @mfalkvidd @fausti no, this is normal the smartsleep log:
        6047 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
        ==> smart sleep enabled, IRQ on pin 1 set, going to sleep for 20864000 ms
        6125 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
        ==> I_PRE_SLEEP_NOTIFICATION, 500ms to process any incoming message before going to seep
        6199 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
        6254 TSF:MSG:ACK
        6699 TSF:TDI:TSL
        6717 MCO:SLP:WUP=1
        6735 TSF:TRI:TSB
        ==> sleep interrupted by IRQ 1
        8437 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
        ==> I_POST_SLEEP_NOTIFICATION, node was sleeping for 20864000ms (but sleep was interrupted)
        • tekkaT tekka
          6254 TSF:MSG:ACK
          6699 TSF:TDI:TSL
          6717 MCO:SLP:WUP=1
          6735 TSF:TRI:TSB
          tekkaT
          tekkaT
          tekka
          ...but, the delay between TSB and SEND is a bit odd;
          9480 TSF:TRI:TSB
          11180 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
          Enabling MY_DEBUG_VERBOSE_RF24 could eventually give some hints.
          • tekkaT tekka
            9480 TSF:TRI:TSB
            tekkaT
            tekkaT
            tekka
            FYI: I tried with both, 2.3.0 and 2.3.1-beta (incl. CE fix), on non-amplified and PA+LNA modules - I do not see any delay between TSB and SEND
            6973 MCO:SLP:MS=5000,SMS=1,I1=1,M1=1,I2=255,M2=255
            6979 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
            7486 TSF:TDI:TSL
            7487 MCO:SLP:WUP=1
            7489 TSF:TRI:TSB
            7492 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:5000
            I assume you have a power issue, a bad module - or an artifact originating from the nodemanager?
            • faustiF
              faustiF
              fausti
              @Yveaux sensor is using standard NRF24L01+ (only the gw uses pa+lna - but I guess that won't be an issue?)
              @tekka did you use the same sketch? You mentioned smartsleep, I haven't enabled that.. I'll try MY_DEBUG_VERBOSE_RF24 later, use a fresh NodeManager and will check all my hardware again and I still have to try that fix: https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
              I've build more than one sensor and all of them are showing that delay - using different power sources and I also tried different capacitor. Maybe after all it's the gw.. but can't think of a reason why sleeping would cause that behavior at gw.
              I'll report later - Thanks for the quick help!!
              tekkaT 2 Replies Last reply
              • faustiF fausti
                tekkaT
                tekkaT
                tekka
                @fausti the log indicates that smartsleep is enabled - that said, smartsleep may originate from the nodemanager
                • faustiF fausti
                  tekkaT
                  tekkaT
                  tekka
                  @fausti Can you re-test your setup with this patch (ideally, update GW and nodes): https://github.com/tekka007/MySensors/tree/RF24STDBYTiming - I've added a delay after setting the radio in standby mode.
                  faustiF 1 Reply Last reply
                  • tekkaT tekka
                    faustiF
                    faustiF
                    fausti
                    @tekka WOW!! Your fix works like a dream - can't thank you enough! :pray: :tada:
                    For now I just used your patch at the sensor - but it allready runs perfectly - no lag/no NACK (see DEBUG below).
                    So the radio needs more time to settle? How long did you set the delay?
                    Many many thanks to @tekka and to you all for helping that fast and professional!!
                    [For so many hours I tried figuring out where the problem lies.. at least I know that library better now ^^ ]
                    0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.1-beta
                    59 MCO:BGN:BFR
                    NodeManager v1.7
                    LIB V=2.3.1-beta R=N E=- T=N A=A S=- B=-
                    MOTION I=1 P=1 T=16
                    LDR I=2 P=16 T=23
                    RADIO...118 TSM:INIT
                    200 TSF:WUR:MS=0
                    223 TSM:INIT:TSP OK
                    245 TSF:SID:OK,ID=9
                    266 TSM:FPAR
                    315 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    1208 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    1265 TSF:MSG:FPAR OK,ID=0,D=1
                    2390 TSM:FPAR:OK
                    2406 TSM:ID
                    2420 TSM:ID:OK
                    2435 TSM:UPL
                    2453 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    2525 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    2582 TSF:MSG:PONG RECV,HP=1
                    2611 TSM:UPL:OK
                    2629 TSM:READY:ID=9,PAR=0,DIS=1
                    2666 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    2740 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    2805 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.3.1-beta
                    2891 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    2961 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    OK
                    3022 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
                    3102 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                    PRES I=1 T=1 D=MOTION
                    3180 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
                    PRES I=2 T=16 D=LDR
                    3276 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
                    READY
                    3364 MCO:REG:REQ
                    3395 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    3467 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    3524 MCO:PIM:NODE REG=1
                    3551 MCO:BGN:STP
                    MY I=9 M=1
                    INT P=3 M=1
                    INT P=2 M=255
                    3569 MCO:BGN:INIT OK,TSP=1
                    LDR I=2 V=302 %=29
                    SEND D=0 I=2 C=0 T=23 S= I=0 F=0.00
                    3645 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:29
                    SLEEP 20864s
                    3768 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                    3846 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                    4419 TSF:TDI:TSL
                    4435 MCO:SLP:WUP=1
                    4456 TSF:TRI:TSB
                    4483 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                    INT P=3, V=1
                    AWAKE
                    MOTION I=1 P=3 V=1
                    SEND D=0 I=1 C=0 T=16 S= I=0 F=0.00
                    4579 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                    LDR I=2 V=284 %=27
                    4718 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:27
                    SLEEP 20864s
                    4841 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                    4919 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                    5494 TSF:TDI:TSL
                    5511 MCO:SLP:WUP=1
                    5531 TSF:TRI:TSB
                    5558 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                    INT P=3, V=0
                    AWAKE
                    MOTION I=1 P=3 V=0
                    5654 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:0
                    LDR I=2 V=295 %=28
                    5793 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:28
                    SLEEP 20864s
                    5916 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                    5994 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                    6569 TSF:TDI:TSL
                    • RayneR
                      RayneR
                      Rayne
                      @tekka This patch is not compiling correctly for ESP8266Gateway when using Wemos D1 Mini in the board manager, nor does it compile when the NodeMCU 1.0 board is selected either.
                      • RayneR Rayne
                        @rayne it compiled fine when the change was merged into MySensors.
                        Could you post the error message you're getting?
                        RayneR 1 Reply Last reply
                          RayneR
                          RayneR
                          Rayne
                          @mfalkvidd Strange, when I compile for a arduino pro mini sensor, it compiles fine. However if I try to compile the esp8266gateway for a Wemos D1 Mini, the compiler complains about a file with no such directory.
                          • RayneR Rayne
                            @rayne see https://forum.mysensors.org/topic/9563/esp8266-fatal-error-gdb_hooks-h-no-such-file-or-directory-solved
                              RayneR
                              RayneR
                              Rayne
                              @mfalkvidd Ahhhh, that was it. I was still on 2.3.0 of the esp8266 core. Once I upgraded to 2.4.2 it compiled fine and was able to find gdb_hooks.h. I think I was on the older version due to some compatibility issues I had when I was making a WiFi Jammer for a buddy of mine some time ago. Hey thanks for your help @mfalkvidd . You are the man!
