  3. Arduino Pro Mini and Mini W5100 LAN Ethernet Shield
8 Posts 3 Posters 1.2k Views 4 Watching
  • giangiredG Offline
    giangiredG Offline
    giangired
    Hallo. I would like to use a gateway based on Mini W5100 Ethernet shield with no Radio module: is it feasible?
    I have connected the devices as indicated in MySensor but I cannot reach my Controller (Domoticz over Raspberry PI).
    The output of serial debug is
    0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 !TSM:INIT:TSP FAIL
    13 TSM:FAIL:CNT=1
    14 TSM:FAIL:DIS
    16 TSF:TDI:TSL
    10018 TSM:FAIL:RE-INIT
    10020 TSM:INIT
    10027 !TSM:INIT:TSP FAIL
    10029 TSM:FAIL:CNT=2
    10031 TSM:FAIL:DIS
    10033 TSF:TDI:TSL
    20036 TSM:FAIL:RE-INIT
    20038 TSM:INIT
    20044 !TSM:INIT:TSP FAIL
    20046 TSM:FAIL:CNT=3
    20048 TSM:FAIL:DIS
    20050 TSF:TDI:TSL
    Any help?
    • giangiredG giangired
      4 TSM:INIT
      5 TSF:WUR:MS=0
      13 TSM:FAIL:CNT=1
      14 TSM:FAIL:DIS
      16 TSF:TDI:TSL
      10020 TSM:INIT
      10031 TSM:FAIL:DIS
      10033 TSF:TDI:TSL
      20038 TSM:INIT
      20048 TSM:FAIL:DIS
      20050 TSF:TDI:TSL
      Any help?
      @giangired yes. Just remove the #define for the radio if you don't want a radio.
      giangiredG 1 Reply Last reply
        giangiredG Offline
        giangiredG Offline
        giangired
        @mfalkvidd thanks. Removing the define for radio the output says TSP NA, why?
          @giangired because there is no transport. In MySensors lingo, transport is how multiple MySensors nodes communicate with eachother. Supported transports are nrf24, rfm69, rs485 and a few more. Since you only have one node, no transport is needed.
            giangiredG Offline
            giangired
            Thanks for clarify. So, why my raspberry pi domoticz don't see the gateway? If I try to ping the ethernet gateway i cannot reach it. Ma there any ping test to be used?
              @giangired I don't know. Could you share the sketch you are using, the debug output of the gateway, what configuration you are using in Domoticz and the domoticz debug log? Maybe we can help spot what's wrong.
              • S Offline
                sparky60
                I am having the same issue using a NANO and Mini 5100. If anybody has some working code, would you please share. I can get everything working if I use a UNO instead of NANO. The NANO and 5100 shows up on my network but is not talking to MySensors. I am trying to integrate into VERA.
                Thank you.
                  giangiredG Offline
                  giangired
                  @mfalkvidd Solved, it was my mistake on wiring. Thanks.
