  3. Waking up on timer AND interrupt
7 Posts 5 Posters 948 Views 4 Watching
  • A
    A
    APL2017
    For battery operated node is it possible to set node to wake up on timer to send battery status AND wake up on DIN3 interrupt to report digital input status? I see example how to wake up on timer for battery status reporting and other example on waking up on digital input interrupt, but not sure how to combine them together.
    • A APL2017
      @APL2017 yes. See https://www.mysensors.org/download/sensor_api_20#sleeping for info on how to do it.
      A 1 Reply Last reply
      • BearWithBeardB
        BearWithBeardB
        BearWithBeard
        I have not tested it myself, but I think getSleepRemaining() is what you are looking for. It returns the time in ms that is remaining in the current sleep cycle if the device woke up by an interrupt. This seems to be implemented for AVR (this includes Arduinos) only.
        Something similar to this should work:
        #define INT_PIN 3
        #define SLEEP_TIME 9000000 // 15 min
        uint32_t sleepTime = SLEEP_TIME;
        int8_t wakeupReason = 0;
        	if (wakeupReason == digitalPinToInterrupt(INT_PIN))
        		sleepTime = getSleepRemaining();
        		// Report sensor status here
        	else if (wakeupReason == MY_WAKE_UP_BY_TIMER)
        		// Report battery level here
        	wakeupReason = sleep(digitalPinToInterrupt(INT_PIN), CHANGE, sleepTime);
        Since sleep() returns the wake up reason, we can check whether it was caused by the external interrupt on D3 or because the timer ran out and set the sleep time for the next period accordingly.
        So, a node with a sleep time of 15 minutes, which is interrupted after 10 minutes, should send the sensor status and go back to sleep for another 5 minutes, report the battery status and reset the sleep timer to the full duration of 15 minutes.
        nagelcN mfalkviddM 2 Replies Last reply
        • BearWithBeardB BearWithBeard
          #define INT_PIN 3
          nagelcN
          nagelcN
          nagelc
          @BearWithBeard
          Wow. Thanks. So many times, I have wanted a function like this, but I did not know it existed. I'm going to have to go back to the documentation and see what other good tricks I have missed.
            #define INT_PIN 3
            Great clear example @BearWithBeard
            I took the liberty to add that example to the documentation.
              A
              A
              APL2017
              @mfalkvidd Thank you, works great!
              • skywatchS
                skywatchS
                skywatch
                @BearWithBeard Thank you for sharing this great tip! - It works great and maybe finally I get my lightning detector working!
                Thanks @mfalkvidd For putting this in with the docs where it will hopefully help others. We need more examples like this in a knowledge base to save time reading through lots of posts that are many years old.
