  3. Dynamic change of variable name
14 Posts 7 Posters 1.9k Views 6 Watching
  • G
    G
    Greg_2502
    Hi, I can't find a solution to my problem.
    I'd like to change the name in a function in a for loop. If it is possible?
    for (i=1; i<5; i++){
    int value[i] = debouncer[i].read();
    YveauxY 1 Reply Last reply
    • alowhumA
      alowhumA
      alowhum
      Not to my knowledge.
      Generally you'd create a function that takes an input value, and change that?
      • G Greg_2502
        YveauxY
        YveauxY
        @greg_2502 do you mean to fill an array?
        Something like
        int value[5];
        skywatchS 1 Reply Last reply
        • YveauxY Yveaux
          Something like
          int value[5];
          skywatchS
          skywatchS
          skywatch
          @yveaux Shouldn't that be int value[4]; ? ;)
          • skywatchS skywatch
            @skywatch not if the 0th position is skipped
              skywatchS
              skywatchS
              skywatch
              @mfalkvidd Hehehe...... ;)
              But i starts at 1 yes? and then increments in interger units whilst it is less than 5. So that should give 1,2,3,4. Or have I been under a misunderstanding?
                @skywatch arrays indexes in c/c++ always start at 0.
                int myarray[5] would have positions 0 thorugh 4. Position 5 would be outside the array. In the code above, position 0 is never used.
                So either make the array 1 element larger than actually needed (with position 0 unused), or let i start at 0:
                int value[4];
                for (i=0; i<4; i++){
                Sergio RiusS skywatchS 2 Replies Last reply
                  int value[4];
                  Sergio RiusS
                  Sergio RiusS
                  Sergio Rius
                  wrote on last edited by Sergio Rius
                  @mfalkvidd said in Dynamic change of variable name:
                  In fact, I interpreted it more like @skywatch
                  Notice the <=
                   int value[5];
                   for (i=1; i<=5; i++){
                  I just made something like this for indexing sensors in a node, where idx 0 was the node itself, and thus already filled before the loop.
                  • Sergio RiusS Sergio Rius
                    Notice the <=
                     int value[5];
                    YveauxY
                    YveauxY
                    @sergio-rius said in Dynamic change of variable name:
                    Notice the <=
                    That will cause a buffer overrun at the end again...
                    skywatchS Sergio RiusS 2 Replies Last reply
                    • YveauxY Yveaux
                      Notice the <=
                      skywatchS
                      skywatchS
                      skywatch
                      @yveaux Can you please explain why as I want to learn why it won't run the code the way I expected it to! -
                        int value[4];
                        skywatchS
                        skywatchS
                        skywatch
                        @mfalkvidd That won't get '0 through 4' as it will never produce i=4 in this case. I would expect it to need to be
                        int value[4];
                        for (i=0; i<=4; i++){
                        in order to get 0 through 4 (note the extra '=' in line 2 above to make this work. Or am I still misunderstanding something? ???
                        • YveauxY Yveaux
                          Notice the <=
                          Sergio RiusS
                          Sergio RiusS
                          Sergio Rius
                          It's as easy as trying it.
                          @yveaux said in Dynamic change of variable name:
                          Really? I can't see why a loop trough 1, 2, 3, 4 could overflow a 5 elements array.
                          In my code, I manually add 0 (the device itself, for vcc) before entering the loop. So in this case, still 5 elements.
                          badmannenB 1 Reply Last reply
                            badmannenB
                            badmannenB
                            badmannen
                            @sergio-rius
                            the loop will run even at "5".
                            that is the problem. if you write "i<5" , then it would be ok
                            rPi 3 - UNO R3 - Mini - Nano - custom
                            • Sergio RiusS
                              Sergio RiusS
                              Sergio Rius
                              @badmannen @Yveaux You're absolutely right. I was lazy, only changed a symbol and gave a bad advice. My response should be changed to <=4.
                              Still I don't understand what the original question was.
