  3. Radio setup give: "check wires"
94 Posts 17 Posters 74.4k Views 3 Watching
  • axillentA axillent
    @MLs if you have original nordic you will see + for the plus version
    MLs
    @axillent
    I bought them through the store available here at Mysensors
    axillentA 1 Reply Last reply
    • M MLs
      @axillent
      axillentA
      axillentA
      axillent
      @MLs it should be OK
      the old version is out of production for years
      sense and drive
      M hekH 2 Replies Last reply
        MLs
        @axillent
        Possible, but now I wanted to read it out of the hardware to be sure.
        • M MLs
          @axillent
          axillentA
          axillentA
          axillent
          that is easy))) check wires
          sense and drive
            MLs
            @axillent
            As I wrote earlier, it is linked and I have also measured the cables to minimize errors.
            • M MLs
              @axillent
              axillentA
              axillentA
              axillent
              @MLs disconnect all from arduino
              connect radio as stated here http://www.mysensors.org/build/connect_radio
              get example GetStarted sketch from RF24 library and see the output
              it should be OK
              otherwise most probably the radio is broken
              sense and drive
                But they still seem to pop up. See a bit up in the thread.
                  axillentA
                  axillentA
                  axillent
                  @hek you knew from our conversation last night that I also got "check wires" and was ready to think that all my modules are the old ones
                  but finally my issue has nothing to do with version of the chip. It is exactly "check wires" issue and issue of the conflicts with other staff,
                  and my modules were purchased about two years ago
                  is it any confirmed case with the old version?
                  sense and drive
                  hekH 1 Reply Last reply
                    @axillent
                    Yep, if you look at the pictures above they're missing +
                      @axillent
                      axillentA
                      axillentA
                      axillent
                      @hek you are right
                      but it seams that only @sonicblaze is owner of this rare thing
                      sense and drive
                      O 1 Reply Last reply
                        @hek you are right
                        O
                        O
                        olaeke
                        @axillent And me! I started the thread so I have got 10 of the them, maybe something for the MySensors museum!
                        • O olaeke
                          axillentA
                          axillentA
                          axillent
                          hm. are the + is missing on top of the nordic chip?
                          it can be probably still used for mysensors in case of:
                          • switching data rate to 1Mbs or 2MBs (old version do not support 250Kbs - default to 1.4)
                          • comment out "check wires" check inside Mysensors library
                          sense and drive
                            O
                            O
                            olaeke
                            @axillent Yes there is no + on those.
                            I have tried using them but without success. I couldn't get them to work at all on the gateway but if I replaced the gateway with + variant and non + on the node then it "almost" worked. I couldn't get the "Auto Id" function to work. I think it has something with Ack to do, i will remember that I have read somewhere that the hardware ack is only implemented in the + variant.
                            • eimisE
                              eimisE
                              eimis
                              I'am a new one on this forum, and I've stepped on the same rake like others. So there are some recommendations for other newbies and questions for developers:
                              1. I've wasted some hours because this library uses serial baud rate 115200, not 9600, what is default for other projects - it should be mentioned in proper place, sorry, if it is, but I've not noticed it.
                              2. Next step for all users, that want to use this great project, should be sketch that outputs NRF24L01 version: my history is, that I've bought 10 NRF's from the same seller (alice***) 2-3 months ago, on chips there is "+" sign, but sketch says, that there is NRF24L01 without "+" :(
                              3. What to do for those unlucky, that bought wrong version: maybe it's possible to use these modules with some restrictions, while right modules will arrive? I saw recommendations about sensor node to change speed and comment out while()1) after "check cables", but what to do for gateway node?
                              4. I'm not a geek developer, maybe it is possible to use #define SOFTSPI in main sketch, before including other libraries? It would be simpler, than editing file RF24_config.h for gateway node and sensor node?
                              • eimisE eimis
                                It is mentioned at a few places on the main site. Anywhere particular place it is missing?
                                Unfortunately the Arduino IDE build system is f**cked up and does not allow this. But I agree that DEBUG and SOFTSPI would had been great to add in the sketch itself.
                                eimisE 1 Reply Last reply
                                  eimisE
                                  eimisE
                                  eimis
                                  I've started from "Building Ethernet Gateway" and finished on "MQTT Gateway", as I use OpenHAB as Controller.
                                  • m26872M
                                    m26872M
                                    m26872
                                    wrote on last edited by m26872
                                    #78
                                    Hm what's this? I haven't had time to test it yet, but it looks very suspicious. I'm pretty sure I ordered via MyS store on Jan 10 (soon after the Ali-links just were introduced). Is it worth the hassle to test or should I throw it straight into the garbage and order a new batch from a proven supplier (which one)?
                                    Bought it from here.
                                    axillentA slartiS 2 Replies Last reply
                                    • m26872M m26872
                                      axillentA
                                      axillentA
                                      axillent
                                      @m26872 this is most probably based on a Chinese clone of the nordic chip
                                      it could probably work
                                      At least nobody will charge you for the try :)
                                      sense and drive
                                      • m26872M m26872
                                        slartiS
                                        slartiS
                                        slarti
                                        @m26872 Didn't work for me. Please tell me how you do.
                                        "One is never alone with a rubber duck"
                                        • slartiS slarti
                                          axillentA
                                          axillentA
                                          axillent
                                          @slarti start from the RF24 example named GettingStarted
                                          connect wires according to hek's instruction http://www.mysensors.org/build/connect_radio
                                          sense and drive
                                          slartiS 1 Reply Last reply
