  3. MQTT gateway issues nrf2401 +W5100 +Arduino Mega
8 Posts 4 Posters 740 Views 4 Watching
  • L Offline
    L Offline
    loc73
    hello everbody, i am a new with my sensors devices and i try to use MQTT gateway with Rpi broker (mosquitto)
    i try to program MQTT gateway with
    • NRF2401 device
    • Arduino Mega
    • ethernet shield W5100 bought on aliexpress
      Shield ethernet
    i alreday modify the power supply of the NRF2401 with adding 10µF parallel 100nF capacitors between GND and +3.3V
    after thta i can ping the gateway with cmd window and i see on the log ( see below) that MQTT connection is OK so i conclude that the ethernet part is OK.
    i took arduino's code on my sensors web site:
    gateway code
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    //#define MY_DEBUG_VERBOSE_RF24
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
    #define MY_SOFTSPI
    #define MY_SOFT_SPI_SCK_PIN 52
    #define MY_SOFT_SPI_MISO_PIN 50
    #define MY_SOFT_SPI_MOSI_PIN 51
    //#endif
    //#ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 49
    //#endif
    //#ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 53
    //#endif
    // Enable these if your MQTT broker requires username/password
    //#define MY_IP_ADDRESS 192,168,1,82
    #define MY_MAC_ADDRESS 0xA8, 0x61, 0x0A, 0xAE, 0x15, 0xEC
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,60
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 62
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <Ethernet.h>
    the compilation and programmation of arduino mega is correct but when i looked the serial port to see the debug i have many lines of informations and i do not see information from my temperature and humidity sensor
    I do not see where is the problem
    0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    18 MCO:REG:NOT NEEDED
    4926 GWT:TPC:IP=192.168.1.82
    5928 MCO:BGN:STP
    5931 MCO:BGN:INIT OK,TSP=0
    6484 GWT:TPC:IP=192.168.1.82
    7487 GWT:RMQ:MQTT RECONNECT
    7494 GWT:RMQ:MQTT CONNECTED
    7497 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
    7503 TSM:READY:NWD REQ
    10251 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    10258 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10263 !TSF:MSG:LEN=0,EXP=7
    10265 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10270 !TSF:MSG:LEN=0,EXP=7
    10273 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10277 !TSF:MSG:LEN=0,EXP=7
    10280 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10285 !TSF:MSG:LEN=0,EXP=7
    10288 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10293 !TSF:MSG:LEN=0,EXP=7
    10296 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10300 !TSF:MSG:LEN=0,EXP=7
    10303 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10308 !TSF:MSG:LEN=0,EXP=7
    10310 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10315 !TSF:MSG:LEN=0,EXP=7
    10317 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10322 !TSF:MSG:LEN=0,EXP=7
    10326 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    10330 !TSF:MSG:LEN=0,EXP=7
    10333 TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    i try to change mysensors librairies but it did not work
    can you help me ? i have no solution for my problem .
    thank you very much for your help
    • L loc73
      • NRF2401 device
      • Arduino Mega
        Shield ethernet
      gateway code
       * LED purposes:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
      #define MY_SOFTSPI
      //#endif
      //#endif
      //#endif
      4 TSM:INIT
      5 TSF:WUR:MS=0
      11 TSM:INIT:TSP OK
      13 TSM:INIT:GW MODE
      5928 MCO:BGN:STP
      Hi @loc73, welcome to the MySensors community!
      Could you post the debug log from your dht node? Did you use this sketch without modifications? If not, please post the modified sketch also. What type of Arduino are you using for the dht node?
      • L Offline
        L Offline
        loc73
        hello, thank you very much for the quick answer.
        i programmed my DHT node with the sketch that you given. below you can see the log of the node.
        the MQTT gateway is switch on during the recording.
        i build my sensors with arduino nano and DHT 11.
        i ordered electronic boards from this web site MY RFX. i am sure of the node because when i program a serial gateway with the same MEGA + NRF2401 i can see datas on serial monitor.
        the shield w5100 is ok because i used the same to send MQTT datas to the my brokers and i can see datas on the right topic.
        the only thing not very clean is i used 5cm wires to connect NRF2401 on arduino MEGA, maybe i will try to reduce the length of these wires.
        one more time thank you very much for your help.
