  3. Trouble w NodeMCU "TSP FAIL"
4 Posts 2 Posters 392 Views 2 Watching
  • N
    N
    nodethecollector
    Noob here, so I tried to do my due diligence before posting
    My goal is to use NodeMCU as wireless gateway to connect to Home Assistant on a Pi. I would also to use this NodeMCU as a Relay Actuator, but we are not there yet-- I'm having trouble getting NodeMCU to successfully get set up as a gateway.
    It seems like the NodeMCU is successfully connecting to my network... it's being assigned a local IP address which I can ping, and it shows up on my router's list of connected devices.
    From what I have searched, the error messages indicate there's an issue connecting with the radio. That confuses me, because the NodeMCU has the radio connected... there are no wires for me to mess up.
    Below is my sketch and the info from the serial monitor. (I redacted my SSID and password, no other changes made)
    Am I missing something? Thank you!
    SKETCH
     * Version 1.0 - Henrik Ekblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
     * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
     * See https://www.mysensors.org/build/connect_radio for wiring instructions.
     * If you are using a "barebone" ESP8266, see
     * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
     * Inclusion mode button:
     * - Connect GPIO5 (=D1) via switch to GND ('inclusion switch')
    #define MY_BAUD_RATE 9600
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "SSID"
    #define MY_WIFI_PASSWORD "PASS"
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "Gateway_MySensors"
    //#define MY_IP_ADDRESS 10,0,0,171
    //#define MY_IP_GATEWAY_ADDRESS 10,0,0,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    SERIAL MONITOR
    MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
    19:18:17.296 -> 124 TSF:LRT:OK
    19:18:17.296 -> 139 TSM:INIT
    19:18:17.296 -> 153 TSF:WUR:MS=0
    19:18:17.329 -> 176 !TSM:INIT:TSP FAIL
    19:18:17.363 -> scandone
    19:18:17.363 -> state: 0 -> 2 (b0)
    19:18:17.398 -> state: 2 -> 3 (0)
    19:18:17.398 -> state: 3 -> 5 (10)
    19:18:17.431 -> add 0
    19:18:17.431 -> aid 5
    19:18:17.431 -> cnt
    19:18:17.431 ->
    19:18:17.431 -> connected with <SSID>, channel 6
    19:18:17.466 -> dhcp client start...
    19:18:17.501 -> 343 TSM:FAIL:CNT=1
    19:18:17.535 -> 363 TSM:FAIL:DIS
    19:18:17.535 -> 380 TSF:TDI:TSL
    19:18:19.229 -> ip:10.0.0.171,mask:255.255.255.0,gw:10.0.0.1
    19:18:27.338 -> pm open,type:2 0
    19:18:27.542 -> 10398 TSM:FAIL:RE-INIT
    19:18:27.575 -> 10422 TSM:INIT
    19:18:27.610 -> 10443 !TSM:INIT:TSP FAIL
    19:18:27.610 -> 10469 TSM:FAIL:CNT=2
    19:18:27.643 -> 10491 TSM:FAIL:DIS
    19:18:27.677 -> 10510 TSF:TDI:TSL
    19:18:37.697 -> 20530 TSM:FAIL:RE-INIT
    19:18:37.697 -> 20554 TSM:INIT
    19:18:37.731 -> 20574 !TSM:INIT:TSP FAIL
    19:18:37.765 -> 20600 TSM:FAIL:CNT=3
    19:18:37.765 -> 20622 TSM:FAIL:DIS
    19:18:37.800 -> 20642 TSF:TDI:TSL
    19:18:47.835 -> 30662 TSM:FAIL:RE-INIT
    19:18:47.835 -> 30686 TSM:INIT
    19:18:47.869 -> 30706 !TSM:INIT:TSP FAIL
    19:18:47.903 -> 30732 TSM:FAIL:CNT=4
    19:18:47.903 -> 30754 TSM:FAIL:DIS
    19:18:47.937 -> 30774 TSF:TDI:TSL
    19:18:57.934 -> 40794 TSM:FAIL:RE-INIT
    19:18:57.968 -> 40818 TSM:INIT
    19:18:58.002 -> 40838 !TSM:INIT:TSP FAIL
    19:18:58.036 -> 40864 TSM:FAIL:CNT=5
    19:18:58.036 -> 40886 TSM:FAIL:DIS
    19:18:58.070 -> 40906 TSF:TDI:TSL
    19:19:08.077 -> 50926 TSM:FAIL:RE-INIT
    19:19:08.111 -> 50950 TSM:INIT
    19:19:08.111 -> 50970 !TSM:INIT:TSP FAIL
    19:19:08.144 -> 50996 TSM:FAIL:CNT=6
    19:19:08.179 -> 51018 TSM:FAIL:DIS
    19:19:08.179 -> 51038 TSF:TDI:TSL
    • N nodethecollector
      SKETCH
       * LED purposes:
      SERIAL MONITOR
      19:18:17.431 -> cnt
      19:18:17.431 ->
      Welcome to the MySensors community @nodethecollector
      The nodemcu does indeed have a radio "built-in". However, that radio is for wifi connections. Most MySensors networks use a different radio for communication between the sensor nodes and the gateway.
      https://www.mysensors.org/about/components#the-radio might give a better view if you haven't read it already.
