  3. Domoticz
  4. sonda PH
sonda PH
2 Posts 2 Posters 1.8k Views 2 Watching
    szybki946
    wrote on last edited by szybki946
    Hello, I'm sorry for my Anglish.
    I was looking for a connection of soda PH to domoticz. I found one project but it is old and it does not work. There is somebody able to do it, I'm sure it will not be useful to one.
    #include <Average.h>
    Average<float> sredniaPH(100); //średnia ze 100 pomiarów
    Serial.begin(9600);
    int Volty = analogRead(A7);
    float V =(float) Volty * 5.0 / 1024.0;
    float peha =(float) V*3.5;
    sredniaPH.push(peha);
    sredniaPH.mean();
    float pH =((float) sredniaPH.mean());
    Serial.println(pH);
      delay(1000)
    • N
      N
      nekitoss
      wrote on last edited by nekitoss
      Hi, @szybki946 !
      Code in your post is working or not?
      If yes - you want to someone modify it, so it will send your pH to domoticz from MySensors node?
      If yes - if you use nrf24l01+ radio - maybe you want this code:
      #define MY_NODE_ID 100 //set node fixed id
      #define MY_BAUD_RATE 9600 //set serial baud rate
      #define MY_RADIO_RF24 //if you use nrf24l01+
      #define PH_CHILD_ID 0
      MyMessage ph_msg(PH_CHILD_ID, V_PH);
        sendSketchInfo("PH_meter", "1.0");  // Send the sketch version information to the gateway and Controller
        present(PH_CHILD_ID, S_WATER_QUALITY, "average_ph");
        //Serial.begin(9600); //don't need it because of #define MY_BAUD_RATE 9600
        sredniaPH.mean();
        Serial.println(pH);
        send(ph_msg.set(pH, 2)); //2 = number of digits after comma
        wait(1000); //in mysensors do not use delay - use wait() or sleep()
      (change IDs, texts and numbers of digits after comma as you want)
