  3. BMP180 suddenly disconnects from my I2C bus after a few minutes
3 Posts 2 Posters 673 Views 2 Watching
  • 5 Offline
    5 Offline
    5H34d
    Hello guys, I have a problem regarding my BMP180 sensor.
    When I restart my Pi everything is fine: I can see my BMP180 on my I2C bus (using i2cdetect) and the scripts I made work as intended.
    After a few minutes though, my BMP180 suddenly disappears from my I2C bus and the scripts return an I/O error.
    Can anyone help me? Thanks in advance!
    • skywatchS Offline
      skywatchS Offline
      skywatch
      Firstly check and re-mate all the contacts. Reflow the solder if it looks suspect under a magnifying glass.
      Second, measure voltage at the pi. What power supply are you using and what power cable to the pi?
      This would be the first things I would do in this situation.
      • 5 Offline
        5 Offline
        5H34d
        Thank you for your quick response.
        I changed every wire and even tried it with another sensor - still the same problem.
        The voltage at the pi is 3.3V. I noticed that the problem occured after I changed the pull-up resistor of the 1-wire bus from 4k7 to 2k2 (before that everything worked as intended).
        Is there any intern pull-up resistor that I need to change or turn off/on?