        Insert Co
         __  __       ____
                |___/                      2.3.1
        16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
        26 TSM:INIT
        27 TSF:WUR:MS=0
        34 TSM:INIT:TSP OK
        35 TSM:FPAR
        38 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2046 !TSM:FPAR:NO REPLY
        2049 TSM:FPAR
        2051 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4059 !TSM:FPAR:NO REPLY
        4061 TSM:FPAR
        4063 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6071 !TSM:FPAR:NO REPLY
        6073 TSM:FPAR
        6075 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        8083 !TSM:FPAR:FAIL
        8084 TSM:FAIL:CNT=1
        8086 TSM:FAIL:DIS
        8088 TSF:TDI:TSL
        18091 TSM:FAIL:RE-INIT
        18093 TSM:INIT
        18099 TSM:INIT:TSP OK
        18101 TSM:FPAR
        18104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        20112 !TSM:FPAR:NO REPLY
        20114 TSM:FPAR
        20116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        22124 !TSM:FPAR:NO REPLY
        22126 TSM:FPAR
        22129 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        24136 !TSM:FPAR:NO REPLY
        24138 TSM:FPAR
        24140 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        26148 !TSM:FPAR:FAIL
        26150 TSM:FAIL:CNT=2
        26151 TSM:FAIL:DIS
        26153 TSF:TDI:TSL
        36157 TSM:FAIL:RE-INIT
        36159 TSM:INIT
        36165 TSM:INIT:TSP OK
        36167 TSM:FPAR
        36170 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        38178 !TSM:FPAR:NO REPLY
        38180 TSM:FPAR
        38182 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        40192 !TSM:FPAR:NO REPLY
        40194 TSM:FPARde Here
        the sketch programmed
         * Version 1.0: Henrik EKblad
        // Enable debug prints
        //#define MY_RS485
        #include <DHT.h>
        #define DHT_DATA_PIN 3
        // Set this offset if the sensor has a permanent small offset to the real temperatures.
        // In Celsius degrees (as measured by the device)
        #define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 10000;
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        DHT dht;
          sendSketchInfo("TemperatureAndHumidity", "1.1");
          present(CHILD_ID_HUM, S_HUM);
          dht.readSensor(true);
          if (isnan(temperature)) {
            lastTemp = temperature;
            // apply the offset before converting to something different than Celsius degrees
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            Serial.println(temperature);
          } else {
            nNoUpdatesTemp++;
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
          } else {
            nNoUpdatesHum++;
          sleep(UPDATE_INTERVAL);
        • L loc73
          Insert Co
           __  __       ____
                  |___/                      2.3.1
          26 TSM:INIT
          27 TSF:WUR:MS=0
          34 TSM:INIT:TSP OK
          35 TSM:FPAR
          2049 TSM:FPAR
          4061 TSM:FPAR
          6073 TSM:FPAR
          8083 !TSM:FPAR:FAIL
          8084 TSM:FAIL:CNT=1
          8086 TSM:FAIL:DIS
          8088 TSF:TDI:TSL
          18093 TSM:INIT
          18101 TSM:FPAR
          20114 TSM:FPAR
          22126 TSM:FPAR
          24138 TSM:FPAR
          26151 TSM:FAIL:DIS
          26153 TSF:TDI:TSL
          36159 TSM:INIT
          36167 TSM:FPAR
          38180 TSM:FPAR
          //#define MY_RS485
          #include <DHT.h>
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT dht;
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
            } else {
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
            } else {
              nNoUpdatesHum++;
          @loc73 the sketches look ok.
          Most common reason for failed communi ation is unstable power to the nrf24. How is it powered (on both nodes)? What capacitors are you using?
          If you haven't already, see https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help for a flowchart that covers how to troubleshoot the most common problems.
          • MasMatM Offline
            MasMatM Offline
            MasMat
            I had weird problems as well. My W5100 module was at fault.
            One module needed resistors and one didn't. I never figured out the problem. I also had what seemed a good ethernet but weird connection problems.
            Check this thread out, just in case it helps.
            https://forum.arduino.cc/index.php?topic=351477.msg3215306#msg3215306
            • L Offline
              L Offline
              loc73
              thank you very much for the answer, i will try your advice and i will make a return of experience.
              Y 1 Reply Last reply
              • L loc73
                Y Offline
                Y Offline
                @loc73 I have an identical (?) ethernet shield that requires pullup of the SD SS line for the nRF24 module to work correctly.
                On an Arduino Uno (to which the shield stacks on top), the SD_SS_PIN connects to pin 4.
                Therefore I added the following code to my gateway sketch:
                #define SD_SS_PIN                     (4)  // chip-select for SD card (unused, pull high!)
                void before() {
                    pinMode(SD_SS_PIN, OUTPUT);
                    digitalWrite(SD_SS_PIN, HIGH);
                Yours would probably connect to a different pin, but idea is the same.
                • L Offline
                  L Offline
                  loc73
                  @Yveaux i try your advice to add pull up resistor in my code and it works immediately!!!!!!
                  THANK YOU VERY MUCH !!!!!!
                  i will never find the solution without your help.
                  @MasMat @mfalkvidd thank you too i keep in mind th flowvhart and resistors on the ethernet connector for next issues......
                  12.1k
