  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • Sergio RiusS
    Sergio RiusS
    Sergio Rius
    Does anyone already made a pcb for this? My board keeps loosing it's "bridging" wires. They rot and fall near the solder.
    petewillP 1 Reply Last reply
    • petewillP petewill
      @Lars65 Take a look at lines 663-667. I haven't tested this but it should be something similar to this:
                lcd.print(hour() < 10 ? F(" ") : F(""));
                lcd.print(hour());
                lcd.print(minute() < 10 ? F(":0") : F(":"));
                lcd.print(minute());
                //lcd.print(isAM() ? F("am") : F("pm"));
      L
      L
      Lars65
      @petewill I did try this, and it worked just fine. Thank you!
      • Sergio RiusS Sergio Rius
        petewillP
        petewillP
        petewill
        @Sergio-Rius Where do you have your controller located? I have had mine running for over a year now and haven't had any issues. Maybe you need to put it into a waterproof case?
        To answer your question though, no, I don't believe anyone has created a PCB for this.
        • L
          L
          Lars65
          I will have mine in the greenhouse. Boxes is made of waxed oak,and it will be 3 modules, each one seald with a sillicone gasket.
          I have some trash wood in the garage, so I thought I could use it to something. :)
          • L
            L
            Lars65
            Have anyone compiled it with the 2.0.0?
              A Former User
              Hello Gentlemen, new to this board as well as new to micro electrics. Started this Irrigation Controller about a two weeks ago, after finding Pete B’s U tube video on this project. Got all the parts and have started building by following Pete B’s video. Have a few part questions and am not very literal with the nomenclature.
              1. This 4.7uF 50V 20% Axial-Lead Electrolytic Capacitor goes on which end or pins on the
              2. Have a FT232RL FTDI USB 3.3V 5.5V to TTL Serial Adapter Module for Mini Port that is different than Pete’s.
                Not sure how to post JPEG's so this is the problem I am having.
                0_1468546122072_7-14-16 Hello Gentlemen help.docx
                The Pins on the ftdi are different than on Pete’s board, in that I cannot find the info for the double GND on the Arduino Pro Mini.
              Any guidance of will be appreciated.
              Respectfully RJ Myers
              • ? A Former User
                petewillP
                petewillP
                petewill
                @Lars65 No, not yet. It's on the list but it will probably be a little while before I get to it.
                @Ngwpower To add pictures you just have to drag and drop into the edit window. They will automatically upload.
                1. Can you provide more info here? I'm not sure what you're asking.
                2. Both of my FTDI adapters connect into the Pro Mini straight across (the wires don't get crossed when connecting. The key thing is TX on one side should go to RX on the other (and vice versa) then the other 4 wires line up from there. So, you almost have it correct in your picture but the TX and RX are switched. Just start from the DTR and go straight across.
                  A Former User
                  Thank You, petewill I adjusted the wiring!
                  0_1468603030032_upload-e9f66bab-6c30-42eb-80b2-da87857849e7
                  This is the picture for the 4.7 UF that has me baffled of where to insert into the radio. Being color blind really hurts with wiring. And rather ask than fry another project....
                  RJ
                  Sergio RiusS 1 Reply Last reply
                  • ? A Former User
                    RJ
                    Sergio RiusS
                    Sergio RiusS
                    Sergio Rius
                    wrote on last edited by Sergio Rius
                    #169
                    @Ngwpower
                    EDIT: My condenser is 10uF / 63v
                    ? 1 Reply Last reply
                    • Sergio RiusS
                      Sergio RiusS
                      Sergio Rius
                      Does this sketch still work with the current Mysensors libraries?
                      I lost my working environment so I had to build a new one. I downloaded the MySensors libraries and the sketch throws me an error not finding MySensor.h. The file is not at the libraries folder, but MySensorS.h
                      If adding this later (used at the samples) the compilation throws an error:
                      W:\....\MySensors_Arduino\arduino-1.6.9\portable\sketchbook\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                      exit status 1
                      Error compilación en tarjeta Arduino Nano.```
                      Does make sense for anyone?
