  3. Delay after TSF:TRI:TSB
19 Posts 5 Posters 4.6k Views 4 Watching
  • tekkaT tekka
    ...but, the delay between TSB and SEND is a bit odd;
    9480 TSF:TRI:TSB
    11180 !TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=NACK:20864000
    Enabling MY_DEBUG_VERBOSE_RF24 could eventually give some hints.
    tekkaT
    tekkaT
    tekka
    FYI: I tried with both, 2.3.0 and 2.3.1-beta (incl. CE fix), on non-amplified and PA+LNA modules - I do not see any delay between TSB and SEND
    6973 MCO:SLP:MS=5000,SMS=1,I1=1,M1=1,I2=255,M2=255
    6979 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
    7486 TSF:TDI:TSL
    7487 MCO:SLP:WUP=1
    7489 TSF:TRI:TSB
    7492 TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:5000
    I assume you have a power issue, a bad module - or an artifact originating from the nodemanager?
    • faustiF
      faustiF
      fausti
      @Yveaux sensor is using standard NRF24L01+ (only the gw uses pa+lna - but I guess that won't be an issue?)
      @tekka did you use the same sketch? You mentioned smartsleep, I haven't enabled that.. I'll try MY_DEBUG_VERBOSE_RF24 later, use a fresh NodeManager and will check all my hardware again and I still have to try that fix: https://forum.mysensors.org/topic/9598/smartsleep-wake-up-message-always-get-nack
      I've build more than one sensor and all of them are showing that delay - using different power sources and I also tried different capacitor. Maybe after all it's the gw.. but can't think of a reason why sleeping would cause that behavior at gw.
      I'll report later - Thanks for the quick help!!
      tekkaT 2 Replies Last reply
      • faustiF fausti
        tekkaT
        tekkaT
        tekka
        @fausti the log indicates that smartsleep is enabled - that said, smartsleep may originate from the nodemanager
        6047 MCO:SLP:MS=20864000,SMS=1
        • faustiF fausti
          tekkaT
          tekkaT
          tekka
          @fausti Can you re-test your setup with this patch (ideally, update GW and nodes): https://github.com/tekka007/MySensors/tree/RF24STDBYTiming - I've added a delay after setting the radio in standby mode.
          faustiF 1 Reply Last reply
          • tekkaT tekka
            faustiF
            faustiF
            fausti
            @tekka WOW!! Your fix works like a dream - can't thank you enough! :pray: :tada:
            For now I just used your patch at the sensor - but it allready runs perfectly - no lag/no NACK (see DEBUG below).
            So the radio needs more time to settle? How long did you set the delay?
            Many many thanks to @tekka and to you all for helping that fast and professional!!
            [For so many hours I tried figuring out where the problem lies.. at least I know that library better now ^^ ]
            0 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.1-beta
            59 MCO:BGN:BFR
            NodeManager v1.7
            LIB V=2.3.1-beta R=N E=- T=N A=A S=- B=-
            MOTION I=1 P=1 T=16
            LDR I=2 P=16 T=23
            RADIO...118 TSM:INIT
            200 TSF:WUR:MS=0
            223 TSM:INIT:TSP OK
            245 TSF:SID:OK,ID=9
            266 TSM:FPAR
            315 TSF:MSG:SEND,9-9-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            1208 TSF:MSG:READ,0-0-9,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            1265 TSF:MSG:FPAR OK,ID=0,D=1
            2390 TSM:FPAR:OK
            2406 TSM:ID
            2420 TSM:ID:OK
            2435 TSM:UPL
            2453 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
            2525 TSF:MSG:READ,0-0-9,s=255,c=3,t=25,pt=1,l=1,sg=0:1
            2582 TSF:MSG:PONG RECV,HP=1
            2611 TSM:UPL:OK
            2629 TSM:READY:ID=9,PAR=0,DIS=1
            2666 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            2740 TSF:MSG:READ,0-0-9,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            2805 TSF:MSG:SEND,9-9-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.3.1-beta
