  3. Multisensor with DSB18B20 and relay
3 Posts 3 Posters 572 Views 3 Watching
  • K
    K
    kvn298
    Hello, i want to build an Multisensor with 4 DS18b20 temperaturesensors and one relay. The hardware works and i copy/pasted the code from the examples. The temperature readings works fine. But the relay does not recognize every message to change the state.
    Here is my Code:
    #define MY_RADIO_RF24
    #define MY_NODE_ID 11
    #include <OneWire.h>
    #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected
    unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
      for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
      sensors.begin();
      sendSketchInfo("Temperature Sensor", "1.1");
      for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++)
         present(i, S_TEMP);
            present(sensor, S_BINARY);
      wait(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      wait(SLEEP_TIME);
        if (message.type==V_STATUS) {
            // Change relay state
            digitalWrite(message.sensor-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
    i changed the sleep into wait but when i sent an command from my fhem to the sensor the relay does not switch any time.
    Can anybody help me?
    K 1 Reply Last reply
    • K kvn298
      Here is my Code:
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
           present(i, S_TEMP);
          #else
        wait(SLEEP_TIME);
      K
      K
      kimot
      wrote on last edited by kimot
      @kvn298
      Each sensor must have unique child ID.
      Your presentation:
      DS18B20 ID=0 to max number of DS18B20
      Relay ID=1
      So second DS have got the same ID like relay.
      • rejoe2R
        rejoe2R
        rejoe2
        The same ChildID most likely isn't the cause for the missed relay commands, but the "wait" instructions. IMO the code should be changed to a "non blocking loop". Search the web for that keywords or have al look at https://www.mysensors.org/build/pulse_water as an example within the MySensors framework.