                        @Ngwpower
                        A Former User
                        @Sergio-Rius
                        Than You for the clarfication & picture worth thousands of words.
                        RJ
                          exit status 1
                          petewillP
                          petewillP
                          petewill
                          @Sergio-Rius Hmm. Are you using the 2.0 release? If so then it's not compatible yet. It still needs to be upgraded.
                            A Former User
                            Got the controller all ready to test like petewill shows in his presentation. Get this error
                            MySensors-1.5.4 loaded it onto my board Arduino Pro Mini and get this error -*** F:\Arduino Programs\My sensors downloads\upload-9cc672c5-a5a3-4711-9e38-8f3f7da898a5\upload-9cc672c5-a5a3-4711-9e38-8f3f7da898a5.ino:33:19: fatal error: Relay.h: No such file or directory***
                            Can I see this operate on my screen, without all the advanced technology? Found the Domoticz site and no sure if this is for me anymore than the Vera that is being used by petewill. Way out of my knowledge base with this project, just to stubborn to quit or give up.
                            L 1 Reply Last reply
                            • ? A Former User
                              L
                              L
                              Lars65
                              @Ngwpower which sketch are you using?
                              • L Lars65
                                A Former User
                                @Lars65 Thanks
                                June 2, 2014 12:00 Version 1.0 Arduino Multi-Zone Sprinkler Control
                                • ? A Former User
                                  @Lars65 Thanks
                                  L
                                  L
                                  Lars65
                                  @Ngwpower I use this one which is earlier in this thread, an it works with my domoticz.
                                  MySprinkler for MySensors
                                  May 31, 2015
                                  *** Version 2.0
                                  *** Upgraded to http://MySensors.org version 1.4.1
                                  *** Expanded for up to 16 Valves
                                  *** Setup for active low relay board or comment out #define ACTIVE_LOW to switch to active high
                                  *** Switch to bitshift method vs byte arrays
                                  *** Changed RUN_ALL_ZONES Vera device to 0 (was highest valve)
                                  *** Added optional LCD display featuring remaining time, date last ran & current time
                                  *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve data and clock respectively
                                  *** Added single pushbutton menu to manually select which program to run (All Zones or a Single Zone)
                                  *** Added option of naming your Zones programmatically or with Vera (V_VAR3 used to store names)
                                  Utilizing your Vera home automation controller and the MySensors.org gateway you can
                                  control up to a sixteen zone irrigation system with only three digital pins.  This sketch
                                  will create NUMBER_OF_VALVES + 1 devices on your Vera controller
                                  This sketch features the following:
                                  * Allows you to cycle through All zones (RUN_ALL_ZONES) or individual zone (RUN_SINGLE_ZONE) control.
                                  * Use the 0th controller to activate RUN_ALL_ZONES (each zone in numeric sequence 1 to n)
                                    using Variable1 as the "ON" time in minutes in each of the vera devices created.
                                  * Use the individual zone controller to activate a single zone.  This feature uses
                                    Variable2 as the "ON" time for each individual device/zone.
                                  * Connect according to pinout below and uses Shift Registers as to allow the MySensors
                                    standard radio configuration and still leave available digital pins
                                  * Turning on any zone will stop the current process and begin that particular process.
                                  * Turning off any zone will stop the current process and turn off all zones.
                                  * To push your new time intervals for your zones, simply change the variable on your Vera and
                                    your arduino will call to Vera once a minute and update accordingly.  Variables will also be
                                    requested when the device is first powered on.
