  3. Dynamic change of variable name
14 Posts 7 Posters 1.9k Views 6 Watching
  • skywatchS skywatch
    @yveaux Shouldn't that be int value[4]; ? ;)
    @skywatch not if the 0th position is skipped
    skywatchS 1 Reply Last reply
      skywatchS
      skywatchS
      skywatch
      @mfalkvidd Hehehe...... ;)
      But i starts at 1 yes? and then increments in interger units whilst it is less than 5. So that should give 1,2,3,4. Or have I been under a misunderstanding?
        @skywatch arrays indexes in c/c++ always start at 0.
        int myarray[5] would have positions 0 thorugh 4. Position 5 would be outside the array. In the code above, position 0 is never used.
        So either make the array 1 element larger than actually needed (with position 0 unused), or let i start at 0:
        int value[4];
        for (i=0; i<4; i++){
          value[i] = debouncer[i].read();
        Sergio RiusS skywatchS 2 Replies Last reply
          int value[4];
          Sergio RiusS
          Sergio RiusS
          Sergio Rius
          @mfalkvidd said in Dynamic change of variable name:
          In fact, I interpreted it more like @skywatch
          Notice the <=
           int value[5];
           for (i=1; i<=5; i++){
          I just made something like this for indexing sensors in a node, where idx 0 was the node itself, and thus already filled before the loop.
          • Sergio RiusS Sergio Rius
            Notice the <=
             int value[5];
            @sergio-rius said in Dynamic change of variable name:
            Notice the <=
            That will cause a buffer overrun at the end again...
            skywatchS Sergio RiusS 2 Replies Last reply
            • YveauxY Yveaux
              Notice the <=
              skywatchS
              skywatchS
              skywatch
              @yveaux Can you please explain why as I want to learn why it won't run the code the way I expected it to! -
                int value[4];
                skywatchS
                skywatchS
                skywatch
                @mfalkvidd That won't get '0 through 4' as it will never produce i=4 in this case. I would expect it to need to be
                int value[4];
                for (i=0; i<=4; i++){
                in order to get 0 through 4 (note the extra '=' in line 2 above to make this work. Or am I still misunderstanding something? ???
                • YveauxY Yveaux
                  Notice the <=
                  Sergio RiusS
                  Sergio RiusS
                  Sergio Rius
                  It's as easy as trying it.
                  @yveaux said in Dynamic change of variable name:
                  Really? I can't see why a loop trough 1, 2, 3, 4 could overflow a 5 elements array.
                  In my code, I manually add 0 (the device itself, for vcc) before entering the loop. So in this case, still 5 elements.
                  badmannenB 1 Reply Last reply
                    badmannenB
                    badmannenB
                    badmannen
                    @sergio-rius
                    the loop will run even at "5".
                    that is the problem. if you write "i<5" , then it would be ok
                    rPi 3 - UNO R3 - Mini - Nano - custom
                    • Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      @badmannen @Yveaux You're absolutely right. I was lazy, only changed a symbol and gave a bad advice. My response should be changed to <=4.
                      Still I don't understand what the original question was.
