  3. Radio setup give: "check wires"
94 Posts 17 Posters 74.4k Views 3 Watching
    @axillent said:
    the old version is out of production for years
    But they still seem to pop up. See a bit up in the thread.
    axillentA
    axillentA
    axillent
    @hek you knew from our conversation last night that I also got "check wires" and was ready to think that all my modules are the old ones
    but finally my issue has nothing to do with version of the chip. It is exactly "check wires" issue and issue of the conflicts with other staff,
    and my modules were purchased about two years ago
    is it any confirmed case with the old version?
    sense and drive
    hekH 1 Reply Last reply
    • axillentA axillent
      @axillent
      Yep, if you look at the pictures above they're missing +
      axillentA 1 Reply Last reply
        @axillent
        axillentA
        axillentA
        axillent
        @hek you are right
        but it seams that only @sonicblaze is owner of this rare thing
        sense and drive
        O 1 Reply Last reply
          @hek you are right
          O
          O
          olaeke
          @axillent And me! I started the thread so I have got 10 of the them, maybe something for the MySensors museum!
          • O olaeke
            axillentA
            axillentA
            axillent
            hm. are the + is missing on top of the nordic chip?
            it can be probably still used for mysensors in case of:
            • switching data rate to 1Mbs or 2MBs (old version do not support 250Kbs - default to 1.4)
            • comment out "check wires" check inside Mysensors library
            sense and drive
              O
              O
              olaeke
              @axillent Yes there is no + on those.
              I have tried using them but without success. I couldn't get them to work at all on the gateway but if I replaced the gateway with + variant and non + on the node then it "almost" worked. I couldn't get the "Auto Id" function to work. I think it has something with Ack to do, i will remember that I have read somewhere that the hardware ack is only implemented in the + variant.
              • eimisE
                eimisE
                eimis
                I'am a new one on this forum, and I've stepped on the same rake like others. So there are some recommendations for other newbies and questions for developers:
                1. I've wasted some hours because this library uses serial baud rate 115200, not 9600, what is default for other projects - it should be mentioned in proper place, sorry, if it is, but I've not noticed it.
                2. Next step for all users, that want to use this great project, should be sketch that outputs NRF24L01 version: my history is, that I've bought 10 NRF's from the same seller (alice***) 2-3 months ago, on chips there is "+" sign, but sketch says, that there is NRF24L01 without "+" :(
                3. What to do for those unlucky, that bought wrong version: maybe it's possible to use these modules with some restrictions, while right modules will arrive? I saw recommendations about sensor node to change speed and comment out while()1) after "check cables", but what to do for gateway node?
                4. I'm not a geek developer, maybe it is possible to use #define SOFTSPI in main sketch, before including other libraries? It would be simpler, than editing file RF24_config.h for gateway node and sensor node?
                • eimisE eimis
                  It is mentioned at a few places on the main site. Anywhere particular place it is missing?
                  Unfortunately the Arduino IDE build system is f**cked up and does not allow this. But I agree that DEBUG and SOFTSPI would had been great to add in the sketch itself.
                  eimisE 1 Reply Last reply
                    eimisE
                    eimisE
                    eimis
                    I've started from "Building Ethernet Gateway" and finished on "MQTT Gateway", as I use OpenHAB as Controller.
                    • m26872M
                      m26872M
                      m26872
                      wrote on last edited by m26872
                      #78
                      Hm what's this? I haven't had time to test it yet, but it looks very suspicious. I'm pretty sure I ordered via MyS store on Jan 10 (soon after the Ali-links just were introduced). Is it worth the hassle to test or should I throw it straight into the garbage and order a new batch from a proven supplier (which one)?
                      Bought it from here.
                      axillentA slartiS 2 Replies Last reply
                      • m26872M m26872
                        axillentA
                        axillentA
                        axillent
                        @m26872 this is most probably based on a Chinese clone of the nordic chip
                        it could probably work
                        At least nobody will charge you for the try :)
                        sense and drive
                        • m26872M m26872
                          slartiS
                          slartiS
                          slarti
                          @m26872 Didn't work for me. Please tell me how you do.
                          "One is never alone with a rubber duck"
                          • slartiS slarti
                            axillentA
                            axillentA
                            axillent
                            @slarti start from the RF24 example named GettingStarted
                            connect wires according to hek's instruction http://www.mysensors.org/build/connect_radio
                            sense and drive
                            slartiS 1 Reply Last reply
                              slartiS
                              slartiS
                              slarti
                              @axillent I tried it and it worked with the modules but none of the MySensors example sketches work with them. Thread about it.
                              • slartiS slarti
                                axillentA
                                axillentA
                                axillent
                                @slarti what is the output from printDetails ?
                                is your chip recognized as NRF24L01+ or just NRF24L01?
                                sense and drive
                                  slartiS
                                  slartiS
                                  slarti
                                  @axillent That's the funny thing, they were recognized as NRF24L01+ but still refuse to work. I don't get "check wires". I just don't get anything.
                                  • slartiS slarti
                                    axillentA
                                    axillentA
                                    axillent
                                    @slarti getting nothing is already something)
                                    GettingStarted can be used to connect two arduinos. Have you tested this? You told that examples are working.
                                    sense and drive
                                      wrote on last edited by hek
                                      #86
                                      Might be possible to tweak initialization to get them to work. If someone has too much time on their hands this could be added as a new RFM73 driver in the development branch.
                                      http://forum.mysensors.org/topic/300/rfm73-experience/14
                                        slartiS
                                        slartiS
                                        slarti
                                        @axillent Yes, the pingpong sketch from @olaeke works after I import the MySensors library to the sketch and comment out
                                        //#include "nRF24L01.h" //#include "RF24.h"
                                        and
                                        #define MINIMAL from RF24_config.h
                                        None of the "normal" examples work or give anything over serial.
                                        axillentA O 2 Replies Last reply
                                        • slartiS slarti
                                          and
                                          axillentA
                                          axillentA
                                          axillent
                                          @slarti it is probably a limited set of configurable parameters are allowed for your chip
                                          you can investigate this but no success guaranteed
                                          sense and drive
