  3. voltage drop with bh1750fvi ?
7 Posts 4 Posters 1.2k Views 3 Watching
  • H
    H
    huex
    i create a lightsensor sketch with bh1750fvi, i found when power with CR2032, voltage from 2.9v drop to 2.4 or lower, but bh1750fvi required 2.4V, so sensor node can't continue , but later 3-5 seconds voltage recovery to 2.9v
    ATMEGA328P-U-TH+ nrf24l01-smd with Customized PCB, Are there any good suggestions for solving this problem? thanks!
    rozpruwaczR YveauxY 2 Replies Last reply
    • H huex
      rozpruwaczR
      rozpruwaczR
      rozpruwacz
      @huex try with new battery
      H 1 Reply Last reply
      • rozpruwaczR rozpruwacz
        H
        H
        huex
        wrote on last edited by huex
        @rozpruwacz yes,but new battery also drop 0.4-0.5v like this ,:disappointed_relieved: , this is new battery offer by Two weeks ago., use it on si7021 node,work well, so 。。。。
        • H huex
          @huex said in voltage drop with bh1750fvi ?:
          bh1750fvi
          Supply current of this sensor is 190uA, sleep current only 1 uA. Are you sure this sensor is put to sleep when not operating it (when your node is sleeping)?
          Are you using a GY-30 module? These seem to have a voltage regulator on board to support 5v supply levels. Try to bypass this regulator when powering from batteries.
          • H
            H
            huex
            @Yveaux thank you ,
            i create a pcb with bh1750fvi chip,
            i use multimeter measure bh1750fvi v+ pin and gnd ,when power on battery from 2.9v drop 2.1v ,and 3-5 seconds ,up to 2.9v, use a new battery NANFU cr2032, also 3.1 drop to 2.7v,
            sleep all is ok , when sleep 7.3ua
            but, when down 2.4v bh1750 no work....so。。。i don't how to do,
              @huex
              coincell internal resistance is higher than others batteries.
              so when your mcu is not sleeping or waking up, you'll get voltage drop (even a few mA drained by mcu will drop voltage like you noticed)
              To fix voltage drop and extend lifetime:
              • use good brand coincells (significantly better specs and lifetime than nonames)
              • add a few(2-3) 100uF close to battery pins for buffering, you can even add one close to the radio module.
              • use wait() or sleep() in your sketch before reading your sensor (to allow voltage recover)
              • you can also use 1Mhz clock for mcu, to use less power when it's not sleeping
              • use a sensor with better voltage range
              • and so on..
              • scalzS scalz
                @huex
                • and so on..
                H
                H
                huex
                @scalz
                ok ,thanks , i follow your suggestion to Give it a try,,thank you ,:+1:
