  3. Radio setup give: "check wires"
94 Posts 17 Posters 74.4k Views 3 Watching
  • O
    O
    olaeke
    I can confirm that you can get non + variant to work on nodes but on the gateway you must have a + variant.
    But it is not worth the effort, if you have got non + variant from the China, throw them away and by new one (and cross your fingers that you get correct next time)
    S 1 Reply Last reply
    • sonicblazeS
      sonicblazeS
      sonicblaze
      I finally got some + versions from AliExpress. Plugged them in, and everything came to life immediately. Amazing what happens when you receive the right parts.
      • O olaeke
        Squint
        @olaeke Can you explain why the controller needs to be "+" ?
        If we follow the speed change from the post above, does it also effect the Controller speed?
        I've just managed to get a sensor going ( non+, via the hack here at 1MB ).. ( My Chip actually shows a +, but printDetails(); shows no +
        My Controller/Gateway also is supposed to be "+", however printDetails(); shows its not + either..
        Is there a chance, I have it setup wrong and it defaults to non+ in the printDetails() output?
        The Controller doest startup and say "Started!"..
        O 1 Reply Last reply
          You don't have to have the + variant.
          To get the none+ variant started I guess you have to remove the sanity check ("check wires") in MySensor.cpp (besides changing the transfer speed to 1Mbit in MyConfig.h).
          • S Squint
            O
            O
            olaeke
            @Squint I have problem with Ack and I have assumed that it has to do with the non + . I have a + variant on my gateway but non puls on my sensor node.
            • O olaeke
              Squint
              @olaeke I believe this is how I have mine setup as well.. Oddly enough both modules have the "+" printed on the chip but I cannot get the sensor code to initialize unless i take out the PVariant check. printDetails shows the following:
              Gateway:
              Data Rate = 2MBPS
              Model = nRF24L01+
              Sensor:
              STATUS = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
              RX_ADDR_P0-1 x00 = 0x0000000000 0x0000000000
              RX_ADDR_P2-5 x00 = 0x00 0x00 0x00 0x00
              TX_ADDR = 0x0000000000
              RX_PW_P0-6 x00 = 0x00 0x00 0x00 0x00 0x00 0x00
              EN_AA = 0x00
              EN_RXADDR x00 = 0x00
              RF_CH = 0x00
              RF_SETUP x00 = 0x00
              CONFIG = 0x00
              DYNPD/FEATURE x00 = 0x00 0x00
              Data Rate = 1MBPS
              Model = nRF24L01
              CRC Length = Disabled
              PA Power = PA_MIN
              The odd part is, on the sensor - all of the values in printDetails(); are 0's.. So I suspect I have something wired incorrectly?
              I've double & tripple checked the wiring..
              • S Squint
                Gateway:
                Data Rate = 2MBPS
                Model = nRF24L01+
                Sensor:
                EN_AA = 0x00
                RF_CH = 0x00
                RF_SETUP x00 = 0x00
                CONFIG = 0x00
                Data Rate = 1MBPS
                Model = nRF24L01
                PA Power = PA_MIN
                O
                O
                olaeke
                @Squint That seem even more tricky that the have printed + on the chip and then it still is non plus.
                I really don't remember now if I run the getstatus() on the sensor node or it was only on the gateway, but it sound strange that you get zeros on all information. The only thing I can think of is either is the radio broken or is there som more #define in the code you have to comment out the get the status info to print correctly.
                I will also remember that I had to fix some more issue in the code to get the non plus to work, I think a made a hack in the process method in the MySensor class, and still the acknowledge didn't work. But I'm not totally shure, I have had a lot of problem with my sensors and my Vera Edge.
                Yesterday I received my new radios (yes + variant) and my Ethernet shield. I have now replaced my radios, replaced the serial gateway with Ethernet (the serial port is not working on Vera Egde, good work Mi Casa Verde!) replaced all my hacked library code with fresh from MySensors.org and...
                NOW IT WORKS!
                I will take the old non plus radio and burn them in the garden tomorrow!
                FYI as sonicblaze wrote is Alice breaking point to give them bad feedback then they contact you within a week and offer you refund,.
                • O olaeke
                  NOW IT WORKS!
