  3. 💬 Button size radionode with sensors swarm extension
atsha204aflashhumidityrf69lightuv lightbatterymysensortemperatureota
189 Posts 28 Posters 75.4k Views 25 Watching
  • pepsonP pepson
    Please share also layer describe...
    Failed load project to production.
    KoreshK
    KoreshK
    Koresh
    wrote on last edited by Koresh
    #167
    @pepson said in 💬 Button size radionode with sensors swarm extension:
    You mixed gerbers of the main board and adapter board.
    It is standard. If you really need it you can find layers description here
    https://goo.gl/Jv33Lb (Generated Gerber Files)
    Can you share your project file and file gerber with this specification
    No I can't. Have no time today, sorry.
    pepsonP 1 Reply Last reply
    • KoreshK Koresh
      pepsonP
      pepsonP
      pepson
      @koresh said in 💬 Button size radionode with sensors swarm extension:
      Can you explaine me more ? What can i do ?
      KoreshK 1 Reply Last reply
      • pepsonP pepson
        KoreshK
        KoreshK
        Koresh
        @pepson
        pcb2.* - main boards gerbers
        rfm69c_to_rfm69hc.* - adapter gerbers
        You need only main board gerbers
        • G
          G
          Gerator
          Hi @koresh I'm having problems with battery monitor. Trying to find out what's wrong, I have realiced that A6 analog reads from regulator output. So It allways reports 3,3V, isn't it?
          Also, I read that unregulated could go up to 6,5V. Wouldn't this destroy radio module? I think I'm missing something.
          • D
            diogoc
            Hi. Do you have unassembled pcbs to sell?
            • G Gerator
              KoreshK
              KoreshK
              Koresh
              @gerator Oh.. so sorry. It is new forum reporting system. Didn't saw your message.
              A6 reads unregulated voltage (3.5-6.5V) through divider (1/3). So it can't destroyed nothing.
              • D diogoc
                KoreshK
                KoreshK
                Koresh
                @diogoc I will try to find them. But all of components are 0402... :eyes:
                • bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @Koresh I still have a bunch of v1 boards that I never got to work because of power consumption (I presume). I thought I'd make one more attempt.
                  I tried bridging the jumper and I'm using a 2032 battery. Consumption varies between 2 and 4mA on different boards. On some boards it fluctuates a lot. The instructions above are not immediately clear. Do I have to remove the LDO AND capacitors as well?
                  • Y
                    Y
                    yury
                    @bjornhallberg
                    while measuring current draw , was there FDTI adapter connected also?
                    • Y yury
                      @bjornhallberg
                      bjornhallbergB
                      bjornhallbergB
                      bjornhallberg
                      wrote on last edited by bjornhallberg
                      #176
                      @yury No I ran them on just a 2032 battery at the time, just had it in an external battery holder. I also removed the LDO on one of the boards and bridged the two top pads, with no apparent effect.
                      Unless there is something wrong with my DMM.
                      alexsh1A 1 Reply Last reply
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @bjornhallberg I have the same v1 board you have with a sleeping power consumption being 5uA. I also have Si1132 sensor soldered and had some issues with power consumption initially as the standard Si1132 lib did not implement sleep function for this sensor.
                        1. what sensors do you have? Do they properly put to sleep? BH1760?
                        2. can you share the sketch?
                        3. removing the LDO will not help you to bring down consumption from 3mA. 3mA most likely mean your radio is not sleeping. Such consumption will kill CR2032 very quickly - no chance running the board on such consumption
                        4. did you try a different multimeter?
                        5. there could be a problem with one of the tantalum capacitor. @yury could you remind which one has to be removed please?
                        I suggest you start with 5)
                        • alexsh1A alexsh1
                          bjornhallbergB
                          bjornhallbergB
                          bjornhallberg
                          #178
                          @alexsh1 Thanks for the suggestions! Reassuring to know that you succeeded.
                          1. I haven't added any sensors so it's just the default ones.
                          2. https://github.com/EasySensors/ButtonSizeNode ... may need some cleaning up @Koresh or do we use v2 code for v1 sensor as well?
                          3. I thought as much ... damn. I'm using the CW version radio with the adapter plate. I also thought about the radio but unlike the NRF radio this one should work with no counterfeit units?
                          4. No my other DMM was out of batteries. Found my old crappy DMM and it says the same, ~2mA.
                          5. I did remove both caps and it's still at ~2mA.
                          You're probably right about something not sleeping. Or else I've done a horrible soldering job on the four radios I've attached so far. All four sensors behave pretty much the same.
                          Also, at least on Domoticz they changed things around now so you have to use V_LEVEL instead of V_LIGHT_LEVEL or what? https://www.domoticz.com/forum/viewtopic.php?t=18577 With V_LIGHT_LEVEL I get some incomprehensible percent value reported.
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @bjornhallberg
                            1. No - please double check the board. There are options for a few sensors. Which ones do you have. Sensors on board.
                            2. Code really depends on sensors on board you have.
                            3. This is not about counterfeit radio. Just radio NOT SLEEPING. That's it.
                            4. OK.
                            5. OK
                            First thing first. Let's deal with your sleeping problem.
                            Identify which sensors you have on board or post a good quality photo of the board.
                            Try to use minimum sketch (see commends below - choose the correct Mhz band):
                            and measure the current
                            #define MY_RADIO_RFM69
                            // Please use one!!!!!!
