  3. Esp8266 gateway with RFM69 433
6 Posts 4 Posters 1.8k Views 4 Watching
  • Q
    Q
    quby
    wrote on last edited by quby
    Hi guys!
    I'm new here, and I have no working node from mysensors, so I decided to get start with it. The first step would be to build a gateway, but at this point I already stuck.
    I wannna build the gateway from a Wemos D1 mini, this version:
    https://www.aliexpress.com/item/Wemos-D1-Mini-V3-0-0-WIFI-Internet-of-Things-Development-Board-Based-ESP8266-CH340-CH340G/32863498073.html?spm=a2g0s.9042311.0.0.13a74c4dyadZID
    and RFM69HW. The wireing is based on this:
    https://www.mysensors.org/build/connect_radio#rfm6995-&-esp8266
    The arduino IDE enviorment is working, and I try to compile this sketch:
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
     * See https://www.mysensors.org/build/connect_radio for wiring instructions.
     * If you are using a "barebone" ESP8266, see
     * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
     * Inclusion mode button:
     * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ // Set your frequency here
    #define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_RFM69_IRQ_PIN D1
    #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
    #define MY_RFM69_CS_PIN D8 // NSS. Use MY_RFM69_SPI_CS for older versions (before 2.2.0)
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    // Enable these if your MQTT broker requires username/password
    #define MY_MQTT_USER "mqtt_user"
    #define MY_MQTT_PASSWORD "xxxxxxxx"
    // Set WIFI SSID and password
    #define MY_WIFI_SSID "SSID"
    #define MY_WIFI_PASSWORD "xxxxxxxxx"
    //#define MY_HOSTNAME "mqtt-sensor-gateway"
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 30, 2
    //MQTT broker if using URL instead of ip address.
    // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
    #define MY_PORT 1883
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN D2  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  D3  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  D4  // the PCB, on board LED
    #include <ESP8266WiFi.h>
    The sketch is compiled OK, and the gateway is started, and I see in the router log, that is connected to my wifi, but that's all. It is not connect to my mqtt broker, but it should, and based on the serial log the radio doesnt start eiter...
    serial log is only this:
    MCO:BGN:INIT GW,CP=RRNGE---,REL=255,VER=2.3.1
    119 TSF:LRT:OK
    16:10:32.200 -> 135 TSM:INIT
    16:10:32.200 -> 148 TSF:WUR:MS=0
    After 2 restart out of 10 probe I see the wifi connection in the serial log but not always.
    What should I do? What am doing wrong? I'm a little dissapointed after 3 days of playing....
    TheoLT 1 Reply Last reply
    • Q quby
      Hi guys!
       * LED purposes:
      119 TSF:LRT:OK
      TheoLT
      TheoLT
      TheoL
      @quby Looks to me as if the radio is not correctly connected. Because I'd expect more lines in the serial log. You could check:
      • Whether wiring is correct.
      • Whether the radio can get the power it needs
      In most cases it's either one of these. But no expert on the MQTT gateway. Also share a photo of how you've connected everything. Because people can't help if they can't see what you're ding.
      • Q
        Q
        quby
        2_1546706672234_IMG_20190105_172531.jpg 1_1546706672234_IMG_20190105_172457.jpg 0_1546706672233_IMG_20190105_172451.jpg
        Hopefully you can see the wireing on the picture. I used as the same wire coloring as on the coloring page!
        I can measure 3,59V between the red and the black wire on the radio chip. The esp board get the power from my computers usb port.
        • R
          R
          Ryanmt
          I have this setup. Try
          #define MY_RFM69_IRQ_PIN D2
          Copy the wiring from here (or better still just buy some PCB's)
          https://www.openhardware.io/view/277/ESP8266-RFM69HW-gateway-with-dipole-antenna
          • C
            C
            canossa
            I tried the same type of connection, but I have a lot of problems because the power is not enough for the esp8266 and rfm69 at the same time!
            You should have a separate power supply for the radio.
            R 1 Reply Last reply
            • C canossa
              R
              R
              Ryanmt
              wrote on last edited by Ryanmt
              @canossa That's useful to know, I am finding it to be hit and miss with this setup too. Seem to randomly lose messages going back to my MQTT gateway (most annoying for door triggers!). i'll try adding in an additional power supply to the 3.3v line and see if that helps out with stability.
