  3. Home Assistant
  4. serial gateway
serial gateway
4 Posts 3 Posters 770 Views 3 Watching
  • Asaf FrigeA Offline
    Asaf FrigeA Offline
    Asaf Frige
    hi, i start to build home automation system based on home assistant that installed on raspberry pi 3. my gateway is serial using arduino nano and nrf24l01. what should i do now? how can i configure the gateway to work with home assistant?
    thank you.
    BearWithBeardB 1 Reply Last reply
    • Asaf FrigeA Asaf Frige
      thank you.
      BearWithBeardB Offline
      BearWithBeard
      Welcome @Asaf-Frige
      Please follow the integration guide for MySensors in the Home Assistant docs.
      It includes all the information you need to connect a serial gateway to Home Assistant, including a sample configuration and sketch. If you have any open questions afterwards, feel free to ask.
        Asaf FrigeA Offline
        Asaf Frige
        i still don't understand how to make the right configuration for me...
        • electrikE Offline
          electrikE Offline
          electrik
          You don't have to configure the gateway, just tell Home assistant the gateway is there.
          Did you follow the instructions in the link @BearWithBeard mentioned?
          Please note the nodes you use have to follow the presentation guide lines, else HA won't detect them automatically.
          https://www.home-assistant.io/integrations/mysensors/#presentation
