  3. Problem with sensors on arduino and domoticz
27 Posts 4 Posters 3.7k Views 4 Watching
  • H Offline
    H Offline
    hyperflemme
    wrote on last edited by Nca78
    Hi everyone,
    to begin I want to apologize for my level of English, I am French. ;)
    I have a problem, i have an arduino mega 2560 and i want associate him with a rasberry pi 3 using an USB cable. into my arduino i have plugged lot of sensors (Motion sensor PIR sensor V1.0; DHT11 sensor; O2 sensor, CO2 censor and light sensor). I have use this gateway for associate him:
    * Copyright (C) 2013-2019 Sensnology AB
    * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
    * The gateway accepts input on serial which will be sent out on radio network.
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
    * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_RF24_CE_PIN 49
    #define MY_RF24_CS_PIN 53
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    juste after i have connected my arduino card into my rasberry pi3
    and she recognized the arduino card. so i put an motionsensor example like this:
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    // #define MY_DEBUG
    uint32_t SLEEP_TIME = 500; // Sleep time between reports (in milliseconds)
    // Initialize motion message
        present(CHILD_ID, S_MOTION);
        // Read digital motion value
        bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        Serial.println(tripped);
    my rasberry card does not recognize my sensor, can you help me?
    • N Offline
      N Offline
      can you please :
      • tell us what controller you are using, and if your gateway was successfully added to it, with gateway responding to the controller ?
      • enable debug mode in your sensor sketch (remove // before "#define MY_DEBUG" line) and tell us what you see in the log ?
      H 2 Replies Last reply
      • B Offline
        B Offline
        bjacobse
        Domoticzs guide, do you have the mysensors gateway defined in Domoticz?
        https://www.domoticz.com/wiki/MySensors
        • B Offline
          B Offline
          bjacobse
          in a shell try to type "dmesg |grep tty"
          then there should be something that shows that a ttyUSB0 or ttyUSB1 devices is attached
          • K Offline
            K Offline
            kimot
            Do you connect your sensor to the same mega2560 which works like serial gateway or are you using different mega2560 connected through radio to serial gateway mega2560?
            H 1 Reply Last reply
            • N Nca78
              can you please :
              H Offline
              H Offline
              hyperflemme
              @nca78 Hi,
              I use an arduino mega 2560, the gateway was successfully added on arduino.
              for MYDEBUG i will test this today
              • K kimot
                H Offline
                H Offline
                hyperflemme
                @kimot I have only 1 arduino, i have put the gateway into this card.
                K 1 Reply Last reply
                • N Nca78
                  can you please :
                  H Offline
                  H Offline
                  hyperflemme
                  @nca78 Hi,
                  Look this and help me please. sketch for motion sensor.
                  N 1 Reply Last reply
                  • H hyperflemme
                    @nca78 Hi,
                    N Offline
                    N Offline
                    @hyperflemme you can check the log using the log parser
                    https://www.mysensors.org/build/parser
                    Here it says it cannot connect to parent, is you gateway active, and on the same radio channel ?
                    • N Nca78
                      H Offline
                      H Offline
                      hyperflemme
                      @nca78 what do you mean by log parser?
                      i just have put a gateway usb into arduino.
                      • N Nca78
                        H Offline
                        H Offline
                        hyperflemme
                        • H hyperflemme
                          N Offline
                          N Offline
                          @hyperflemme as you can read "no potential parents replied to find parent request". It means no gateway replied to the radio calls.
                          Please describe your full mysensors installation if you want help :
                          • controller used ?
                          • board, radio used for gateway ?
                          • board, radio used for sensor ?
                          • H hyperflemme
                            K Offline
                            K Offline
                            kimot
                            @hyperflemme
                            Than in your second sketch ( with sensors )
                            is missing.
                            This sketch works like normal node without this, not as gateway with sensors connected.
                            • N Nca78
                              • controller used ?
                              H Offline
                              H Offline
                              hyperflemme
                              @nca78 Hi,
                              I just have an nrf24l01 plug into my arduino.
                              I miss something to make it work?
                              Thank's for helping me
                              • K kimot
                                @hyperflemme
                                is missing.
                                H Offline
                                H Offline
                                hyperflemme
                                @kimot in my sketch for motion sensor you think i just have to had #define MY_GATEWAY_SERIAL on the top of the program?
                                Thank's for your help
                                • H hyperflemme
                                  N Offline
                                  N Offline
                                  @hyperflemme said in Problem with sensors on arduino and domoticz:
                                  The arduino that is connected to computer with USB should have #define MY_GATEWAY_SERIAL yes, so it will behave as a gateway and send the data to the computer. You need to configure it in your controller (home automation software) also.
                                  If you have 1 gateway (arduino + radio) connected to computer + 1 sensor (arduino + radio) separated then the sensor should not have this #define.
                                  • N Nca78
                                    H Offline
                                    H Offline
                                    hyperflemme
                                    @nca78 all my sensor are connected on the arduino card with nRF24L01, and the arduino card is connected by usb on my computer. I want tu connect the arduino card at an raspberry pi 3 but she don't recognise arduino card and sensor, however i have put the gateway and sketch of sensor into the arduino card....
                                    • H hyperflemme
                                      N Offline
                                      N Offline
                                      @hyperflemme what controller software are you using on the raspberry pi ?
                                      • N Nca78
                                        H Offline
                                        H Offline
                                        hyperflemme
                                        @nca78 Linux on raspberry pi 3 with domoticz
                                        • H hyperflemme
                                          N Offline
                                          N Offline
                                          @hyperflemme did rebuild the gateway script with #define MY_GATEWAY_SERIAL ?
                                          Then did you add the gateway in the hardware tab of domoticz ?
                                          12.2k
