  3. The opposite of presenting a child?
4 Posts 2 Posters 933 Views 2 Watching
  • alowhumA
    alowhumA
    alowhum
    I'm working on a 433Mhz signal cloner. This device learns new 433Mhz signals, and then allows the user to replay signals.
    For each new copied ON/OFF signal pair I want to present a binary switch to the controller. That works fine.
    But the user also has the ability to delete the last copied signal.
    In this case I would like to tell the controller to remove (or display as disabled) the related switch.
    Looking through the API I didn't see any 'internal signal' to do so. But perhaps there is a way?
    • alowhumA
      alowhumA
      alowhum
      Are there no clever hacks for this?
        If your controller supports scripting, perhaps you can have a special child using that sends child id to delete?
        • alowhumA
          alowhumA
          alowhum
          That's an interesting idea, thanks. Perhaps I could also make two children that contain the numeric count of how many devices are operational.
          Would this be something that could be relevant to build into MySensors?
