  3. RFM69HCW beginning of a newbie with ATMEGA328P
4 Posts 2 Posters 797 Views 1 Watching
  • SuperNinjaS
    SuperNinjaS
    SuperNinja
    Re: [SOLVED] Newbie trying to get RFM69HCW working with ATMEGA328P
    Hi all,
    I continue this topic here to have more details on the beginning with MySensors
    • I have 2 moteino (clone) with RFM69HCW 868MHz and ATMEGA328p at 3.3v
    • both are connected to the pc with FTDIs on 2 USB sockets, and therefore 2 ARDUINO IDE windows open.
    • RFM69HCW connections are: SCK: 13, MISO: 12, MOSI: 11, CS: 10, IRQ: 2
    • 1 integrated blue led out of 9
    What I managed to do: use an example from the RFM69 library of lowPowerLab = the 2 modules communicate well.
    What I would like to do with MySensors:
    • correctly initialize my modules (I saw that there is an RFM69_new_driver): define the RFM69HCW, the pins, the frequency, the ATC mode ...
    • do a first sketch of "hello world!" that the Node transmits to the Gateway.
    I have read a lot of examples and it is very confusing for me because there are different ways to initialize the RFM69. Some are obsolete, others don't work, or are only made for HW. Anyway, can you help me create my first start-up sketch to get started on a solid foundation.
    • scalzS
      scalzS
      wrote on last edited by scalz
      if you're new to mysensors and still don't have a network in prod, I would recommend to use the new driver.
      example for rfm69cw
      #define MY_RADIO_RFM69
      #define MY_RFM69_NEW_DRIVER
      #define MY_RFM69_FREQUENCY			RFM69_868MHZ
       #define MY_SIGNAL_REPORT_ENABLED
      #define MY_RFM69_ATC_TARGET_RSSI_DBM (-85)
      //#define MY_RFM69_ENABLE_ENCRYPTION
      //#define MY_DEBUG_VERBOSE_RFM69
      //#define MY_RFM69_NETWORKID 110
      #define MY_RFM69_IRQ_PIN 2
      #define MY_RFM69_CS_PIN 10
      for rfm69H, add this too
      #define MY_IS_RFM69HW
      https://www.mysensors.org/apidocs/MyConfig_8h.html
      you could also show your sketch, and logs so people can help you.
      SuperNinjaS 1 Reply Last reply
      • scalzS scalz
        example for rfm69cw
        SuperNinjaS
        SuperNinjaS
        SuperNinja
        @scalz said in RFM69HCW beginning of a newbie with ATMEGA328P:
        Thank you for your help, precisely, I did not have a sketch to start which corresponds to my material which is however basic.
        yes for the "new driver". i test your example.
        • SuperNinjaS
          SuperNinjaS
          SuperNinja
          wrote on last edited by SuperNinja
          I come back here with good news :laughing:
          Here I succeeded in making communicate the Node and the Gateway.
          At first I did not have a Parent and I understood that this was because I had not given a hard NODE_ID.
          To remedy this I downloaded the excel: Windows GUI / Controller for MySensors which automatically assigns the NODE_lD
          So if I resume my start test installation:
          • a Node RFM69HCW + ATmega 328p with the following sketch:
            This is an example that demonstrates how to report the battery level for a sensor
            Instructions for measuring battery capacity on A0 are available here:
            http://www.mysensors.org/build/battery
          //#define MY_DEBUG_VERBOSE_SIGNING
          // RFM config
          //#define MY_RFM69_NETWORKID 101
          //========== LED ==========
          //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
          #define MY_DEFAULT_RX_LED_PIN  9  // Receive led pin
          // Set blinking period
          #define MY_WITH_LEDS_BLINKING_INVERSE
          //========== ANALOG INPUT ==========
          //#define  BATTERY_SENSE_PIN = 0;  // select the input pin for the battery sense point
          //int oldBatteryPcnt = 0;
          //========== DIGITAL INPUT ==========
          //#define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
          //#define CHILD_ID 1   // Id of the sensor child
          //========== NODE ID ==========
          //#define MY_NODE_ID 1
          //#define MY_NODE_TYPE "NODE"
          // ID of the sensor child
          #define CHILD_ID_UPLINK_QUALITY (0)
          #define CHILD_ID_TX_LEVEL       (1)