                                  * Pushbutton activation to RUN_ALL_ZONES, RUN_SINGLE_ZONE or halt the current program
                                  * LED status indicator
                                  PARTS LIST:
                                  Available from the MySensors store - http://www.mysensors.org/store/
                                  * Relays (8 channel)
                                  * Female Pin Header Connector Strip
                                  * Prototype Universal Printed Circuit Boards (PCB)
                                  * NRF24L01 Radio
                                  * Arduino (I used a Pro Mini)
                                  * FTDI USB to TTL Serial Adapter
                                  * Capacitors (10uf and .1uf)
                                  * 3.3v voltage regulator
                                  * Resistors (270 & 10K)
                                  * Female Dupont Cables
                                  * 1602 LCD (with I2C Interface)
                                  * LED
                                  * Push button
                                  * Shift Register (SN74HC595)
                                  * 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
                                  * 3 Pole 5mm Pitch PCB Mount Screw Terminal Block
                                  * 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
                                  * 18 gauge wire (for relay)
                                  * Irrigation Power Supply (24-Volt/750 mA Transformer)
                                  INSTRUCTIONS:
                                  * A step-by-step setup video is available here: http://youtu.be/l4GPRTsuHkI
                                  * After assembling your arduino, radio, decoupling capacitors, shift register(s), status LED, pushbutton LCD (I2C connected to
                                    A4 and A5) and relays, and load the sketch.
                                  * Following the instructions at https://MySensors.org include the device to your MySensors Gateway.
                                  * Verify that each new device has a Variable1, Variable2 and Variable3. Populate data accordingly with whole minutes for
                                    the RUN_ALL_ZONES routine (Variable1) and the RUN_SINGLE_ZONE routines (Variable 2).  The values entered for times may be zero and
                                    you may use the defaulet zone names by leaving Variable3 blank.
                                  * Once you have entered values for each zone and each variable, save the settings by pressing the red save button on your Vera.
                                  * Restart your arduino; verify the settings are loaded into your arduino with the serial monitor; the array will be printed
                                    on the serial monitor.
                                  * Your arduino should slow-flash, indicating that it is in ready mode.
                                  * There are multiple debug serial prints that can be monitored to assure that it is operating properly.
                                  * ***THIS SHOULD NO LONGER BE NEEDED*** The standard MySensors library now works. https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
                                  Contributed by Jim (BulldogLowell@gmail.com) with much contribution from Pete (pete.will@mysensors.org) and is released to the public domain
                                  #include <Wire.h>
                                  #include <Time.h>
                                  #include <LiquidCrystal.h>
                                  #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                                  #define VALVE_RESET_TIME 7500UL   // Change this (in milliseconds) for the time you need your valves to hydraulically reset and change state
                                  #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                                  #define SKETCH_NAME "MySprinkler Domoticz"
                                  #define SKETCH_VERSION "2.0"
                                  #define CHILD_ID_SPRINKLER 0
                                  //#define ACTIVE_LOW // comment out this line if your relays are active high
                                  #define DEBUG_ON   // comment out to supress serial monitor output
                                  #ifdef ACTIVE_LOW
                                  #define BITSHIFT_VALVE_NUMBER ~(1U << (valveNumber-1))
                                  #define ALL_VALVES_OFF 0xFFFF
                                  #else
                                  #define BITSHIFT_VALVE_NUMBER (1U << (valveNumber-1))
                                  #define ALL_VALVES_OFF 0U
                                  #ifdef DEBUG_ON
                                  #define DEBUG_PRINT(x)   Serial.print(x)
                                  #define SERIAL_START(x)  Serial.begin(x)
                                  #else
                                  typedef enum {
                                    STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE, ZONE_SELECT_MENU
                                  SprinklerStates;
                                  SprinklerStates state = STAND_BY_ALL_OFF;
                                  SprinklerStates lastState;
                                  byte menuState = 0;
                                  unsigned long menuTimer;
                                  byte countDownTime = 10;
                                  int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                                  int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                                  int valveNumber;
                                  int lastValve;
                                  unsigned long startMillis;
                                  const int ledPin = 5;
                                  const int waterButtonPin = 3;
                                  boolean buttonPushed = false;
                                  boolean showTime = true;
                                  boolean clockUpdating = false;
                                  boolean recentUpdate = true;
                                  const char *dayOfWeek[] = {
                                    "Null", "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
                                  // Name your Zones here or use Vera to edit them by adding a name in Variable3...
