  3. Floor Cooling in my House
5 Posts 4 Posters 756 Views 4 Watching
  • S Offline
    Strontvlieg
    Hi There,
    I am working on floor cooling in my house. I want to use MySensors for this. In the room to be cooled, I want to make a sensor with floor temperature and some other sensors that are linked via modbus to the main controller that is mounted at the water pump. The main controller has to talk with the gateway.
    Now my question.
    Is it possible to link 2 MySensors via modbus and that 1 of these 2 MySensors talks to the gateway?
    I am thinking of some kind of repeater function.
    Ikes 72000I 1 Reply Last reply
    • S Strontvlieg
      Hi There,
      Now my question.
      Ikes 72000I Offline
      Ikes 72000I Offline
      Ikes 72000
      wrote on last edited by Ikes 72000
      @Strontvlieg, you can use Node-red for that, it's simple and work fine.
      I use both Modbus and Mysensor at home, with Node-red.
      Modbus Node red
      Mysensors Node red
      With this solution, it will be easy to do what you need to achieve.
      • S Offline
        Strontvlieg
        @Ikes-72000
        Hi
        I know Node-Red and use it with Home-Assistant.
        The floor cooling must be fail-proof, so it must also work without a gateway. this is the reason that the control panel is connected to the main controller via modbus.
        This will not work with Node-Red because a gateway is required for control.
        I'm afraid to have design something for myself, maybe someone else has a good idea.
        • Julie AdamJ Offline
          Julie AdamJ Offline
          Julie Adam
          Banned
          I have done with this last month but somehow my controller was damaged and having an airline on it, So could you guys suggest me the best way how should I repaired. one of my friends is suggested me to put this controller in a wooden frame and for this, he is suggested me to visit at Woodworkers Coupons, do let me know is someone is ever experienced such type of coupon codes.
          • Julie AdamJ Julie Adam
            zboblamontZ Offline
            zboblamontZ Offline
            zboblamont
            @Julie-Adam Have you considered disconnecting the air-line from the controller and reconnecting it to the air-head ?
            The cranium woodframe is probably interrupting signals which possibly
            explains the coupon fascination...
