  3. Push-button not working
3 Posts 3 Posters 657 Views 3 Watching
  • G Offline
    G Offline
    geronimo
    Re: [💬 Door](Window and Push-button Sensor)
    I build this setup for a push-button and it works very well. But as soon as I connect it to my doorbell push button it doesn't function anymore. It doesn't register that I push the doorbell-button. Only very occasionaly (like 1 in 50 pushes).
    The only difference I can see is that the doorbell-button has significant longer wires (like 4 meters x 2) and that the wires are thicker. Originally the button was used with 8V 1A AC transformator.
    Anyone suggestions what I can do to make it working?
    Regards,
    Jeroen
    • G geronimo
      Regards,
      Jeroen
      @geronimo can you measure the resistance of the wires (using a multimeter) when the button is pressed? If the resistance is larger than about 5kohm, you'll need a weaker pullup.
      • skywatchS Offline
        skywatchS Offline
        skywatch
        If the door bell push button is outside then it is likely the contacts are not too good - that is why the original bell probably used 24 or higher voltage (likely AC) to overcome this.
        Take the cover off the button and lightly sand or file the contacts until you have shiny metal again. Do the same with the screws and wires that are held by the screws. Finally, give it a spray of wd40 and reassemble. Test again. Hopefully it will work now.
        If you do not feel confident doing that a new door bell push button is probably not that expensive and you would only need to clean the wires where they meet the contacts.
        Finally, be careful with the wires. Electricians leave little extra and they will very likely be solid core and can break easily.