          #define CHILD_ID_TX_PERCENT     (2)
          #define CHILD_ID_TX_RSSI        (3)
          #define CHILD_ID_RX_RSSI        (4)
          #define CHILD_ID_TX_SNR         (5)
          #define CHILD_ID_RX_SNR         (6)
          // Initialize general message
          //MyMessage msgUplinkQuality(CHILD_ID_UPLINK_QUALITY, V_CUSTOM);
          //MyMessage msgTxLevel(CHILD_ID_TX_LEVEL, V_CUSTOM);
          //MyMessage msgTxPercent(CHILD_ID_TX_PERCENT, V_CUSTOM);
          MyMessage msgTxRSSI(CHILD_ID_TX_RSSI, V_CUSTOM);
          //MyMessage msgRxRSSI(CHILD_ID_RX_RSSI, V_CUSTOM);
          //MyMessage msgTxSNR(CHILD_ID_TX_SNR, V_CUSTOM);
          //MyMessage msgRxSNR(CHILD_ID_RX_SNR, V_CUSTOM);
          //=              SETUP              =
          }//FIN du SETUP
          //=              PRESENTATION              =
            // Send the sketch version information to the gateway and controller
            sendSketchInfo("ATC_report", "1.0");
            //present(CHILD_ID_UPLINK_QUALITY, S_CUSTOM, "UPLINK QUALITY RSSI");
            // present(CHILD_ID_TX_LEVEL, S_CUSTOM, "TX LEVEL DBM");
            //present(CHILD_ID_TX_PERCENT, S_CUSTOM, "TX LEVEL PERCENT");
            present(CHILD_ID_TX_RSSI, S_CUSTOM, "TX RSSI");
            // present(CHILD_ID_RX_RSSI, S_CUSTOM, "RX RSSI");
            // present(CHILD_ID_TX_SNR, S_CUSTOM, "TX SNR");
            // present(CHILD_ID_RX_SNR, S_CUSTOM, "RX SNR");
          //=              LOOP               =
            // send messages to GW
            //send(msgUplinkQuality.set(transportGetSignalReport(SR_UPLINK_QUALITY)));
            //send(msgTxLevel.set(transportGetSignalReport(SR_TX_POWER_LEVEL)));
            //send(msgTxPercent.set(transportGetSignalReport(SR_TX_POWER_PERCENT)));
            send(msgTxRSSI.set(transportGetSignalReport(SR_TX_RSSI)));
            // retrieve RSSI / SNR reports from incoming ACK
            //  send(msgRxRSSI.set(transportGetSignalReport(SR_RX_RSSI)));
            //  send(msgTxSNR.set(transportGetSignalReport(SR_TX_SNR)));
            //  send(msgRxSNR.set(transportGetSignalReport(SR_RX_SNR)));
            // wait a bit
            wait(10000);
          }// FIN de LOOP
            Serial.print("Message recu pour le capteur :");
            Serial.print(message.sensor);
            Serial.print(", Nouveau statut : ");
          • a Gateway RFM69HCW + ATmega 328p with the following sketch, connected to the PC win10 on a USB socket (thanks to an FTDI) :
            DESCRIPTION
            The ArduinoGateway prints data received from sensors on the serial link.
            The gateway accepts input on serial which will be sent out on radio network.
            The GW code is designed for Arduino Nano 328p / 16MHz
          // RFM config
          //#define MY_RFM69_ATC_TARGET_RSSI_DBM (-85)
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
            // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
            #if F_CPU == 8000000L
            #define MY_BAUD_RATE 38400
            // Enable inclusion mode
          //=              SETUP              =
          //=              PRESENTATION              =
          //=              LOOP               =
          • On the PC the execution of the Controller program: Windows GUI / Controller for MySensors.
            Which give :
            We can see in sky blue, the sending of the state of a virtual "Motion" sensor from the Gateway to the Node (adjustable at the bottom of the interface).
            The other V_CUSTOMs are the RSSI of the RFM69 transmition stage.
            Oddity: after receiving the state of the Motion sensor, sent by the Gateway, the Node transmits a value of 127 ??
          Everything works, out of the box, you just had to know how to start with the configuration of the RFM69HCW, thank you @scalz
          The second step is to replace the Win10 Controller with a Node-Red Controller.
          I already have a Node-Red server with its Dashboard running on an RPI 3B.
          I found "node-red-contrib-mysensors" but it still seems blurry to me (sorry I learn fast but you have to explain myself a long time) :yum:
          I think I'll open another Topic or continue on the original node-red-contrib-mysensors, Topic.
