1.1k Posts 105 Posters 785.7k Views 98 Watching
  • alexsh1A alexsh1
    @mfalkvidd Just a tip. You may be better of buying this one:
    https://www.amazon.co.uk/KKmoon-Portable-Digital-Oscilloscope-Interface/dp/B07C4RTXF6/ref=sr_1_3?ie=UTF8&qid=1534094879&sr=8-3&keywords=oscilloscope+portable
    Much better spec and the price is the same. AND you can save tons of time as it does not require soldering.
    @alexsh1 thanks for the tip. I guess I'll have a hard time getting my money and time back now that the kit is soldered, but it might be interesting for someone else.
    • alexsh1A alexsh1
      @tbowmo Now I want to build one :-)))
      tbowmoT
      tbowmoT
      tbowmo
      @alexsh1
      I used this as a base for my own build: https://www.instructables.com/id/2-Player-Bartop-Arcade-Machine-Powered-by-Pi/
      • kalinaK
        kalinaK
        kalina
        LED backlight for my CNC machine....
        • mfalkviddM
          #613
          Today I've been trying to get a MS5803_05BA sensor working. This is a pressure sensor that is commonly used in dive computers.
          The sensor is tiny and handles 0-5 bar. So far I've not been able to communicate with it though. I use i2c and have tried two libraries, but none of them work (or maybe I killed the sensor when I soldered the cable).
          • mfalkviddM
            At first I had a 25m cable. Turns out i2c isn't designed for that. It is designed for ~1m at 100kHz and ~10m at 10kHz. ESP8266 defaults to 400kHz and can't go lower than 50kHz without modifying the ESP8266 core files.
            I got my first use case for the oscilloscope I built.
            This was the signal at the start of the cable:
            This was the signal at the end of the cable:
            So no surprise that the communication didn't work.
            I tried with a 2k pullup:
            Much better! But still not very good.
            I modified the library to use 7.5kHz:
            Better again, but still not great. I lowered the speed to 0.75kHz:
            Nice and clean!
            But communication still didn't work so I decided to cut the cable (to the 10cm length seen above) and restore all my changes. But communication still doesn't work.
            I bought the sensor from a reputable distributor in UK so I don't think I got a faulty sensor. But I don't seem to get any life signs at all from it. I tried an i2c scan sketch and it found nothing.
              Nice and clean!
              @mfalkvidd shot in the dark ; do you pull the PS pin high to select i2c protocol?
              • YveauxY Yveaux
                #616
                @yveaux yes I do. I took the easy way: soldered the 3.3V wire to pads 5 and 6 at the same time.
                And I have tried putting a 104 ceramic capacitor between 3V3 and GND right next to the sensor.
                CSB is connected to GND.
                My next step is either to see if I can get SPI working (instead of i2c), or order a new sensor. But first sleep.
                • nagelcN
                  nagelcN
                  nagelc
                  BT832 Thin Node prototype. Inspired by https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node and @neverdie nrf5 and am612 research. I noticed the BT832 is about the same width as a AA battery holder. I'm using one AA LiFePo4. This is my first sensor with nrf5, bme280, and am612. I also incorporated a jst-sh 6 pin connector for programming. It includes swd, power, and text. All sensors are working. It did not turn out to be very thin. Need to try some smaller PIR lenses and rearrange components for the next iteration.
                    Nice work! If you want to go thinner, you may have to use a coincell. Looks nice the way it is though.
                    • kalinaK
                      kalinaK
                      kalina
                      I have assembled a few UPS ... now I am testing these hardware.
                      2_1537103208634_UPS_3.jpg 1_1537103208634_UPS_2.jpg 0_1537103208633_UPS_1.jpg
                      nagelcN T 2 Replies Last reply
                      • kalinaK kalina
                        nagelcN
                        nagelcN
                        nagelc
                        @kalina
                        Nice packaging. I'll be interested to hear how well they work.
                        kalinaK 1 Reply Last reply
                        • nagelcN nagelc
                          @kalina
                          kalinaK
                          kalinaK
                          kalina
                          @nagelc
                          OK, I will keep you informed of developments on this project ...
                          • kalinaK kalina
                            tsjoender
                            @kalina said in What did you build today (Pictures) ?:
                            Looks neat! How did you do the cutout of the sides of these enclosures?
                            • T tsjoender
                              kalinaK
                              kalinaK
                              kalina
                              @tsjoender said in What did you build today (Pictures) ?:
                              No magic, this is the work of the CNC...)))
                              • sundberg84S
                                sundberg84S
                                #624
                                Today I had the ladder so I could get on the roof so while there I changed batteries on my rain node.
                                • sundberg84S sundberg84
                                  @sundberg84 But what did you build today? ;-)
                                  • YveauxY Yveaux
                                    sundberg84S
                                    sundberg84S
                                    @yveaux nothing that I can post here unfortunately... only a ladder for my cat 😂 non automated.
                                    Nca78N 1 Reply Last reply
                                    • nagelcN
                                      nagelcN
                                      nagelc
                                      wrote on last edited by nagelc
                                      #627
                                      It's a breakout for a Fanstel BT832 (NRF52832). Two experiments with this board, still a work in progress:
                                      • I wondered if it would be possible to hand solder to the LGA pads on the back of the BT832 using small plated thru holes (6 solder spots middle left in the first picture). Two pads connected. The rest did not. About what I expected.
                                      • Using just the microprocessor of the BT832 to make a LoRa node. (NRF5 radio turned off). So far the Ra-01 is not initializing. Edit (10/8). The RA-01 now initializes. I needed to update the pin assignments in MyBoardNRF5.h.
                                        Just pretend you have automated your cat. We can't control from here.
                                        • vladimirV
                                          vladimirV
                                          vladimir
                                          Colleagues!
                                          I am writing in this thread, because here are the most active users of the forum and the system MySensors.:raised_hands:
                                          Perhaps you can help me with the solution of my problem: Improvement Xiaomi smart kettle (I need help!)
                                          Maybe you had similar projects...
                                          Then, I can finally publish a new project in this thread. :v:
