  3. Radio setup give: "check wires"
94 Posts 17 Posters 74.4k Views 3 Watching
  • B
    B
    boozz
    @olaeke
    Yes I got the non-plus versions to work at 1MBPS but the distance is much better with the +- version.
    Writing this I realize that I had a problem with the serial gateway. Somehow it needed a plus-version for this specific sketch to get the network running. Max distance in house approx. 6 meters (through walls, no line of Sight.
    Regards,
    Boozz
    • O
      O
      olaeke
      I can confirm that you can get non + variant to work on nodes but on the gateway you must have a + variant.
      But it is not worth the effort, if you have got non + variant from the China, throw them away and by new one (and cross your fingers that you get correct next time)
      S 1 Reply Last reply
      • sonicblazeS
        sonicblazeS
        sonicblaze
        I finally got some + versions from AliExpress. Plugged them in, and everything came to life immediately. Amazing what happens when you receive the right parts.
        • O olaeke
          Squint
          @olaeke Can you explain why the controller needs to be "+" ?
          If we follow the speed change from the post above, does it also effect the Controller speed?
          I've just managed to get a sensor going ( non+, via the hack here at 1MB ).. ( My Chip actually shows a +, but printDetails(); shows no +
          My Controller/Gateway also is supposed to be "+", however printDetails(); shows its not + either..
          Is there a chance, I have it setup wrong and it defaults to non+ in the printDetails() output?
          The Controller doest startup and say "Started!"..
          O 1 Reply Last reply
            You don't have to have the + variant.
            To get the none+ variant started I guess you have to remove the sanity check ("check wires") in MySensor.cpp (besides changing the transfer speed to 1Mbit in MyConfig.h).
            • S Squint
              O
              O
              olaeke
              @Squint I have problem with Ack and I have assumed that it has to do with the non + . I have a + variant on my gateway but non puls on my sensor node.
              • O olaeke
                Squint
                @olaeke I believe this is how I have mine setup as well.. Oddly enough both modules have the "+" printed on the chip but I cannot get the sensor code to initialize unless i take out the PVariant check. printDetails shows the following:
                Gateway:
                Data Rate = 2MBPS
                Model = nRF24L01+
                Sensor:
                STATUS = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
                RX_ADDR_P0-1 x00 = 0x0000000000 0x0000000000
                RX_ADDR_P2-5 x00 = 0x00 0x00 0x00 0x00
                TX_ADDR = 0x0000000000
                RX_PW_P0-6 x00 = 0x00 0x00 0x00 0x00 0x00 0x00
                EN_AA = 0x00
                EN_RXADDR x00 = 0x00
                RF_CH = 0x00
                RF_SETUP x00 = 0x00
                CONFIG = 0x00
                DYNPD/FEATURE x00 = 0x00 0x00
                Data Rate = 1MBPS
                Model = nRF24L01
                CRC Length = Disabled
                PA Power = PA_MIN
                The odd part is, on the sensor - all of the values in printDetails(); are 0's.. So I suspect I have something wired incorrectly?
                I've double & tripple checked the wiring..
                • S Squint
                  Gateway:
                  Data Rate = 2MBPS
                  Model = nRF24L01+
                  Sensor:
                  EN_AA = 0x00
                  RF_CH = 0x00
                  RF_SETUP x00 = 0x00
                  CONFIG = 0x00
                  Data Rate = 1MBPS
                  Model = nRF24L01
                  PA Power = PA_MIN
                  O
                  O
                  olaeke
                  @Squint That seem even more tricky that the have printed + on the chip and then it still is non plus.
                  I really don't remember now if I run the getstatus() on the sensor node or it was only on the gateway, but it sound strange that you get zeros on all information. The only thing I can think of is either is the radio broken or is there som more #define in the code you have to comment out the get the status info to print correctly.
                  I will also remember that I had to fix some more issue in the code to get the non plus to work, I think a made a hack in the process method in the MySensor class, and still the acknowledge didn't work. But I'm not totally shure, I have had a lot of problem with my sensors and my Vera Edge.
                  Yesterday I received my new radios (yes + variant) and my Ethernet shield. I have now replaced my radios, replaced the serial gateway with Ethernet (the serial port is not working on Vera Egde, good work Mi Casa Verde!) replaced all my hacked library code with fresh from MySensors.org and...
                  NOW IT WORKS!
                  I will take the old non plus radio and burn them in the garden tomorrow!
