NODE NOT REG - Node not registered?
I've seen this pattern on a few of my nodes.
I will present the sketch and everything seems to be going ok at first. But as soon as I start presenting children I get "NODE NOT REG".
The delay between radio sends is already at 400 milliseconds. Giving the radio some breathing space usually solves any issues I have.
What is 'node registration'? I had a look in the MySensors code. Does this mean the node needs to get an ID from the controller first?
// Looking at it further, I suspect there's something wrong with the send command.
I tried changing this:
send(buttonmsg.setSensor(replayableID).set( loadState(replayableID) )); wait(RADIO_DELAY);To this:
boolean state = loadState(replayableID); send(buttonmsg.setSensor(replayableID).set( state?false:true )); wait(RADIO_DELAY); // Tell the controller in what state the lock is.But no luck.
Then I tried moving the send() commands out of the presentation function. Perhaps it only allows presentation commands. But no luck there either.
25 TSM:INIT 31 TSF:WUR:MS=10000 38 TSM:INIT:TSP OK 40 TSF:SID:OK,ID=5 43 TSM:FPAR 78 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: 141 TSF:MSG:READ,4-4-5,s=255,c=3,t=8,pt=1,l=1,sg=0:1 146 TSF:MSG:FPAR OK,ID=4,D=2 571 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0 575 TSF:MSG:FPAR OK,ID=0,D=1 2085 TSM:FPAR:OK 2086 TSM:ID 2087 TSM:ID:OK 2089 TSM:UPL 2126 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1 2132 TSF:MSG:READ,0-0-5,s=255,c=3,t=25,pt=1,l=1,sg=0:1 2138 TSF:MSG:PONG RECV,HP=1 2141 TSM:UPL:OK 2142 TSM:READY:ID=5,PAR=0,DIS=1 2147 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100 2153 TSF:MSG:READ,0-0-5,s=255,c=3,t=15,pt=6,l=2,sg=0:0100 2160 TSF:MSG:SEND,5-5-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1 2168 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0 2179 TSF:MSG:READ,0-0-5,s=255,c=3,t=6,pt=0,l=1,sg=0:M PRESENTATION 2186 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=OK:Signal Hub 2195 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1 2604 TSF:MSG:SEND,5-5-0-0,s=1,c=0,t=36,pt=0,l=13,sg=0,ft=0,st=OK:Device status Detectable child ID 10 3414 TSF:MSG:SEND,5-5-0-0,s=10,c=0,t=0,pt=0,l=10,sg=0,ft=0,st=OK:Detected 1 recog loadState at presentation: 0 3821 !MCO:SND:NODE NOT REG Detectable child ID 11 4228 TSF:MSG:SEND,5-5-0-0,s=11,c=0,t=0,pt=0,l=10,sg=0,ft=0,st=OK:Detected 2 recog loadState at presentation: 0 4635 !MCO:SND:NODE NOT REG Detectable child ID 12 5042 TSF:MSG:SEND,5-5-0-0,s=12,c=0,t=0,pt=0,l=10,sg=0,ft=0,st=OK:Detected 3 recog loadState at presentation: 0 5449 !MCO:SND:NODE NOT REG -
The entire node is quite huge. But here's the relevant parts.
I am now looking into the progmem char array.
PROGMEM const char detectedMessage[] = { "Detected " }; // This construction saves some memory. PROGMEM const char replayMessage[] = { "Replay " }; // This construction saves some memory. boolean resend_button_states = 1; void presentation() { Serial.println(F("PRESENTATION")); sendSketchInfo(F("Signal Hub"), F("1.1"), 1); wait(RADIO_DELAY); // Child 0. Sends the sketch version information to the gateway and Controller present(DEVICE_STATUS_ID, S_INFO, F("Device status")); wait(RADIO_DELAY); // Child 1. This outputs general status details. send(textmsg.setSensor(DEVICE_STATUS_ID).set( F("Hi") )); wait(RADIO_DELAY); //present(LISTENER_OUTPUT_ID, S_INFO, F("Detected codes")); wait(RADIO_DELAY); // Child 2. This outputs the ID of detected signals that were matched to signals in eeprom. #if !(defined(HAS_TOUCH_SCREEN)) present(LEARN_SIMPLE_BTN_ID, S_BINARY, F("Recognise a single code")); wait(RADIO_DELAY);// Child 3 present(LEARN_ON_OFF_BTN_ID, S_BINARY, F("Recognise an ON+OFF code")); wait(RADIO_DELAY); // Child 4 present(COPYING_SIMPLE_BTN_ID, S_BINARY, F("Copy a single code")); wait(RADIO_DELAY); // Child 5 present(COPYING_ON_OFF_BTN_ID, S_BINARY, F("Copy an ON/OFF code")); wait(RADIO_DELAY); // Child 6 #endif char childNameMessage[11]; strcpy_P(childNameMessage, detectedMessage); // We loop over all the detect-only signals, and present them to the controller. Their Child ID's are between 10 and 99. for( byte recognisedID=10; recognisedID < 10 + (amountOfStoredSignals - amountOfStoredReplayableSignals); recognisedID++ ){ Serial.print(F("Detectable child ID ")); Serial.println(recognisedID); childNameMessage[9] = recognisedID + 39; // (recognisedID - 10) + 49; present(recognisedID, S_DOOR, childNameMessage); wait(RADIO_DELAY); } wait(RADIO_DELAY); strcpy_P(childNameMessage, replayMessage); // We loop over all the replayable signals, and present them to the controller. Their child ID's are between 100 and 200. for( byte replayableID=100; replayableID < 100 + amountOfStoredReplayableSignals; replayableID++ ){ Serial.print(F("Replayable child ID ")); Serial.println(replayableID); childNameMessage[7] = (replayableID - 100) + 49; present(replayableID, S_BINARY, childNameMessage); wait(RADIO_DELAY); } resend_button_states = 1; } void send_all_button_states(){ Serial.println(F("Sending button states")); // We loop over all the replayable signals, and send their values. for( byte replayableID=10; replayableID < 10 + amountOfStoredReplayableSignals; replayableID++ ){ Serial.print(F("replay loadState at presentation: ")); Serial.println(loadState(replayableID)); if( loadState(replayableID) > 1 ){ saveState(replayableID, 0); } boolean state = loadState(replayableID); send(buttonmsg.setSensor(replayableID).set( state?false:true )); wait(RADIO_DELAY); // Tell the controller in what state the child is. } wait(RADIO_DELAY); // We loop over all the detect-only signals, and send their values. for( byte recognisedID=100; recognisedID < 100 + (amountOfStoredSignals - amountOfStoredReplayableSignals); recognisedID++ ){ send(detectmsg.setSensor(recognisedID).set( 0 )); wait(RADIO_DELAY); // Tell the controller in what state the child is. } void loop() { if( resend_button_states ){ resend_button_states = 0; send_all_button_states(); } } -
I removed the last send() message from the presentation function, and now it seems to work.
Apparently the presentation function only eats presentation messages. Better put: it seems like after that function is done, MySensors sends a "register" command, and only after that can you then send updates for the children to it.