      Which radio to use is set by this part of the sketch:
      If you don't want to attach a radio (for now), just change the sketch to
      //#define MY_RADIO_RF24
      This will make your gateway a lone node in its MySensors network, since it can't communicate with other nodes. Which is fine if you want it to function as a relay actuator only. When you want to build more nodes, you can select a radio type and connect radio modules to the node(s) and the gateway and update the sketches to reflect your choice of radio.
      • N
        N
        nodethecollector
        @mfalkvidd wow, thank you for your help! I totally misunderstood the radio scenario.
        I uploaded my "Gateway + Relay Actuator" sketch and updated the radio section as you suggested. We are connected! I can ping the node.
        Now my challenge is getting connected to Home Assistant on my Pi. I'm thinking I need to do some permissions work within HA/Pi.
        Thank you!
        SKETCH
        #define MY_WIFI_PASSWORD "Pass"
        #define MY_HOSTNAME "MySensors_Gateway2"
        #define MY_NODE_ID 1
        #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
        void before()
          for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
            present(sensor, S_BINARY);
          if (message.getType()==V_STATUS) {
            // Change relay state
            digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            saveState(message.getSensor(), message.getBool());
            // Write some debug info
            Serial.print(message.getSensor());
        SERIAL MONITOR
        MCO:BGN:INIT GW,CP=R-NGE---,FQ=80,REL=255,VER=2.3.2
        09:20:06.194 -> 126 MCO:BGN:BFR
        09:20:06.267 -> scandone
        09:20:07.256 -> 1203 GWT:TIN:CONNECTING...
        09:20:08.281 -> 2232 GWT:TIN:CONNECTING...
        09:20:09.100 -> scandone
        09:20:10.052 -> state: 0 -> 2 (b0)
        09:20:10.052 -> 3987 GWT:TIN:CONNECTING...
        09:20:10.086 -> state: 2 -> 3 (0)
        09:20:10.121 -> state: 3 -> 5 (10)
        09:20:10.121 -> add 0
        09:20:10.155 -> aid 13
        09:20:10.155 -> cnt
        09:20:10.155 ->
        09:20:10.155 -> connected with SSID, channel 6
        09:20:10.189 -> ip:10.0.0.171,mask:255.255.255.0,gw:10.0.0.1
        09:20:10.223 -> ip:10.0.0.171,mask:255.255.255.0,gw:10.0.0.1
        09:20:10.291 -> 4220 GWT:TIN:IP: 10.0.0.171
        09:20:10.324 -> 4249 MCO:BGN:STP
        09:20:10.324 -> 4267 MCO:REG:NOT NEEDED
        09:20:10.358 -> 4292 MCO:BGN:INIT OK,TSP=NA
        09:20:20.092 -> pm open,type:2 0
        09:20:47.941 -> 41822 GWT:TSA:C=0,CONNECTED
        09:20:47.975 -> 41866 GWT:RFC:C=0,MSG=255;255;3;0;20;
        09:20:58.061 -> 51953 GWT:RFC:C=0,MSG=0;255;3;0;2;
        09:21:08.201 -> 62090 GWT:RFC:C=0,MSG=0;255;3;0;2;
        HOME ASSISTANT CONFIGURATION.YAML
        mysensors:
          gateways:
            - device: '10.0.0.171'
              persistence_file: '/home/pi/homeassistant/mysensors/mysensors.json'
              tcp_port: 5003
          version: '2.0'
        HOME ASSISTANT LOGS
        2020-05-26 09:20:47 WARNING (SyncWorker_6) [mysensors.persistence] File does not exist or is not readable: /home/pi/homeassistant/mysensors/mysensors.json
        2020-05-26 09:20:47 WARNING (SyncWorker_6) [mysensors.persistence] Trying backup file: /home/pi/homeassistant/mysensors/mysensors.json.bak
        2020-05-26 09:20:47 WARNING (SyncWorker_6) [mysensors.persistence] File does not exist or is not readable: /home/pi/homeassistant/mysensors/mysensors.json.bak
        2020-05-26 09:20:47 WARNING (SyncWorker_6) [mysensors.persistence] Failed to load sensors from file: /home/pi/homeassistant/mysensors/mysensors.json
        2020-05-26 09:20:47 ERROR (SyncWorker_2) [mysensors.persistence] Permission denied when writing to /home/pi/homeassistant/mysensors/mysensors.json
        • N
          N
          nodethecollector
          In case this helps someone in the future, I learned two additional things about getting these added to Home Assistant:
          1. The "file does not exist" error messages is because I had not created a sensor yet.
            Described here: https://community.home-assistant.io/t/mysensors-persistance-file/11047
          2. Home Assistant was not seeing my RelayActuator sensor because it needs to send an initial value from the loop. For some reason, that is not in the example sketches.
            Mentioned here https://www.elektormagazine.com/labs/mysensors-home-assistant-howto and I used code from here to make it happen https://www.home-assistant.io/integrations/mysensors#presentation