                                  String valveNickName[17] = {
                                    "All Zones", "Zone 1", "Zone 2", "Zone 3", "Zone 4", "Zone 5", "Zone 6", "Zone 7", "Zone 8", "Zone 9", "Zone 10", "Zone 11", "Zone 12", "Zone 13", "Zone 14", "Zone 15", "Zone 16"
                                  time_t lastTimeRun = 0;
                                  //Setup Shift Register...
                                  const int latchPin = 8;
                                  const int clockPin = 4;
                                  const int dataPin  = 7;
                                  byte clock[8] = {0x0, 0xe, 0x15, 0x17, 0x11, 0xe, 0x0}; // fetching time indicator
                                  byte raindrop[8] = {0x4, 0x4, 0xA, 0xA, 0x11, 0xE, 0x0,}; // fetching Valve Data indicator
                                  // Set the pins on the I2C chip used for LCD connections:
                                  //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
                                  LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                                  MyMessage msg1valve(CHILD_ID_SPRINKLER, V_LIGHT);
                                  MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);
                                  MyMessage var2valve(CHILD_ID_SPRINKLER, V_VAR2);
                                    SERIAL_START(115200);
                                    DEBUG_PRINTLN(F("Initialising..."));
                                    pinMode(latchPin, OUTPUT);
                                    pinMode(clockPin, OUTPUT);
                                    pinMode(dataPin, OUTPUT);
                                    pinMode(ledPin, OUTPUT);
                                    pinMode(waterButtonPin, INPUT_PULLUP);
                                    //pinMode(waterButtonPin, INPUT);
                                    attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                                    digitalWrite (ledPin, HIGH);
                                    DEBUG_PRINTLN(F("Turning All Valves Off..."));
                                    updateRelays(ALL_VALVES_OFF);
                                    //delay(5000);
                                    lcd.begin(16, 2); //(16 characters and 2 line display)
                                    lcd.clear();
                                    lcd.backlight();
                                    lcd.createChar(0, clock);
                                    lcd.createChar(1, raindrop);
                                    //check for saved date in EEPROM
                                    DEBUG_PRINTLN(F("Checking EEPROM for stored date:"));
                                    delay(500);
                                    if (gw.loadState(0) == 0xFF); // EEPROM flag
                                      DEBUG_PRINTLN(F("Retreiving last run time from EEPROM..."));
                                      for (int i = 0; i < 4 ; i++)
                                        lastTimeRun = lastTimeRun << 8;
                                        lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                                    gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                                    gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                                    for (byte i = 0; i <= NUMBER_OF_VALVES; i++)
                                      gw.present(i, S_LIGHT);
                                    DEBUG_PRINTLN(F("Sensor Presentation Complete"));
                                    digitalWrite (ledPin, LOW);
                                    DEBUG_PRINTLN(F("Ready..."));
                                    lcd.setCursor(0, 0);
                                    lcd.print(F(" Syncing Time  "));
                                    lcd.setCursor(15, 0);
                                    lcd.write(byte(0));
                                    lcd.setCursor(0, 1);
                                    int clockCounter = 0;
                                    while (timeStatus() == timeNotSet && clockCounter < 21)
                                      gw.process();
                                      gw.requestTime(receiveTime);
                                      DEBUG_PRINTLN(F("Requesting time from Gateway:"));
                                      delay(1000);
                                      lcd.print(".");
                                      clockCounter++;
                                      if (clockCounter > 16)
                                        DEBUG_PRINTLN(F("Failed initial clock synchronization!"));
                                        lcd.clear();
                                        lcd.print(F("  Failed Clock  "));
                                        lcd.print(F(" Syncronization "));
                                        delay(2000);
                                        break;
                                    lcd.clear();
                                    //Update valve data when first powered on
                                      lcd.print(F(" Updating  "));
                                      lcd.print(F(" Valve Data: "));
                                      lcd.print(i);
                                      boolean flashIcon = false;
                                      DEBUG_PRINT(F("Calling for Valve "));
                                      DEBUG_PRINT(i);
                                      DEBUG_PRINTLN(F(" Data..."));
                                      while (gw.process() == false)
                                        flashIcon = !flashIcon;
                                        flashIcon ? lcd.write(byte(1)) : lcd.print(F(" "));
                                        gw.request(i, V_VAR1);
                                        delay(100);
