  3. Delay after TSF:TRI:TSB
19 Posts 5 Posters 4.6k Views 4 Watching
    @fausti interesting that the sleep and the nack has the same value. Maybe something gets overwritten in memory.
    tekkaT
    tekkaT
    tekka
    @mfalkvidd @fausti no, this is normal the smartsleep log:
    6047 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
    ==> smart sleep enabled, IRQ on pin 1 set, going to sleep for 20864000 ms
    6125 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    ==> I_PRE_SLEEP_NOTIFICATION, 500ms to process any incoming message before going to seep
    6199 TSF:MSG:READ,0-0-9,s=2,c=1,t=23,pt=5,l=4,sg=0:5
    6254 TSF:MSG:ACK
    6699 TSF:TDI:TSL
    6717 MCO:SLP:WUP=1
    6735 TSF:TRI:TSB
    ==> sleep interrupted by IRQ 1
    8437 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
    ==> I_POST_SLEEP_NOTIFICATION, node was sleeping for 20864000ms (but sleep was interrupted)
    tekkaT 1 Reply Last reply
    • tekkaT tekka
      6254 TSF:MSG:ACK
      6699 TSF:TDI:TSL
      6717 MCO:SLP:WUP=1
      6735 TSF:TRI:TSB
      tekkaT
      tekkaT
      tekka
      ...but, the delay between TSB and SEND is a bit odd;
      9480 TSF:TRI:TSB
      11180 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
      Enabling MY_DEBUG_VERBOSE_RF24 could eventually give some hints.
      • tekkaT tekka
        9480 TSF:TRI:TSB
        tekkaT
        tekkaT
        tekka
        FYI: I tried with both, 2.3.0 and 2.3.1-beta (incl. CE fix), on non-amplified and PA+LNA modules - I do not see any delay between TSB and SEND
        6973 MCO:SLP:MS=5000,SMS=1,I1=1,M1=1,I2=255,M2=255
        6979 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
        7486 TSF:TDI:TSL
        7487 MCO:SLP:WUP=1
        7489 TSF:TRI:TSB
        7492 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:5000
        I assume you have a power issue, a bad module - or an artifact originating from the nodemanager?
        • faustiF
          faustiF
          fausti
          @Yveaux sensor is using standard NRF24L01+ (only the gw uses pa+lna - but I guess that won't be an issue?)
          @tekka did you use the same sketch? You mentioned smartsleep, I haven't enabled that.. I'll try MY_DEBUG_VERBOSE_RF24 later, use a fresh NodeManager and will check all my hardware again and I still have to try that fix: https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
          I've build more than one sensor and all of them are showing that delay - using different power sources and I also tried different capacitor. Maybe after all it's the gw.. but can't think of a reason why sleeping would cause that behavior at gw.
          I'll report later - Thanks for the quick help!!
          tekkaT 2 Replies Last reply
          • faustiF fausti
            tekkaT
            tekkaT
            tekka
            @fausti the log indicates that smartsleep is enabled - that said, smartsleep may originate from the nodemanager
            • faustiF fausti
              tekkaT
              tekkaT
              tekka
              @fausti Can you re-test your setup with this patch (ideally, update GW and nodes): https://github.com/tekka007/MySensors/tree/RF24STDBYTiming - I've added a delay after setting the radio in standby mode.
              faustiF 1 Reply Last reply
              • tekkaT tekka
                faustiF
                faustiF
                fausti
                @tekka WOW!! Your fix works like a dream - can't thank you enough! :pray: :tada:
                For now I just used your patch at the sensor - but it allready runs perfectly - no lag/no NACK (see DEBUG below).
                So the radio needs more time to settle? How long did you set the delay?
                Many many thanks to @tekka and to you all for helping that fast and professional!!
                [For so many hours I tried figuring out where the problem lies.. at least I know that library better now ^^ ]
                0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.1-beta
                59 MCO:BGN:BFR
                NodeManager v1.7
                LIB V=2.3.1-beta R=N E=- T=N A=A S=- B=-
                MOTION I=1 P=1 T=16
                LDR I=2 P=16 T=23
                RADIO...118 TSM:INIT
                200 TSF:WUR:MS=0
                223 TSM:INIT:TSP OK
                245 TSF:SID:OK,ID=9
                266 TSM:FPAR
                315 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                1208 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                1265 TSF:MSG:FPAR OK,ID=0,D=1
                2390 TSM:FPAR:OK
                2406 TSM:ID
                2420 TSM:ID:OK
                2435 TSM:UPL
                2453 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                2525 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                2582 TSF:MSG:PONG RECV,HP=1
                2611 TSM:UPL:OK
                2629 TSM:READY:ID=9,PAR=0,DIS=1
                2666 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                2740 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                2805 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.3.1-beta
                2891 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                2961 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                OK
                3022 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
                3102 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
                PRES I=1 T=1 D=MOTION
                3180 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
                PRES I=2 T=16 D=LDR
                3276 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
                READY
                3364 MCO:REG:REQ
                3395 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                3467 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                3524 MCO:PIM:NODE REG=1
                3551 MCO:BGN:STP
                MY I=9 M=1
                INT P=3 M=1
                INT P=2 M=255
                3569 MCO:BGN:INIT OK,TSP=1
                LDR I=2 V=302 %=29
                SEND D=0 I=2 C=0 T=23 S= I=0 F=0.00
                3645 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:29
                SLEEP 20864s
                3768 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                3846 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                4419 TSF:TDI:TSL
                4435 MCO:SLP:WUP=1
                4456 TSF:TRI:TSB
                4483 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                INT P=3, V=1
                AWAKE
                MOTION I=1 P=3 V=1
                SEND D=0 I=1 C=0 T=16 S= I=0 F=0.00
                4579 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
                LDR I=2 V=284 %=27
                4718 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:27
                SLEEP 20864s
                4841 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                4919 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                5494 TSF:TDI:TSL
                5511 MCO:SLP:WUP=1
                5531 TSF:TRI:TSB
                5558 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
                INT P=3, V=0
                AWAKE
                MOTION I=1 P=3 V=0
                5654 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:0
                LDR I=2 V=295 %=28
                5793 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:28
                SLEEP 20864s
                5916 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
                5994 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
                6569 TSF:TDI:TSL
                • RayneR
                  RayneR
                  Rayne
                  @tekka This patch is not compiling correctly for ESP8266Gateway when using Wemos D1 Mini in the board manager, nor does it compile when the NodeMCU 1.0 board is selected either.
                  • RayneR Rayne
                    @rayne it compiled fine when the change was merged into MySensors.
                    Could you post the error message you're getting?
                    RayneR 1 Reply Last reply
                      RayneR
                      RayneR
                      Rayne
                      @mfalkvidd Strange, when I compile for a arduino pro mini sensor, it compiles fine. However if I try to compile the esp8266gateway for a Wemos D1 Mini, the compiler complains about a file with no such directory.
                      • RayneR Rayne
                        @rayne see https://forum.mysensors.org/topic/9563/esp8266-fatal-error-gdb_hooks-h-no-such-file-or-directory-solved
                          RayneR
                          RayneR
                          Rayne
                          @mfalkvidd Ahhhh, that was it. I was still on 2.3.0 of the esp8266 core. Once I upgraded to 2.4.2 it compiled fine and was able to find gdb_hooks.h. I think I was on the older version due to some compatibility issues I had when I was making a WiFi Jammer for a buddy of mine some time ago. Hey thanks for your help @mfalkvidd . You are the man!
