  3. NRF24 init problem
NRF24 init problem
3 Posts 2 Posters 521 Views 2 Watching
  • raptorjrR Offline
    raptorjrR Offline
    raptorjr
    I have a problem with my NRF24(kind of always had some problems). I have the kind where you can see the IC, not any blob. So I hope they are genuine.
    I have a temperature sensor that worked for a couple of weeks, and then all of a sudden stopped to work. Now I have connected everything so I can see the debug output and get this:
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
    26 TSM:INIT
    28 TSF:WUR:MS=0
    34 !TSM:INIT:TSP FAIL
    36 TSM:FAIL:CNT=1
    37 TSM:FAIL:DIS
    39 TSF:TDI:TSL
    10041 TSM:FAIL:RE-INIT
    10043 TSM:INIT
    10049 !TSM:INIT:TSP FAIL
    10051 TSM:FAIL:CNT=2
    10053 TSM:FAIL:DIS
    10055 TSF:TDI:TSL
    20058 TSM:FAIL:RE-INIT
    20060 TSM:INIT
    20066 !TSM:INIT:TSP FAIL
    20068 TSM:FAIL:CNT=3
    20070 TSM:FAIL:DIS
    20072 TSF:TDI:TSL
    30075 TSM:FAIL:RE-INIT
    I've seen that before and therefore tried to change the NRF24 module to another one. But it didn't work. So just to test I rigged up a testbench with another Arduino and only connected the NRF24, and none of the modules that I have left is working as it should. And the spares I had have only been laying in a box. I don't understand what could be wrong? Can all of them die without ever being used?
    Y 1 Reply Last reply
    • raptorjrR raptorjr
      26 TSM:INIT
      28 TSF:WUR:MS=0
      36 TSM:FAIL:CNT=1
      37 TSM:FAIL:DIS
      39 TSF:TDI:TSL
      10043 TSM:INIT
      10053 TSM:FAIL:DIS
      10055 TSF:TDI:TSL
      20060 TSM:INIT
      20070 TSM:FAIL:DIS
      20072 TSF:TDI:TSL
      Y Offline
      Y Offline
      @raptorjr obvious errors could be cabling, power stability and power level.
      Hard to say and think along without a detailed description of your setup (which arduino, how is everything connected). I hope you didn't power the nrf24 with 5v...
      raptorjrR 1 Reply Last reply
      • Y Yveaux
        raptorjrR Offline
        raptorjrR Offline
        raptorjr
        @yveaux In my outdoor tempsensor everything was working for a while. And to avoid any problems with the initial setup I put a Nano on a breadboard with only the nrf24 connected.
        The first setup could have had some issues that I don’t know of, but strange that my test setup have the same problems? That should have avoided any hidden problems to test everything again in a new setup.
        And Arduino runs on 5V and nrf24 on 3.3V.
        Is there any other way to check the function of a nrf24? Maybe some other sketch that is not mysensor but able to verify the nrf24 works. I need to try to narrow down the problem because it seems strange that all 4 are broken.