                  Squint
                  @olaeke It turns out mine were actually + models. I had the sensors wired incorrectly because I had SOFTSPI enabled.. Once I realized the correct pinout ( After about 3 days of trial/error/code-digging ) its now reporting the + as it should and the radios are working as intended.
                  • O olaeke
                    I have modified the excelent "ping/pong test" program from maniacbug so it compiles with the RF24 lib. that comes with MySensors 1.4
                    With this program it is very easy to test your radio if it works or maybe if it works bad (many timeouts) and you also get this info printed if it is a + or non + chip.
                    • Download attached zip
                    • Build ino file
                    • Uppload on two nodes
                    • Connect serial monitor (115200 baud)
                    • Press T in serial monitor and then you should se "
                      Now sending 29788...ok...Got response 29788, round-trip delay: 23"
                    For the printout of chip details you need to comment out #define MINIMAL in RF24_config.h. I also recommend comment SERIAL_DEBUG so you get less debuginfo on serial.
                    MySensorsPingPongTst.zip
                    MLs
                    • O olaeke
                      • Build ino file
                      MLs
                      @olaeke
                      I can not get it to work.
                      The pins I use on nRF24L01 + / nRF24L01
                      Arduino NRF24L01 Radio Ethernet module
                      GND GND
                      3.3V VCC
                      13 SCK
                      12 MISO
                      11 MOSI
                      6 CSN
                      5 CE
                      And what I get is this
                      RX_ADDR_P0-1 = 0x0000000000 0x0000000000
                      RX_ADDR_P2-5 = 0x00 0x00 0x00 0x00
                      RX_PW_P0-6 = 0x00 0x00 0x00 0x00 0x00 0x00
                      EN_AA = 0x00
                      EN_RXADDR = 0x00
                      RF_CH = 0x00
                      RF_SETUP = 0x00
                      CONFIG = 0x00
                      DYNPD/FEATURE = 0x00 0x00
                      Data Rate = 1MBPS
                      Model = nRF24L01
                      PA Power = PA_MIN
                      What am I doing wrong?
                      axillentA 1 Reply Last reply
                      • M MLs
                        @olaeke
                        GND GND
                        3.3V VCC
                        13 SCK
                        12 MISO
                        11 MOSI
                        6 CSN
                        5 CE
                        EN_AA = 0x00
                        EN_RXADDR = 0x00
                        RF_CH = 0x00
                        RF_SETUP = 0x00
                        CONFIG = 0x00
                        Data Rate = 1MBPS
                        Model = nRF24L01
                        PA Power = PA_MIN
                        axillentA
                        axillentA
                        axillent
                        @MLs what else is connected to arduino?
                        i had the same result yesterday trying to build ethernet gateway using ENC based shield. I'm faced a conflict between radio and ethernet
                        sense and drive
                        • axillentA axillent
                          MLs
                          wrote on last edited by MLs
                          #60
                          @axillent
                          Four Dallas temp sensor.
                          But what I am interested in is the model I have (nRF24L01 + / nRF24L01) and not to send / receive data.
                          • M MLs
                            @axillent
                            axillentA
                            axillentA
                            axillent
                            @MLs if you have original nordic you will see + for the plus version
                            sense and drive
                              MLs
                              @axillent
                              I bought them through the store available here at Mysensors
                              • M MLs
                                @axillent
                                axillentA
                                axillentA
                                axillent
                                @MLs it should be OK
                                the old version is out of production for years
                                sense and drive
                                M hekH 2 Replies Last reply
                                  MLs
                                  @axillent
                                  Possible, but now I wanted to read it out of the hardware to be sure.
                                  • M MLs
                                    @axillent
                                    axillentA
                                    axillentA
                                    axillent
                                    that is easy))) check wires
                                    sense and drive
                                      MLs
                                      @axillent
                                      As I wrote earlier, it is linked and I have also measured the cables to minimize errors.
                                      • M MLs
                                        @axillent
                                        axillentA
                                        axillentA
                                        axillent
                                        @MLs disconnect all from arduino
                                        connect radio as stated here http://www.mysensors.org/build/connect_radio
                                        get example GetStarted sketch from RF24 library and see the output
                                        it should be OK
                                        otherwise most probably the radio is broken
                                        sense and drive
                                          But they still seem to pop up. See a bit up in the thread.