            2891 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
            2961 TSF:MSG:READ,0-0-9,s=255,c=3,t=6,pt=0,l=1,sg=0:M
            OK
            3022 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Testo
            3102 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:2.0
            PRES I=1 T=1 D=MOTION
            3180 TSF:MSG:SEND,9-9-0-0,s=1,c=0,t=1,pt=0,l=6,sg=0,ft=0,st=OK:MOTION
            PRES I=2 T=16 D=LDR
            3276 TSF:MSG:SEND,9-9-0-0,s=2,c=0,t=16,pt=0,l=3,sg=0,ft=0,st=OK:LDR
            READY
            3364 MCO:REG:REQ
            3395 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
            3467 TSF:MSG:READ,0-0-9,s=255,c=3,t=27,pt=1,l=1,sg=0:1
            3524 MCO:PIM:NODE REG=1
            3551 MCO:BGN:STP
            MY I=9 M=1
            INT P=3 M=1
            INT P=2 M=255
            3569 MCO:BGN:INIT OK,TSP=1
            LDR I=2 V=302 %=29
            SEND D=0 I=2 C=0 T=23 S= I=0 F=0.00
            3645 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:29
            SLEEP 20864s
            3768 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
            3846 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
            4419 TSF:TDI:TSL
            4435 MCO:SLP:WUP=1
            4456 TSF:TRI:TSB
            4483 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
            INT P=3, V=1
            AWAKE
            MOTION I=1 P=3 V=1
            SEND D=0 I=1 C=0 T=16 S= I=0 F=0.00
            4579 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:1
            LDR I=2 V=284 %=27
            4718 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:27
            SLEEP 20864s
            4841 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
            4919 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
            5494 TSF:TDI:TSL
            5511 MCO:SLP:WUP=1
            5531 TSF:TRI:TSB
            5558 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=33,pt=5,l=4,sg=0,ft=0,st=OK:20864000
            INT P=3, V=0
            AWAKE
            MOTION I=1 P=3 V=0
            5654 TSF:MSG:SEND,9-9-0-0,s=1,c=1,t=16,pt=5,l=4,sg=0,ft=0,st=OK:0
            LDR I=2 V=295 %=28
            5793 TSF:MSG:SEND,9-9-0-0,s=2,c=1,t=23,pt=5,l=4,sg=0,ft=0,st=OK:28
            SLEEP 20864s
            5916 MCO:SLP:MS=20864000,SMS=1,I1=1,M1=1,I2=255,M2=255
            5994 TSF:MSG:SEND,9-9-0-0,s=255,c=3,t=32,pt=5,l=4,sg=0,ft=0,st=OK:500
            6569 TSF:TDI:TSL
            • RayneR
              RayneR
              Rayne
              @tekka This patch is not compiling correctly for ESP8266Gateway when using Wemos D1 Mini in the board manager, nor does it compile when the NodeMCU 1.0 board is selected either.
              • RayneR Rayne
                @rayne it compiled fine when the change was merged into MySensors.
                Could you post the error message you're getting?
                RayneR 1 Reply Last reply
                  RayneR
                  RayneR
                  Rayne
                  @mfalkvidd Strange, when I compile for a arduino pro mini sensor, it compiles fine. However if I try to compile the esp8266gateway for a Wemos D1 Mini, the compiler complains about a file with no such directory.
                  • RayneR Rayne
                    @rayne see https://forum.mysensors.org/topic/9563/esp8266-fatal-error-gdb_hooks-h-no-such-file-or-directory-solved
                      RayneR
                      RayneR
                      Rayne
                      @mfalkvidd Ahhhh, that was it. I was still on 2.3.0 of the esp8266 core. Once I upgraded to 2.4.2 it compiled fine and was able to find gdb_hooks.h. I think I was on the older version due to some compatibility issues I had when I was making a WiFi Jammer for a buddy of mine some time ago. Hey thanks for your help @mfalkvidd . You are the man!
