  3. MYSbootloader not rebooting, help
6 Posts 3 Posters 1.3k Views 2 Watching
  • mythbaiM
    mythbaiM
    mythbai
    wrote on last edited by mythbai
    I'm new to this OTA wireless programming. I've made some Mysensors working for a year or so. But before I fully implement other more complicated sensors in my home, I need to get this OTA working. Currently I'm testing the latest code from github version 1.3.0-rc1. Everything seems working ok, except the rebooting.
    The bootloader is custom compiled with Radio on channel #1, and Gateway in serial mode with Radio channel set to 1 as well. Whenever I send reboot command though MYScontroller, it's just not triggering note enter rebooting mode, and I have to physically reset the Mini Pro for it to start requesting firmware version.
    Here is the log shown in MYSController Debug:
    4/9/2019 12:39:01	TX	1;0;3;0;13;0
    4/9/2019 12:39:02	RX	0;255;3;0;9;12729500 !TSF:MSG:SEND,0-0-1-1,s=0,c=3,t=13,pt=0,l=1,sg=0,ft=0,st=NACK:0
    Anyone has the same problem? Can all of you rebooting node smoothly?
    tekkaT 1 Reply Last reply
    • mythbaiM mythbai
      tekkaT
      tekkaT
      tekka
      @mythbai Looks like the node is not actively listening for incoming commands. Please post the full node sketch and node debug log for troubleshooting.
      • mythbaiM
        mythbaiM
        mythbai
        Here is my node's sketch, hmm... I wonder if it has to do with the sleep function.
        #include <OneWire.h>
        * Version 1.0 - Henrik Ekblad
        * Motion Sensor example using HC-SR501
        * http://www.mysensors.org/build/motion
        // Enable debug prints
        //#define MY_DEBUG
        #define MY_RF24_CHANNEL (1)
        //#define MY_NODE_ID 3
        #define LIGHT_SENSOR_ANALOG_PIN 0 // analogue LDR sensor read PIN
        #define DIGITAL_MOTION_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
        #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
        #define MAX_ATTACHED_DS18B20 8
        #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
        // light sensor configuration
        #define REF_RESISTANCE            10030  // measure this for best result
        #define MAX_ADC_READING           1023
        #define LUX_CALC_SCALAR           42208480
        #define LUX_CALC_EXPONENT         -1.5395
        DallasTemperature tempSensors(&oneWire); // Pass the oneWire reference to Dallas Temperature.
        int lastLightLevel;
        int numTempSensors=0;
        bool receivedConfig = false;
        bool metric = true;
        // Id of the children sensors
        #define CHILD_ID_MOTION 0
        #define CHILD_ID_LIGHT 1
        #define CHILD_ID_TEMP_BASE 2
        // Initialize messages
        MyMessage msg_m(CHILD_ID_MOTION, V_TRIPPED);
        MyMessage msg_l(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
        MyMessage msg_t(CHILD_ID_TEMP_BASE,V_TEMP);
        void before()
          tempSensors.begin();
          pinMode(DIGITAL_MOTION_SENSOR, INPUT);      // sets the motion sensor digital pin as input
          tempSensors.setWaitForConversion(false);
          sendSketchInfo("Composite Sensor", "1.0");
          numTempSensors = tempSensors.getDeviceCount();
          // Present all temperature sensors to controller
          for (int i=0; i<numTempSensors && i<MAX_ATTACHED_DS18B20; i++) {
            present(i + CHILD_ID_TEMP_BASE, S_TEMP);
          present(CHILD_ID_MOTION, S_MOTION);
          int ldrRawData;
          float ldrResistance;
          int16_t ldrLux;
          // Read digital motion value
          bool tripped = digitalRead(DIGITAL_MOTION_SENSOR) == HIGH;
          Serial.println(tripped);
          send(msg_m.set(tripped?"1":"0"));  // Send tripped value to gw
          // Read analog LDR value
          ldrRawData = analogRead(LIGHT_SENSOR_ANALOG_PIN);
          // convert ldrReading to LDR resistance
          ldrResistance = (float)(MAX_ADC_READING-ldrRawData) / ldrRawData * REF_RESISTANCE;
          // LDR_LUX
          ldrLux = LUX_CALC_SCALAR * pow(ldrResistance, LUX_CALC_EXPONENT);
          Serial.println(ldrLux);
          if (ldrLux != lastLightLevel) {
            send(msg_l.set(ldrLux));
            lastLightLevel = ldrLux;
          tempSensors.requestTemperatures();
          int16_t conversionTime = tempSensors.millisToWaitForConversion(tempSensors.getResolution());
          wait(conversionTime);
            float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?tempSensors.getTempCByIndex(i):tempSensors.getTempFByIndex(i)) * 10.)) / 10.;
            Serial.print("Temperature: ");
            Serial.println(temperature);
            #if COMPARE_TEMP == 1
            #else
              send(msg_t.setSensor(i + CHILD_ID_TEMP_BASE).set(temperature,1));
            sleep(digitalPinToInterrupt(DIGITAL_MOTION_SENSOR), CHANGE, SLEEP_TIME);
        • mythbaiM
          mythbaiM
          mythbai
          Now I uploaded a simple Blink sketch, which is a modified version adding wdt_reset(). The reason I added wdt_reset() is if I don't, the node will just reboot by itself.
          Still I'm having trouble have MYScontroller to reboot the node remotely.
          Here is the sketch of my Blink.
          #include <avr/wdt.h>
          // the setup function runs once when you press reset or power the board
            // initialize digital pin LED_BUILTIN as an output.
            pinMode(LED_BUILTIN, OUTPUT);
            wdt_disable();
            wdt_enable(WDTO_4S);
          // the loop function runs over and over again forever
            digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
            delay(1000);                       // wait for a second
            digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
            wdt_reset();
          Any idea why the node won't reboot?
          • mythbaiM mythbai
              wdt_disable();
              wdt_reset();
            @mythbai when sleeping, the radio is off so the node will not notice any incoming messages.
            Delay will block all processing on the node, including processing of incoming messages. So when in delay(), the node will not notice incoming messages.
            Documentation: https://www.mysensors.org/download/sensor_api_20#waiting
            https://www.mysensors.org/download/sensor_api_20#sleeping
            Depending on your use case, smartsleep might be what you need.
            • mythbaiM
              mythbaiM
              mythbai
              @mfalkvidd You're absolutely right! smartsleep() still won't make it reboot though. But I finally made it working.
              The "OTA wireless programming" tutorial and default sample firmware "Blink" doesn't allow the node to be rebootable. I added MySensors.h into the Blink sketch and defined basic configuration made the node rebootable. Loaded up some other basic MySensor sample node also works as long as I'm not using sleep().
              I originally thought the MYSBootloader will not be impacted by the firmware itself. I guess I'm wrong. It seems reboot function is post bootup and will rely on the loaded firmware to intepret the I_REBOOT command which is in the Mysensors library.
              I'm very new to the arduino programming and Mysensors, so please pardon my ignorance. Anyway, I'm very happy this forum gave me some momentum to move forward!
