  3. Vera
  4. Mysensors Plugin - Lua Startup Failed
13 Posts 7 Posters 7.2k Views 2 Watching
  • Sven WolfS Offline
    Sven WolfS Offline
    Sven Wolf
    Hey there.
    So as the subject line says.
    I can't seem to get the mysensors plugin to work.
    I have followed the installation instructions but the 'device'
    show the following: "Lua Startup Failure"
    On the top of my screen there seems to be a log which says:
    "MySensors plugin : Choose the Serial Port
    MySensors Plugin[15] : Running Lua Startup"
    Anyone have any ideas of what to do to make it work?
    I'm on a Vera 3 with UI5 by the way.
    //Sven
    • 5546dug5 Offline
      5546dug5 Offline
      5546dug
      I think you have the same as I did
      From where you are you. Need to go under apps-dev apps-config port
      There, change the baud rate to 115200 and select the ' my sensors plugin ' under the 'used by' pull down list .
      Important now to save this in Vera and then Hit Save , and then hit reload. That should be it.
      • hekH Offline
        hekH Offline
        Yes, it should be described here:
        http://www.mysensors.org/controller/vera#including-new-sensors
          Sven WolfS Offline
          Sven Wolf
          Oh, maybe I should've scrolled XD
          Thanks a lot guys. This will probably fix it.
          //Sven
          • H Offline
            H Offline
            heeythere47
            Hi, I have the same problem but when I go to serial port configaration all I get up is
            "Serial Port configuration
            If you connected the USB/serial device and it's not displayed here, reload Luup.Reload Luup
            Not available"
            Any help appreciated. Using vera lite u17. Thanks
            B 1 Reply Last reply
            • H heeythere47
              Not available"
              B Offline
              B Offline
              blacey
              • H Offline
                H Offline
                heeythere47
                Tried this, hasn't helped. Same message as before. This from device page.mysensor.PNG
                Would chinese clones be causing this problem?
                Thanks Jamie
                D 1 Reply Last reply
                • H heeythere47
                  Thanks Jamie
                  Dwalt
                  @heeythere47 Did you try what @5546dug suggested above? Your Vera is wanting you to "choose serial port". Check the baud rate and make sure the 'MySensors plugin' is selected.
                  • H Offline
                    H Offline
                    heeythere47
                    I have gone to apps-dev apps-config port. but it is not opening the menu up to allow me to set anything.
                    I go into develop apps, create device & paste D_Arduino1.xml in Upnp Device Filename field.
                    Thats fine device is created. At this point it is an "Unnamed device"
                    Then I go back to develop apps Serial port configuration & get this
                    ClickReload Luup & the device becomes
                    but i am still not able to choose serial port & if click start on the device I get
                    lua startup failure message
                    Cheers Jamie
                    • H Offline
                      H Offline
                      heeythere47
                      Also have gone to z-wave settings & restarted luup engine. Thanks
                      • H Offline
                        H Offline
                        heeythere47
                        I have come to the conclusion that my vera does not recognise theses nanos & have ordered what I hope is a genuine one by the price. I will see how that goes.
                        Cheers Jamie
                        • M Offline
                          M Offline
                          mjunqueira
                          There is a cheaper version of the nano that uses the ch340 Usb to Serial, there is no driver on the open wrt, to recognize it,
                          Please take a look at the bottom of your nano,
                          if it´s the same of to photo, you will need to buy one with the FTDI chip:
                          • H Offline
                            H Offline
                            heeythere47
                            that is the chip on the nanos I bought. The serial gateway is working now I received a genuine nano & the cheap ones work fine with relays, motion sensors etc. All good.
                            Thanks Jamie
