1.1k Posts 105 Posters 747.7k Views 98 Watching
  • kalinaK
    kalinaK
    kalina
    I have assembled a few UPS ... now I am testing these hardware.
    2_1537103208634_UPS_3.jpg 1_1537103208634_UPS_2.jpg 0_1537103208633_UPS_1.jpg
    nagelcN T 2 Replies Last reply
    • kalinaK kalina
      nagelcN
      nagelcN
      nagelc
      @kalina
      Nice packaging. I'll be interested to hear how well they work.
      kalinaK 1 Reply Last reply
      • nagelcN nagelc
        @kalina
        kalinaK
        kalinaK
        kalina
        @nagelc
        OK, I will keep you informed of developments on this project ...
        • kalinaK kalina
          tsjoender
          @kalina said in What did you build today (Pictures) ?:
          Looks neat! How did you do the cutout of the sides of these enclosures?
          • T tsjoender
            kalinaK
            kalinaK
            kalina
            @tsjoender said in What did you build today (Pictures) ?:
            No magic, this is the work of the CNC...)))
            • sundberg84S
              sundberg84S
              #624
              Today I had the ladder so I could get on the roof so while there I changed batteries on my rain node.
              • sundberg84S sundberg84
                @sundberg84 But what did you build today? ;-)
                • YveauxY Yveaux
                  sundberg84S
                  sundberg84S
                  @yveaux nothing that I can post here unfortunately... only a ladder for my cat 😂 non automated.
                  Nca78N 1 Reply Last reply
                  • nagelcN
                    nagelcN
                    nagelc
                    wrote on last edited by nagelc
                    #627
                    It's a breakout for a Fanstel BT832 (NRF52832). Two experiments with this board, still a work in progress:
                    • I wondered if it would be possible to hand solder to the LGA pads on the back of the BT832 using small plated thru holes (6 solder spots middle left in the first picture). Two pads connected. The rest did not. About what I expected.
                    • Using just the microprocessor of the BT832 to make a LoRa node. (NRF5 radio turned off). So far the Ra-01 is not initializing. Edit (10/8). The RA-01 now initializes. I needed to update the pin assignments in MyBoardNRF5.h.
                      Just pretend you have automated your cat. We can't control from here.
                      • vladimirV
                        vladimirV
                        vladimir
                        Colleagues!
                        I am writing in this thread, because here are the most active users of the forum and the system MySensors.:raised_hands:
                        Perhaps you can help me with the solution of my problem: Improvement Xiaomi smart kettle (I need help!)
                        Maybe you had similar projects...
                        Then, I can finally publish a new project in this thread. :v:
                        • vladimirV vladimir
                          Colleagues!
                          #630
                          @vladimir please don't crosspost. Everybody is able to see the latest messages, so there is no need to point to your post from multiple threads.
                          vladimirV 1 Reply Last reply
                          • YveauxY Yveaux
                            vladimirV
                            vladimirV
                            vladimir
                            @yveaux Excuse me. I promise not to do it again!:man-gesturing-ok:
                            • sundberg84S
                              sundberg84S
                              #632
                              @Nca78 Well, i automated my cat door.
                              • Andrew MaynardA
                                Andrew MaynardA
                                Andrew Maynard
                                The rules are simple - keep it simple with one picture (or a few) with a small text including a small exp
                                sick of breadboard so made the gateway more permanent. added a nice dc plug to it after pic
                                • sundberg84S
                                  sundberg84S
                                  #634
                                  Playing with how small I could create a EasyPCB if I only used SMD components and footprints for both RFM69 and Nrf24l01+... including MysX, Signing, Flash offcourse... and a coincell...
                                  tbowmoT monteM 2 Replies Last reply
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @sundberg84
                                    cool, what dimensions are you down to now?
                                    btw. what happened to the trace in lower right corner (the one that runs by the ISP connector)?
                                    • tbowmoT tbowmo
                                      @sundberg84
                                      sundberg84S
                                      sundberg84S
                                      #636
                                      @tbowmo - Thanks!! :) 42mm diameter (round, but the 3d view doesnt show that).
                                      The track - well, it seems like I can only get KiCad to make 45dgr tracks... need to investigate it its possible to make other tracks...
                                      O 1 Reply Last reply
                                        monteM
                                        monteM
                                        monte
                                        @sundberg84 you can also use smd crystal. They are cheaply available on aliexpress. Are you using 0603 caps and resistors?
                                        • monteM monte
                                          sundberg84S
                                          sundberg84S
                                          @monte - 0805 res/caps, (for me easy to solder, while 0603 is possible but start to get hard).
                                          I was thinking about SMD crystal but left it since i couldnt find a common size. Do you know a good size for SMD crystal (with multiple brands?) like 0805 or a good searchword? I found HC-49S but they are the same size as the ones with pins.
                                          monteM 1 Reply Last reply