                                        gw.request(i, V_VAR2);
                                        delay(100);
                                        gw.request(i, V_VAR3);
                                        delay(100);
                                    lcd.clear();
                                    gw.process();
                                    updateClock();
                                    updateDisplay();
                                    //goGetValveTimes();
                                    if (buttonPushed)
                                      menuTimer = millis();
                                      DEBUG_PRINTLN(F("Button Pressed"));
                                      if (state == STAND_BY_ALL_OFF)
                                        state = ZONE_SELECT_MENU;
                                        menuState = 0;
                                      else if (state == ZONE_SELECT_MENU)
                                        menuState++;
                                        if (menuState > NUMBER_OF_VALVES)
                                          menuState = 0;
                                      else
                                      slowToggleLED ();
                                      if (state != lastState)
                                        DEBUG_PRINTLN(F("State Changed... all Zones off"));
                                          delay(50);
                                          gw.send(msg1valve.setSensor(i).set(false), false);
                                        lcd.clear();
                                        lcd.setCursor(0,0);
                                        lcd.print(F("** Irrigation **"));
                                        lcd.setCursor(0,1);
                                        lcd.print(F("**   Halted   **"));
                                        delay(2000);
                                        lastValve = -1;
                                    else if (state == RUN_ALL_ZONES)
                                      if (lastValve != valveNumber)
                                          if (i == 0 || i == valveNumber)
                                            gw.send(msg1valve.setSensor(i).set(true), false);
                                          else
                                      lastValve = valveNumber;
                                      fastToggleLed();
                                        valveNumber = 1;
                                        DEBUG_PRINTLN(F("State Changed, Running All Zones..."));
                                      unsigned long nowMillis = millis();
                                      if (nowMillis - startMillis < VALVE_RESET_TIME)
                                      else if (nowMillis - startMillis < (allZoneTime[valveNumber] * 60000UL))
                                        updateRelays(BITSHIFT_VALVE_NUMBER);
                                      else
                                        DEBUG_PRINTLN(F("Changing Valves..."));
                                        startMillis = millis();
                                        valveNumber++;
                                        if (valveNumber > NUMBER_OF_VALVES)
                                          state = CYCLE_COMPLETE;
                                          lastValve = -1;
                                          lastTimeRun = now();
                                          saveDateToEEPROM(lastTimeRun);
                                          DEBUG_PRINT(F("State = "));
                                          DEBUG_PRINTLN(state);
                                    else if (state == RUN_SINGLE_ZONE)
                                      fastToggleLed();
                                          else
                                        DEBUG_PRINTLN(F("State Changed, Single Zone Running..."));
                                        DEBUG_PRINT(F("Zone: "));
                                        DEBUG_PRINTLN(valveNumber);
                                      else if (nowMillis - startMillis < (valveSoloTime [valveNumber] * 60000UL))
                                      else
                                    else if (state == CYCLE_COMPLETE)
                                      if (millis() - startMillis < 30000UL)
                                        fastToggleLed();
                                      else
                                    else if (state = ZONE_SELECT_MENU)
                                      displayMenu();
                                    lastState = state;
                                  void displayMenu(void)
                                    static byte lastMenuState = -1;
                                    static int lastSecond;
                                    if (menuState != lastMenuState)
                                      lcd.clear();
                                      lcd.print(valveNickName[menuState]);
                                      lcd.print(F("Starting"));
                                      DEBUG_PRINT(valveNickName[menuState]);
                                      Serial.print(F(" Starting Shortly"));
                                    int thisSecond = (millis() - menuTimer) / 1000UL;
                                    if (thisSecond != lastSecond && thisSecond < 8)
                                      lcd.print(F("."));
                                      Serial.print(".");
                                    lastSecond = thisSecond;
                                    if (millis() - menuTimer > 10000UL)
                                      if (menuState == 0)
                                        valveNumber = 1;
                                        state = RUN_ALL_ZONES;
                                      else
                                        valveNumber = menuState;