                            //#define MY_RFM69_FREQUENCY   RF69_433MHZ
                            //#define MY_RFM69_FREQUENCY   RF69_868MHZ
                            //#define MY_RFM69_FREQUENCY   RF69_915MHZ
                            #define MY_NODE_ID AUTO
                            #define MY_TRANSPORT_UPLINK_CHECK_DISABLED
                            #define MY_PARENT_NODE_ID 0
                            #include <BH1750.h> //Make sure you are using this one https://github.com/claws/BH1750
                            BH1750 lightMeter;
                            #include "SparkFun_Si7021_Breakout_Library.h"
                            Weather sensor;
                            #define SPIFLASH_BLOCKERASE_32K   0xD8
                            #define SPIFLASH_CHIPERASE        0x60
                            lightMeter.begin(BH1750::ONE_TIME_LOW_RES_MODE);
                              noInterrupts();
                              _flash.initialize();
                              _flash.sleep();
                              interrupts();
                            lux = lightMeter.readLightLevel();
                            Serial.print("Lux="); Serial.println(lux);
                            sleep(10000);
                            • bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              @alexsh1 I may have made a bit of a mistake with some glitchy chinese test probes. De-glitched cables and connected to a proper lab power supply gave very different readings (with the default git-sketch) ...
                              Still a bit confused over the differing readings. I get that the board I stripped from regulator and capacitors would perform better though. So do I have to do the same for all the other boards as well? Of course, I could save the worst performing boards for later and run them on 2xAA or something in places where space isn't an issue.
                              KoreshK alexsh1A 2 Replies Last reply
                                KoreshK
                                KoreshK
                                Koresh
                                Hi @bjornhallberg.
                                I've done many tests today with your code. All tested boards were the newer ones. So I completely had no ideas until I read your last message. Now all is clear for me. You have battery draining ~10-100ua, not 1-2mA. As I see your boards contain 107J capacitors. It was an absolutely failed batch of capacitors. We resoldered all of these capacitors on all the boards after we had found this problem with @alexsh1. Unfortunatelly some of these boards had been sent until we found this problem. We are so sorry you had to deal with these failed boards. I suggest I send you some new tested buttonsized v1 boards to you. Also I can send good capacitors to rework failed boards and some of my new interesting boards for free.
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @bjornhallberg @Koresh That's what I wrote a few posts above - start with the capacitors :-)
                                  My suggestion - get a decent DMM. Brymen BM235 or 121GW or any Fluke.
                                  Measuring a sleeping current is challenging and some unexpansive Chinese DMM manage it just really well. BUT! You do not want to waist your time just because your meter is crap and was completely off on some readings.
                                  • KoreshK Koresh
                                    Hi @bjornhallberg.
                                    bjornhallbergB
                                    bjornhallbergB
                                    bjornhallberg
                                    @koresh Package went under the "Postnord" radar! Woohoo, perfect! I will start replacing the old capacitors and finally be able to deploy the sensors. Very nice of you to include some product samples as well. Really excited about these sensors!
                                    • Christoph BlankC
                                      Christoph BlankC
                                      Christoph Blank
                                      Hi guys, quick question: I'm using a LiFePo4 3.2V battery directly on the board (sensors part removed).
                                      Somehow the battery percentage always shows 100 - how should I change the default code to make this work?
                                      Right now I'm using the code like here: https://github.com/EasySensors/ButtonSizeNode/blob/master/ButtonSizeNode.ino
                                      • Christoph BlankC Christoph Blank
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        @christoph-blank Hi, thanks for using this board. In the first version of this board the divider is conected after LDO, so you can't measure voltage above 3.3V. In the second version the divider is connected to the battery directly. You use 3.2v battery so it is not problem for you. But LiFePo4 battery has very flat discharge curve so it can be hard to read this level with reasonable accuracy.
                                        I will try to find LiFePo4 battery and add some piece of code soon. Yet you can play with followed code
                                          // Get the battery Voltage
                                          // 1M, 470K divider across battery and using internal ADC ref of 1.1V1
                                          /* The MySensors Lib uses internal ADC ref of 1.1V which means analogRead of the pin connected to 470kOhms Battery Devider reaches
                                           * 1023 when voltage on the divider is around 3.44 Volts. 2.5 volts is equal to 750. 2 volts is equal to 600.
                                           * RFM 69 CW works stable up to 2 volts. Assume 2.5 V is 0% and 1023 is 100% battery charge
                                           * RFM 69 HCW works stable up to 2.5 volts (sometimes it can work up to 2.0V). Assume 2.5 V is 0% and 1023 is 100% battery charge
                                           * 3.3V ~ 1023
                                           * 3.0V ~ 900
                                           * 2.5V ~ 750
                                           * 2.0V ~ 600
                                        #ifdef  MY_IS_RFM69HW
                                          int batteryPcnt = (sensorValue - 750)  / 1.5;
                                          int batteryPcnt = (sensorValue - 600)  / 3;
                                        Christoph BlankC 1 Reply Last reply
                                        • KoreshK Koresh
                                             * 3.3V ~ 1023
                                             * 3.0V ~ 900
                                             * 2.5V ~ 750
                                             * 2.0V ~ 600
                                          Christoph BlankC
                                          Christoph BlankC
                                          Christoph Blank
                                             * 3.3V ~ 1023
                                             * 3.0V ~ 900
                                             * 2.5V ~ 750
                                             * 2.0V ~ 600
                                          Thank you very much, what are the other differences between V1 and V2? I believe I have V1 but I'm not sure.
                                          The above code is what I currently use, and I removed the sensor part of the module. However, it shows 100% until the end (until it's not sending anymore).
                                          Looking forward to your tests!
                                          Christoph
