  3. Building an IR controller
4 Posts 2 Posters 2.8k Views 1 Watching
  • CorvlC
    CorvlC
    Corvl
    wrote on last edited by Corvl
    Time for a new project.
    Some time ago I build a serial gateway and a servo to control my floorheating thermostate.
    Now I want to build a device to control a media box ( switch it off via my vera 3)
    Today I have hooked up a IR reciever and transmitter on a arduino uno.
    Uploaded the sketch and tried to controll the media box.
    No , it isn't working , i think it is going wrong somewhere reading the IR-code.
    Whatever button I press on a remote , it always shows the same code , for the transmitter of the mediabox it is "000000" , for the transmitter of a Yamaha amplifier , it is "ffffff" Every button on those remotes gives the same code, that can not be right.
    Using the serial monitor this is confirmed. ( see the copy paste at the bottom of this post).
    What is wrong? and what else can I try to read to correct code?
    Thanks for the help ,
    Cor
    Here the output from serial monitor:
    connecting at 115200
    sensor started, id 105
    send: 105-105-0-0 s=255,c=0,t=17,pt=0,l=3,st=ok:1.4
    send: 105-105-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    read: 0-0-105 s=255,c=3,t=6,pt=0,l=1:M
    send: 105-105-0-0 s=255,c=3,t=11,pt=0,l=9,st=ok:IR Sensor
    send: 105-105-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 105-105-0-0 s=3,c=0,t=3,pt=0,l=3,st=ok:1.4
    Decoded NEC: Value:5EA1E21C (32 bits)
    Raw samples(68): Gap:6094
    Head: m8850 s4450
    0:m500 s700 1:m450 s1700 2:m450 s700 3:m450 s1750
    4:m450 s1800 5:m450 s1750 6:m450 s1800 7:m550 s550
    8:m450 s1800 9:m500 s600 10:m550 s1700 11:m500 s600
    12:m450 s650 13:m450 s700 14:m450 s650 15:m550 s1700
    16:m450 s1750 17:m450 s1800 18:m500 s1700 19:m550 s600
    20:m500 s600 21:m550 s600 22:m500 s1700 23:m450 s700
    24:m500 s600 25:m500 s650 26:m500 s550 27:m550 s1700
    28:m550 s1650 29:m500 s1750 30:m550 s550 31:m550 s600
    32:m500
    Extent=66250
    Mark min:450 max:550
    Space min:550 max:1800
    send: 105-105-0-0 s=3,c=1,t=24,pt=0,l=8,st=ok:5ea1e21c
    Decoded NEC: Value:FFFFFFFF (0 bits)
    Raw samples(4): Gap:40500
    Head: m8850 s2250
    0:m450
    Extent=11550
    Mark min:450 max:450
    Space min:32767 max:0
    send: 105-105-0-0 s=3,c=1,t=24,pt=0,l=8,st=ok:ffffffff
    Raw samples(4): Gap:29764
    Head: m8850 s2300
    0:m500
    Extent=11650
    Mark min:500 max:500
    • CorvlC
      CorvlC
      Corvl
      No one has a clue on how to troubleshoot this?
      :weary:
      • H
        H
        HarryDutch
        @Corvl
        I don't know which IR library you are using, but this one is very good:
        https://github.com/cyborg5/IRLib
        Several examples to troubleshoot IR issues and don't forget to read the manual there (84 pages!).
        • CorvlC
          CorvlC
          Corvl
          pffff , 84 pages ..... it is something I have to read I guess .
          Thanks for the info ..... I will report here if it is working ......
          Cor