                                        state = RUN_SINGLE_ZONE;
                                    else
                                    lastMenuState = menuState;
                                  void updateRelays(int value)
                                    digitalWrite(latchPin, LOW);
                                    shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
                                    shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
                                    digitalWrite(latchPin, HIGH);
                                  void PushButton() //interrupt with debounce
                                    static unsigned long last_interrupt_time = 0;
                                    unsigned long interrupt_time = millis();
                                    if (interrupt_time - last_interrupt_time > 200)
                                      buttonPushed = true;
                                    last_interrupt_time = interrupt_time;
                                  void fastToggleLed()
                                    static unsigned long fastLedTimer;
                                    if (millis() - fastLedTimer >= 100UL)
                                      digitalWrite(ledPin, !digitalRead(ledPin));
                                      fastLedTimer = millis ();
                                  void slowToggleLED ()
                                    static unsigned long slowLedTimer;
                                    if (millis() - slowLedTimer >= 1250UL)
                                      slowLedTimer = millis ();
                                  void getVariables(const MyMessage &message)
                                    boolean zoneTimeUpdate = false;
                                    if (message.isAck())
                                      DEBUG_PRINTLN(F("This is an ack from gateway"));
                                      if (message.sensor == i)
                                        if (message.type == V_LIGHT)
                                          int switchState = atoi(message.data);
                                          if (switchState == 0)
                                            DEBUG_PRINTLN(F("Recieved Instruction to Cancel..."));
                                          else
                                            if (i == 0)
                                              valveNumber = 1;
                                              DEBUG_PRINTLN(F("Recieved Instruction to Run All Zones..."));
                                            else
                                              valveNumber = i;
                                              DEBUG_PRINT(F("Recieved Instruction to Activate Zone: "));
                                              DEBUG_PRINTLN(i);
                                        else if (message.type == V_VAR1)
                                          int variable1 = atoi(message.data);// RUN_ALL_ZONES time
                                          DEBUG_PRINT(F("Recieved variable1 valve:"));
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINT(F(" = "));
                                          DEBUG_PRINTLN(variable1);
                                          if (variable1 != allZoneTime[i])
                                            allZoneTime[i] = variable1;
                                            zoneTimeUpdate = true;
                                        else if (message.type == V_VAR2)
                                          int variable2 = atoi(message.data);// RUN_SINGLE_ZONE time
                                          DEBUG_PRINT(F("Recieved variable2 valve:"));
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINTLN(variable2);
                                          if (variable2 != valveSoloTime[i])
                                            valveSoloTime[i] = variable2;
                                        else if (message.type == V_VAR3)
                                          String newMessage = String(message.data);
                                          if (newMessage.length() == 0)
                                            DEBUG_PRINT(F("No Name Recieved for zone "));
                                            DEBUG_PRINTLN(i);
                                            break;
                                          if (newMessage.length() > 16)
                                            newMessage.substring(0, 16);
                                          valveNickName[i] = "";
                                          valveNickName[i] += newMessage;
                                          DEBUG_PRINT(F("Recieved new name for zone "));
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINT(F(" and it is now called: "));
                                          DEBUG_PRINTLN(valveNickName[i]);
                                    if (zoneTimeUpdate)
                                      DEBUG_PRINTLN(F("New Zone Times Recieved..."));
                                        if (i != 0)
                                          DEBUG_PRINT(F("Zone "));
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINT(F(" individual time: "));
                                          DEBUG_PRINT(valveSoloTime[i]);
                                          DEBUG_PRINT(F(" group time: "));
                                          DEBUG_PRINTLN(allZoneTime[i]);
                                    else
                                      recentUpdate = false;
                                  void updateDisplay()
                                    static unsigned long lastUpdateTime;
                                    static boolean displayToggle = false;
                                    //static byte toggleCounter = 0;
                                    static SprinklerStates lastDisplayState;
