  3. problem with RF24 and switching relays
2 Posts 2 Posters 793 Views 2 Watching
    MHofer
    wrote on last edited by MHofer
    I have a problem with nodes that switch a relay, after switching the relay, the node is often no longer accessible and thus the relay is no longer switchable the error message is:
    2019-02-10 17:01:33.737 Error: MySensors: Command not received by Node !! (node_id: 11, child_id: 4)
    I have the problem with several knots independently of each other
    MySensor 2.3
    components:
    L7805CV
    Nano V3.0 ATmega 328 Board CH340
    NRF24L01+
    NRF24L01+ Breakout Modul
    4 Kanal Relais 5V
    YveauxY 1 Reply Last reply
    • M MHofer
      MySensor 2.3
      components:
      L7805CV
      NRF24L01+
      4 Kanal Relais 5V
      YveauxY
      YveauxY
      @mhofer The serial log of the node might reveal what's going on with the node.
      It could very well be the inductive kick from switching the relay that resets or hangs your node.
      How is everything connected?