                  FYI as sonicblaze wrote is Alice breaking point to give them bad feedback then they contact you within a week and offer you refund,.
                  • O olaeke
                    NOW IT WORKS!
                    Squint
                    @olaeke It turns out mine were actually + models. I had the sensors wired incorrectly because I had SOFTSPI enabled.. Once I realized the correct pinout ( After about 3 days of trial/error/code-digging ) its now reporting the + as it should and the radios are working as intended.
                    • O olaeke
                      I have modified the excelent "ping/pong test" program from maniacbug so it compiles with the RF24 lib. that comes with MySensors 1.4
                      With this program it is very easy to test your radio if it works or maybe if it works bad (many timeouts) and you also get this info printed if it is a + or non + chip.
                      • Download attached zip
                      • Build ino file
                      • Uppload on two nodes
                      • Connect serial monitor (115200 baud)
                      • Press T in serial monitor and then you should se "
                        Now sending 29788...ok...Got response 29788, round-trip delay: 23"
                      For the printout of chip details you need to comment out #define MINIMAL in RF24_config.h. I also recommend comment SERIAL_DEBUG so you get less debuginfo on serial.
                      MySensorsPingPongTst.zip
                      MLs
                      • O olaeke
                        • Build ino file
                        MLs
                        @olaeke
                        I can not get it to work.
                        The pins I use on nRF24L01 + / nRF24L01
                        Arduino NRF24L01 Radio Ethernet module
                        GND GND
                        3.3V VCC
                        13 SCK
                        12 MISO
                        11 MOSI
                        6 CSN
                        5 CE
                        And what I get is this
                        RX_ADDR_P0-1 = 0x0000000000 0x0000000000
                        RX_ADDR_P2-5 = 0x00 0x00 0x00 0x00
                        RX_PW_P0-6 = 0x00 0x00 0x00 0x00 0x00 0x00
                        EN_AA = 0x00
                        EN_RXADDR = 0x00
                        RF_CH = 0x00
                        RF_SETUP = 0x00
                        CONFIG = 0x00
                        DYNPD/FEATURE = 0x00 0x00
                        Data Rate = 1MBPS
                        Model = nRF24L01
                        PA Power = PA_MIN
                        What am I doing wrong?
                        axillentA 1 Reply Last reply
                        • M MLs
                          @olaeke
                          GND GND
                          3.3V VCC
                          13 SCK
                          12 MISO
                          11 MOSI
                          6 CSN
                          5 CE
                          EN_AA = 0x00
                          EN_RXADDR = 0x00
                          RF_CH = 0x00
                          RF_SETUP = 0x00
                          CONFIG = 0x00
                          Data Rate = 1MBPS
                          Model = nRF24L01
                          PA Power = PA_MIN
                          axillentA
                          axillentA
                          axillent
                          @MLs what else is connected to arduino?
                          i had the same result yesterday trying to build ethernet gateway using ENC based shield. I'm faced a conflict between radio and ethernet
                          sense and drive
                          • axillentA axillent
                            MLs
                            wrote on last edited by MLs
                            #60
                            @axillent
                            Four Dallas temp sensor.
                            But what I am interested in is the model I have (nRF24L01 + / nRF24L01) and not to send / receive data.
                            • M MLs
                              @axillent
                              axillentA
                              axillentA
                              axillent
                              @MLs if you have original nordic you will see + for the plus version
                              sense and drive
                                MLs
                                @axillent
                                I bought them through the store available here at Mysensors
                                • M MLs
                                  @axillent
                                  axillentA
                                  axillentA
                                  axillent
                                  @MLs it should be OK
                                  the old version is out of production for years
                                  sense and drive
                                  M hekH 2 Replies Last reply
                                    MLs
                                    @axillent
                                    Possible, but now I wanted to read it out of the hardware to be sure.
                                    • M MLs
                                      @axillent
                                      axillentA
                                      axillentA
                                      axillent
                                      that is easy))) check wires
                                      sense and drive
                                        MLs
                                        @axillent
                                        As I wrote earlier, it is linked and I have also measured the cables to minimize errors.
                                        • M MLs
                                          @axillent
                                          axillentA
                                          axillentA
                                          axillent
                                          @MLs disconnect all from arduino
                                          connect radio as stated here http://www.mysensors.org/build/connect_radio
                                          get example GetStarted sketch from RF24 library and see the output
                                          it should be OK
                                          otherwise most probably the radio is broken
                                          sense and drive