                                    if (state != lastDisplayState || millis() - lastUpdateTime >= 3000UL)
                                      displayToggle = !displayToggle;
                                      switch (state) {
                                        case STAND_BY_ALL_OFF:
                                          fastClear();
                                          if (displayToggle)
                                            lcd.print(F("  System Ready "));
                                            if (clockUpdating)
                                              lcd.write(byte(0));
                                            lcd.print(hourFormat12() < 10 ? F(" ") : F(""));
                                            lcd.print(hourFormat12());
                                            lcd.print(month() < 10 ? F(" 0") : F(" "));
                                            lcd.print(month());
                                            lcd.print(day() < 10 ? F("/0") : F("/"));
                                            lcd.print(day());
                                            lcd.print(F("/"));
                                            lcd.print(year() % 100);
                                          else
                                            lcd.print(F("  Last Watered "));
                                            if (clockUpdating)
                                              lcd.write(byte(0));
                                            lcd.print(dayOfWeek[weekday(lastTimeRun)]);
                                            lcd.setCursor(11, 1);
                                            lcd.print(month(lastTimeRun) < 10 ? F(" ") : F(""));
                                            lcd.print(month(lastTimeRun));
                                            lcd.print(day(lastTimeRun) < 10 ? F("/0") : F("/"));
                                            lcd.print(day(lastTimeRun));
                                          break;
                                        case RUN_SINGLE_ZONE:
                                          fastClear();
                                          if (displayToggle)
                                            lcd.print(F("Single Zone Mode"));
                                            lcd.print(F(" Zone:"));
                                            if (valveNumber < 10) lcd.print(F("0"));
                                            lcd.print(valveNumber);
                                            lcd.print(F(" Active"));
                                          else
                                            lcd.print(F(" Time Remaining "));
                                            if (valveSoloTime[valveNumber] == 0)
                                              lcd.print(F(" No Valve Time "));
                                            else
                                              unsigned long timeRemaining = (valveSoloTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                                              lcd.print(timeRemaining / 60 < 10 ? "   0" : "   ");
                                              lcd.print(timeRemaining / 60);
                                              lcd.print("min");
                                              lcd.print(timeRemaining % 60 < 10 ? " 0" : " ");
                                              lcd.print(timeRemaining % 60);
                                              lcd.print("sec  ");
                                          break;
                                        case RUN_ALL_ZONES:
                                          fastClear();
                                          if (displayToggle)
                                            lcd.print(F(" All-Zone  Mode "));
                                            lcd.print(F(" Active "));
                                          else
                                            int timeRemaining = (allZoneTime[valveNumber] * 60) - ((millis() - startMillis) / 1000);
                                            lcd.print((timeRemaining / 60) < 10 ? "   0" : "   ");
                                            lcd.print("min");
                                            lcd.print("sec  ");
                                          break;
                                        case CYCLE_COMPLETE:
                                          if (displayToggle)
                                            lcd.print(F(" Watering Cycle "));
                                            lcd.print(F("    Complete    "));
                                          else
                                            int totalTimeRan = 0;
                                            for (int i = 1; i < NUMBER_OF_VALVES + 1; i++)
                                              totalTimeRan += allZoneTime[i];
                                            lcd.print(F(" Total Time Run "));
                                            lcd.print(totalTimeRan < 10 ? "   0" : "   ");
                                            lcd.print(totalTimeRan);
                                            lcd.print(" Minutes   ");
                                      lastUpdateTime = millis();
                                    lastDisplayState = state;
                                  void receiveTime(time_t newTime)
                                    DEBUG_PRINTLN(F("Time value received and updated..."));
                                    int lastSecond = second();
                                    int lastMinute = minute();
                                    int lastHour = hour();
                                    setTime(newTime);
                                    if (((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour)) || showTime)
                                      DEBUG_PRINTLN(F("Clock updated...."));
