  3. Home Assistant
  4. RGB Light: Custom Effects
4 Posts 2 Posters 604 Views 2 Watching
  • rvendrameR
    rvendrameR
    rvendrame
    Anyone figured out how to trigger an update + sending of V_VAR1 / V_VAR2 from home assistant to a node?
    My goal is to trigger custom effects in a mysensor-RGB node.
    (Yes, I know my sketch could present switches to allow triggering of the effects but I wanted to learn more how HA mySensor integration works and maybe couple with HA's existing 'effect_list' attribute for RGB lights).
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    electrikE 1 Reply Last reply
    • rvendrameR rvendrame
      electrikE
      electrikE
      electrik
      @rvendrame
      I think you should start with presenting a sensor as S_CUSTOM with V_VAR1 as described here
      https://www.home-assistant.io/integrations/sensor.mysensors/
      That should show up in HA and from there you can control the values from HA.
      I hope this helps.
      • rvendrameR
        rvendrameR
        rvendrame
        @electrik , thanks for the directions. Yes the S_CUSTOM does show up in HA --- But how to change its value there? I can set different values in dev tools UI, but that is known to be temporary (it lasts only until next refresh from integration), and changing it there does not trigger a V_VAR1 message from HA back to node...
        Alexa / Google Home
        • electrikE
          electrikE
          electrik
          I have no idea, sorry...
          Personally I use node red for automations, from there you can just address the node and child directly even when it isn't presented or not supported by home assistant.