                                      DEBUG_PRINT(F("Sensor's time currently set to:"));
                                      DEBUG_PRINT(hourFormat12() < 10 ? F(" 0") : F(" "));
                                      DEBUG_PRINT(hourFormat12());
                                      DEBUG_PRINT(minute() < 10 ? F(":0") : F(":"));
                                      DEBUG_PRINT(minute());
                                      DEBUG_PRINTLN(isAM() ? F("am") : F("pm"));
                                      DEBUG_PRINT(month());
                                      DEBUG_PRINT(F("/"));
                                      DEBUG_PRINT(day());
                                      DEBUG_PRINTLN(year());
                                      DEBUG_PRINTLN(dayOfWeek[weekday()]);
                                      showTime = false;
                                    else
                                      DEBUG_PRINTLN(F("Sensor's time did NOT need adjustment greater than 1 second."));
                                  void fastClear()
                                    lcd.print(F("                "));
                                    lcd.print(F("                "));
                                  void updateClock()
                                    static unsigned long lastVeraGetTime;
                                    if (millis() - lastVeraGetTime >= 3600000UL) // updates clock time and gets zone times from vera once every hour
                                      DEBUG_PRINTLN(F("Requesting time and valve data from Gateway..."));
                                      lcd.write(byte(0));
                                      clockUpdating = true;
                                      lastVeraGetTime = millis();
                                  void saveDateToEEPROM(unsigned long theDate)
                                    DEBUG_PRINTLN(F("Saving Last Run date"));
                                    if (gw.loadState(0) != 0xFF)
                                      gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                                    for (int i = 1; i < 5; i++)
                                      gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                                  void goGetValveTimes()
                                    static unsigned long valveUpdateTime;
                                    static byte valveIndex = 1;
                                    if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                                      DEBUG_PRINTLN(F("Calling for Valve Data..."));
                                      lcd.write(byte(1)); //lcd.write(1);
                                      gw.request(valveIndex, V_VAR1);
                                      gw.request(valveIndex, V_VAR2);
                                      gw.request(valveIndex, V_VAR3);
                                      valveUpdateTime = millis();
                                      valveIndex++;
                                      if (valveIndex > NUMBER_OF_VALVES + 1)
                                        valveIndex = 1;
                                   Take away the three dots in the bottom.
                                  Sergio RiusS ? 2 Replies Last reply
                                  • Sergio RiusS
                                    Sergio RiusS
                                    Sergio Rius
                                    Does anyone have a working portable Arduino IDE for that sketch that would want to share with me? I lost my installation and so many things changed in the built in scripts when you do a new installation. I can compile the project even using 1.4.5 mysensors libraries.
                                    Thanks a lot.
                                    • petewillP
                                      petewillP
                                      petewill
                                      @Ngwpower Don't give up! It is a learning curve for sure but totally worth it when you finally get it. Try the irrigation controller sketch from the MySensors 1.5 library example. All the required stuff should be there.
                                      @Sergio-Rius I'm not sure what you're looking for. Do you need the 1.5 version?
                                        A Former User
                                        Thanks, I envy you young people at 67 just opening the wide world of tech - do't have to do this sitting on a motor grader or Bull Dozer in the high desert. I have tried from 1.3 to 2.0 and thought I saw a flicker of LED in the string of switches, as in your example. Had my 5V on the wrong pin, so back to square one.
                                        I am having fun attempting to learn the terminology as well as the application!
                                        L petewillP 2 Replies Last reply
                                        • ? A Former User
                                          L
                                          L
                                          Lars65
                                          @Ngwpower I am 55 and still learning. I don't know anything about programming. But I spend a lot of time on forums, and reading.
                                          I would love to learn programming, but I have a slow learning curve now.
                                          I work as a processengineer,so I guess I can understand some logic.
                                          But this is really fun stuff.
                                          Started up a couple of years ago, reading about a home made CNC mill.
                                          Now I have my own, and it got pretty big can mill surfaces about 1100x800mm.
                                          And I use it most to mill PCB boards. Hahaha.
